Cant make a broadband connection
i just installed manjaro and i want to make a new broadband connection but i dont have broadband listed when i want to create a new connection
You should have this list after you click on the + and then chose from the dropdown menu:
If is a PPPoE connection then you chose DSL/PPPoE, otherwise you chose Mobile Broadband …
