I needed to restore system with timeshift
, but after selecting the needed tmeshift, it lost my btrfs
device and system freezed at once, so I had to hard reboot. After reboot grub seems to be corrupted, so I couldn’t boot into my system, and I had to use live flash drive to restore it.
Here’s list of my partitions:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 93M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 867.5M 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 1.9G 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 921.4M 1 loop /run/miso/sfs/rootfs
sda 8:0 1 7.2G 0 disk
├─sda1 8:1 1 3.8G 0 part /run/miso/bootmnt
└─sda2 8:2 1 4M 0 part
nvme1n1 259:0 0 931.5G 0 disk
├─nvme1n1p1 259:1 0 300M 0 part
├─nvme1n1p2 259:2 0 922.4G 0 part
└─nvme1n1p3 259:3 0 8.8G 0 part
nvme0n1 259:4 0 476.9G 0 disk
├─nvme0n1p1 259:5 0 1G 0 part
├─nvme0n1p2 259:6 0 16M 0 part
├─nvme0n1p3 259:7 0 468G 0 part
├─nvme0n1p4 259:8 0 641M 0 part
└─nvme0n1p5 259:9 0 7.3G 0 part
and fdisk
output:
[manjaro manjaro]# fdisk -l /dev/nvme1n1
Disk /dev/nvme1n1: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: WDS100T1X0E-00AFY0
Disklabel type: gpt
Disk identifier: 7B1CC2C0-8792-9F4A-BE2E-AAEA216C9DA9
Device Start End Sectors Size Type
/dev/nvme1n1p1 4096 618495 614400 300M EFI System
/dev/nvme1n1p2 618496 1935065125 1934446630 922.4G Linux filesystem
/dev/nvme1n1p3 1935065126 1953520064 18454939 8.8G Linux swap
But when I try to mount
the /dev/nvme1n1p2
or /dev/nvme1n1p1
, it says:
[manjaro manjaro]# mount -o subvol=@ /dev/nvme1n1p2 /mnt
mount: /mnt: mount(2) system call failed: No such file or directory.
dmesg(1) may have more information after failed mount system call.
Meanwhile in dmesg
[ 322.875171] BTRFS: device fsid 9561de22-96e5-46aa-9810-bb027c4815e9 devid 1 transid 329581 /dev/nvme1n1p2 scanned by mount (11423)
[ 322.875606] BTRFS info (device nvme1n1p2): using crc32c (crc32c-intel) checksum algorithm
[ 322.875611] BTRFS info (device nvme1n1p2): disk space caching is enabled
[ 322.947711] BTRFS info (device nvme1n1p2): enabling ssd optimizations
