Hi guys. I have a problem after resizing root and home partitions. It seems like I can’t log in as usual due to problem with my /home partition. I’m currently log in to tty in emergency mode with some error messages:
[DEPEND] Dependency failed for Fule System Check on <some-long-UUID>.
[DEPEND] Dependency failed for /home.
[DEPEND] Dependency failed for Local File Systems.
lsblk -f shows that there are no UUID and mountpoints and other column values for my used to home partition. And etc/fstab shows my used to working partition with all infos including UUID for my boot, root, and home partition.
Please guide me to the right direction. I’m not familiar with the underlying Arch/Manjaro as I only use this OS for work.
The focus should be at p7 and p8. Those are the root and home partition respectively. There’s no type or UUID on p8. Is there anyway for me to recover it to it’s working state?
What I did with the resizing is I resize my home partition and move it to the right, which left empty space to be reclaimed by my root partition at its left. I did this using KDE partition tool from live USB. A failure happen when moving the resized home to the right with no specific detail. But it appears to be working fine from the tool as the empty space was in the left of the home partition. So I redo the root partition resize process and it proceed successfully. Then I try to reboot and I end up with this problem.
I think the root partition is OK as the UUID match from lsblk and etc/fstab, and its info like its type and mountpoint is correct. The home partition on the other hand doesn’t shows any info from lsblk output. The partition is there, but there’s no info for its UUID, type, endpoints, etc. Can it be recovered?
Then you could do everything from the live USB instead of working from your broken system. Doesn’t solve the issue, but at least you could send proper info instead of unreadable photos of your monitor.
Looking at nvme0n1p8 property from KDE Partition Manager shows that the partition type is unformatted, and try to change it to ext4 gives me a warning that this operation will format the partition. Does that mean I can no longer able to use the partition as /home without formatting it first?
Please help me find a solution in which I can recover it. There are some ongoing works that haven’t been pushed yet
Please use testdisk to recover your data from that unformatted partition, before you do more changes. Do not apply the changes on KDE Partition Manager !!!
I guess when you resized those partitions, something did not go as planed.
Thanks for the help. I’m not familiar with the tool. Can’t recover anything. Looks like there’s no way around it. It will serves me as a hard slap for not making any backup before doing something risky.
To anyone who read this, be careful before resizing and moving a partition.
