Hello everybody,
I installed Wireshark some hours ago and suddenly experienced Firefox crashing constantly, so I restarted. After restart I’m greeted by GRUB (as usual) and I’m able to boot into Manjaro XFCE. I type in my password, the screen turns black for a second and I’m back at the XFCE login screen. The password is 100% correct - when I type in a wrong password on purpose I receive the respective error message stating that the password is wrong.
EDIT:
As mentioned in an additional post, I’m able to log in as root but not with my user.
I finally found a command I executed because I wasn’t able to use Wireshark before:
sudo chmod +x /usr/bin/dumpcap
Is this somethind that could be related to my login problem?
Here’s some additional info:
System: 12Kernel 5.9.16-1-MANJARO x86_64 12bits 64 12compiler gcc 12v 10.2.0
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2021 quiet systemd.show_status=1 apparmor=1
security=apparmor driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
12Desktop Xfce 4.16.0 12tk Gtk 3.24.24 12info xfce4-panel 12wm xfwm4 12dm N/A
12Distro Manjaro Linux 12base Arch Linux
12Machine: 12Type Desktop 12Mobo ASUSTeK 12model Z170 PRO GAMING 12v Rev X.0x 12serial <filter>
12UEFI American Megatrends 12v 3606 12date 02/22/2018
12CPU: 12Info Quad Core 12model Intel Core i7-6700K 12socket LGA1151 12bits 64 12type MT MCP
12arch Skylake-S 12family 6 12model-id 5E (94) 12stepping 3 12microcode E2 12cache 12L1 256 KiB
12L2 8 MiB 12L3 8 MiB
12flags avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 12bogomips 64026
12Speed 800 MHz 12min/max 800/4200 MHz 12base/boost 4000/8300 12volts 1.2 V 12ext-clock 100 MHz
12Core speeds (MHz) 121 800 122 800 123 799 124 800 125 800 126 800 127 800 128 800
12Vulnerabilities 12Type itlb_multihit 12status KVM: VMX unsupported
12Type l1tf 12mitigation PTE Inversion
12Type mds 12mitigation Clear CPU buffers; SMT vulnerable
12Type meltdown 12mitigation PTI
12Type spec_store_bypass
12mitigation Speculative Store Bypass disabled via prctl and seccomp
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
12Type spectre_v2 12mitigation Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP:
conditional, RSB filling
12Type srbds 12mitigation Microcode
12Type tsx_async_abort 12mitigation Clear CPU buffers; SMT vulnerable
12Graphics: 12Device-1 NVIDIA GM204 [GeForce GTX 970] 12vendor Micro-Star MSI 12driver nouveau 12v kernel
12alternate nvidia_drm,nvidia 12bus-ID 01:00.0 12chip-ID 10de:13c2 12class-ID 0300
12Display 12server X.Org 1.20.10 12driver 12loaded nvidia 12display-ID :0.0 12screens 1
12Screen-1 0 12s-res 2560x1440 12s-dpi 96 12s-size 677x381mm (26.7x15.0") 12s-diag 777mm (30.6")
12OpenGL 12renderer NV124 12v 4.3 Mesa 21.0.1 12direct render Yes
12Audio: 12Device-1 Intel 100 Series/C230 Series Family HD Audio 12vendor ASUSTeK
12driver snd_hda_intel 12v kernel 12bus-ID 00:1f.3 12chip-ID 8086:a170 12class-ID 0403
12Device-2 NVIDIA GM204 High Definition Audio 12vendor Micro-Star MSI 12driver snd_hda_intel
12v kernel 12bus-ID 01:00.1 12chip-ID 10de:0fbb 12class-ID 0403
12Sound Server-1 ALSA 12v k5.9.16-1-MANJARO 12running yes
12Sound Server-2 sndio 12v N/A 12running no
12Sound Server-3 JACK 12v 0.125.0 12running no
12Sound Server-4 PulseAudio 12v 14.2 12running yes
12Sound Server-5 PipeWire 12v 0.3.24 12running no
12Network: 12Device-1 Intel Ethernet I219-V 12vendor ASUSTeK 12driver e1000e 12v kernel 12port f000
12bus-ID 00:1f.6 12chip-ID 8086:15b8 12class-ID 0200
12IF enp0s31f6 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
12Bluetooth: 12Device-1 Cambridge Silicon Radio Bluetooth Dongle (HCI mode) 12type USB 12driver btusb
12v 0.8 12bus-ID 1-2:2 12chip-ID 0a12:0001 12class-ID e001
12Report This feature requires one of these tools: hciconfig/bt-adapter
12Drives: 12Local Storage 12total 2.49 TiB 12used 73.77 GiB (2.9%)
12SMART Message Required tool smartctl not installed. Check --recommends
12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Corsair 12model Force MP510 12size 894.25 GiB
12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s 12lanes 4 12rotation SSD
12serial <filter> 12rev ECFM22.5 12temp 32.9 C
12ID-2 /dev/sda 12maj-min 8:0 12vendor Samsung 12model SSD 840 EVO 250GB 12size 232.89 GiB
12block-size 12physical 512 B 12logical 512 B 12speed 6.0 Gb/s 12rotation SSD 12serial <filter>
12rev BB6Q
12ID-3 /dev/sdb 12maj-min 8:16 12vendor Samsung 12model SSD 850 EVO 500GB 12size 465.76 GiB
12rev 2B6Q
12ID-4 /dev/sdc 12maj-min 8:32 12vendor Seagate 12model ST1000DM003-1CH162 12size 931.51 GiB
12block-size 12physical 4096 B 12logical 512 B 12speed 6.0 Gb/s 12serial <filter> 12rev CC47
12ID-5 /dev/sdd 12maj-min 8:48 12type USB 12vendor SanDisk 12model Ultra 12size 28.97 GiB
12block-size 12physical 512 B 12logical 512 B 12serial <filter> 12rev 1.00
12Partition: 12ID-1 / 12raw-size 885.45 GiB 12size 870.55 GiB (98.32%) 12used 73.77 GiB (8.5%) 12fs ext4
12block-size 4096 B 12dev /dev/nvme0n1p1 12maj-min 259:1
12Swap: 12Alert No Swap data was found.
12Sensors: 12System Temperatures 12cpu 29.8 C 12mobo 27.8 C 12gpu nouveau 12temp 46.0 C
12Fan Speeds (RPM) N/A 12gpu nouveau 12fan 0
12Info: 12Processes 264 12Uptime 11m 12wakeups 0 12Memory 31.31 GiB 12used 2.15 GiB (6.9%) 12Init systemd
12v 247 12tool systemctl 12Compilers 12gcc 10.2.0 12clang 11.1.0 12Packages 12pacman 1351 12lib 407
12flatpak 0 12Client Unknown Client: systemd 12inxi 3.3.03
Thanks in advance!
