This has been going on for a while I just haven’t posted because it hasn’t bothered me but it is an issue. The Steam window opens on my second monitor but from there I can’t move or resize the window. Right-click doesn’t even do anything on the window. I can navigate the app fine otherwise.
Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=40809886-d17c-433b-876f-89a03d053b64 rw quiet splash apparmor=1
Desktop: GNOME v: 47.4 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
Type: Desktop System: Gigabyte product: AB350-Gaming v: N/A
serial: <superuser required>
Mobo: Gigabyte model: AB350-Gaming-CF v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F21 date: 02/08/2018
System RAM: total: 16 GiB available: 15.57 GiB used: 4.54 GiB (29.1%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
part-no: UD4-3000 serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001129
smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3393 min/max: 1550/3200 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 3393 2: 3393 3: 3393
4: 3393 5: 3393 6: 3393 7: 3393 8: 3393 9: 3393 10: 3393 11: 3393 12: 3393
bogomips: 76669
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate irperf lahf_lm
lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sha_ni skinit
smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 2
speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 08:00.0
chip-ID: 10de:1c02 class-ID: 0300
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
compositor: gnome-shell driver: X: loaded: N/A failed: nvidia gpu: nvidia
note: X driver n/a, try sudo/root display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x343mm (47.40x13.50")
s-diag: 1252mm (49.29")
Monitor-1: DVI-D-0 pos: primary,left res: mode: 1920x1080 hz: 60
scale: 100% (1) dpi: 82 size: 598x336mm (23.54x13.23") diag: 686mm (27.01")
modes: N/A
Monitor-2: HDMI-0 pos: right res: mode: 1920x1080 hz: 75 scale: 100% (1)
dpi: 93 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia v: 550.144.03 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
memory: 2.93 GiB
API: Vulkan v: 1.4.303 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 3GB driver: N/A device-ID: 10de:1c02 surfaces: xcb,xlib
Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: nvidia-smi
x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 08:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte
bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
API: ALSA v: k6.12.12-2-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off with: nsmd status: off tools: N/A
Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-media-session
status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli
Server-4: PulseAudio v: 17.0-43-g3e2bb status: active with: pulseaudio-jack
type: module tools: pacat,pactl,pavucontrol
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Broadcom BCM4360 802.11ac Dual Band Wireless Network Adapter
driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 07:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0b05:190e
Report: hciconfig ID: hci0 rfk-id: 0 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Info: acl-mtu: 1021:6 sco-mtu: 255:12 link-policy: rswitch hold sniff park
link-mode: peripheral accept
Local Storage: total: 3.41 TiB used: 2.75 TiB (80.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EZAZ-00L9GB0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3500312CS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5900 serial: <filter> fw-rev: CA12 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 EVO 1TB
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH30N rev: A201
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 192.26 GiB (84.4%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 40809886-d17c-433b-876f-89a03d053b64
used: 80.3 MiB (26.8%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: E832-7B45
ID-3: /run/media/nicholas/fourth-disk raw-size: 931.51 GiB
size: 915.82 GiB (98.31%) used: 853.29 GiB (93.2%) fs: ext4 dev: /dev/sdd
maj-min: 8:48 label: fourth-disk uuid: 1be4d25b-4ff6-40b0-a5c7-dfe6cc409b83
ID-4: /run/media/nicholas/second disk raw-size: 434.51 GiB
size: 426.62 GiB (98.18%) used: 257.67 GiB (60.4%) fs: ext4 dev: /dev/sdc2
maj-min: 8:34 label: second disk uuid: 1ec047b4-ec64-4d28-8893-f16ad7899256
ID-5: /run/media/nicholas/third-disk raw-size: 1.82 TiB
size: 1.79 TiB (98.37%) used: 1.47 TiB (82.4%) fs: ext4 dev: /dev/sda
maj-min: 8:0 label: third-disk uuid: 31f2d06a-293c-46c3-9216-27dc993cfb4e
ID-1: /dev/sdc1 maj-min: 8:33 size: 31.25 GiB fs: swap label: N/A
uuid: 14863704-322a-453c-b7a5-87bba34bb094
Device-1: 1-1:2 info: ASUSTek ASUS USB-BT500 type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
Device-1: 3-3:6 info: Logitech G502 Proteus Spectrum Optical Mouse
type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
chip-ID: 046d:c332 class-ID: 0300 serial: <filter>
Device-2: 3-4:7 info: Ducky One 3̠ type: HID,keyboard,mouse
driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:1011 class-ID: 0300
serial: <filter>
Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 39.1 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 360 Power: uptime: 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: gsd-power,
tool: systemctl
Packages: 2558 pm: pacman pkgs: 2530 libs: 633 tools: gnome-software,pamac
pm: flatpak pkgs: 19 pm: snap pkgs: 9 Compilers: clang: 19.1.7 gcc: 14.2.1
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.37
Edit: Just changed to Big Picture and back and it worked fine but then the system said there was an error and forced me to log out! When I logged back in I opened Steam and could move it but now it locked back into place and can’t be moved or resized again.
