Hello friends.
I’m using Manjaro Qonos (21.2.1) AwesomeWM edition.
When I’m not using my laptop for about 15 minutes it switches off, and after that I have to manually reconnect my Bluetooth keyboard.
I want to know whether my laptop uses “suspend” function or something else, and where/how I can control it?
Hi @chazashleyua, and welcome!
AFAIK when it comes back from sleep you should be able to see why it went to sleep/suspend/whateveryouwanttocallit with:
sudo journalctl --unit=acpid
You can also do it for any other unit
To find more units, run:
systemctl list-unit-files --all
And that can be sombined with grep
to try and finee the units qu9icker. For example;:
$ systemctl list-unit-files --all | grep -i acpi
acpid.service disabled disabled
Hope this helps!
Hmm, I just checked it, and it says
ACPI group/action undefined: jack/lineout / LINEOUT
ACPI group/action undefined: jack/videoout / VIDEOOUT
As I understand, it simply says that sound and video were disabled, but there is no info about what caused it.
Housekeeping … no activity …
