Can't open Minecraft via Shiginima Launcher
Using the 32bit version of manjaro, i can't use trizen -S minecraft-launcher, so I'm trying using the Shiginima launcher. When i try to launch the 1.15.2 version, i get this error in the launcher:
---- Minecraft Crash Report ----
// I feel sad now :(
Time: 3/13/20, 12:54 PM
Description: Initializing game
java.lang.ExceptionInInitializerError
	at dbr.<init>(SourceFile:157)
	at dbn.<init>(SourceFile:394)
	at net.minecraft.client.main.Main.main(SourceFile:166)
Caused by: java.lang.RuntimeException: java.lang.UnsatisfiedLinkError: Failed to locate library: liblwjgl32.so
	at cxm.<clinit>(SourceFile:38)
	... 3 more
Caused by: java.lang.UnsatisfiedLinkError: Failed to locate library: liblwjgl32.so
	at org.lwjgl.system.Library.loadSystem(Library.java:147)
	at org.lwjgl.system.Library.loadSystem(Library.java:67)
	at org.lwjgl.system.Library.<clinit>(Library.java:50)
	at org.lwjgl.system.MemoryAccessJNI.<clinit>(MemoryAccessJNI.java:13)
	at org.lwjgl.system.Pointer.<clinit>(Pointer.java:28)
	at org.lwjgl.system.Platform.mapLibraryNameBundled(Platform.java:80)
	at org.lwjgl.glfw.GLFW.<clinit>(GLFW.java:674)
	at java.base/jdk.internal.misc.Unsafe.ensureClassInitialized0(Native Method)
	at java.base/jdk.internal.misc.Unsafe.ensureClassInitialized(Unsafe.java:1045)
	at java.base/java.lang.invoke.DirectMethodHandle$EnsureInitialized.computeValue(DirectMethodHandle.java:357)
	at java.base/java.lang.invoke.DirectMethodHandle$EnsureInitialized.computeValue(DirectMethodHandle.java:354)
	at java.base/java.lang.ClassValue.getFromHashMap(ClassValue.java:226)
	at java.base/java.lang.ClassValue.getFromBackup(ClassValue.java:208)
	at java.base/java.lang.ClassValue.get(ClassValue.java:114)
	at java.base/java.lang.invoke.DirectMethodHandle.checkInitialized(DirectMethodHandle.java:378)
	at java.base/java.lang.invoke.DirectMethodHandle.ensureInitialized(DirectMethodHandle.java:368)
	at java.base/java.lang.invoke.DirectMethodHandle.ensureInitialized(DirectMethodHandle.java:400)
	at cxm.<clinit>(SourceFile:35)
	... 3 more
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Render thread
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
	Minecraft Version: 1.15.2
	Minecraft Version ID: 1.15.2
	Operating System: Linux (i386) version 4.14.166-1-MANJARO
	Java Version: 13.0.1, N/A
	Java VM Version: OpenJDK Server VM (mixed mode), Oracle Corporation
	Memory: 83960136 bytes (80 MB) / 204697600 bytes (195 MB) up to 1060372480 bytes (1011 MB)
	CPUs: 2
	JVM Flags: 4 total; -Xmx1G -XX:+UseConcMarkSweepGC -XX:-UseAdaptiveSizePolicy -Xmn128M
	Launched Version: 1.15.2
	Backend library: LWJGL version 3.2.2 build 10
	Backend API: ~~ERROR~~ NoClassDefFoundError: Could not initialize class org.lwjgl.glfw.GLFW
	GL Caps:
	Using VBOs: Yes
	Is Modded: Probably not. Jar signature remains and client brand is untouched.
	Type: Client (map_client.txt)
	CPU: <unknown>
thanks for the help
