Hi, due to an interrumped update i can’t boot manjaro and i already tried doing this method
sudo su -
manjaro-chroot -a
pacman-mirrors -f 5 && pacman -Syyu
update-grub
exit
with no success because i get stuck at the pacman part
Aparently theres an issue with pacman because everytime i write a pacman command it always returns “pacman: error while loading shared libraries: /usr/lib/libcrypto.so.3: file too short”
any help is appreciated
from chroot run this: pacman -S openssl --overwrite '*'
then rerun again:
any errors post here;
if there are none, reinstall kernel: pacman -S linux515
if there are errors, post them here, if there are none, exit chroot, reboot
Thanks for the quick answer, when i write pacman -S openssl --overwrite '*' it keeps telling me “pacman: error while loading shared libraries: /usr/lib/libcrypto.so.3: file too short” and if i run pacman-mirrors -f 5 && pacman -Syyu it tells me “ImportError: /usr/lib/libssl.so.3: file too short”
how do you start your pc, (LiveMedia, Desktop, Laptop, etc. incl. model.)
which bootloader you use
especially the steps you take to get to the point where you can chroot…
and what you get as errors etc…
Anyhow maybe you need to download a fresh LiveISO, or maybe reinstall some base packages inside the chroot environment, or simply fix your bootloader, or a combination of these
The more details you give the better people can assist you…
Your title:
Error: file ‘/boot/vmlinuz-5.15-X86-64’ not found you need to load the kernel first
Means your bootloader isn’t able to find your kernel, because the filename you mention IS the kernel.…
So let people assist you in fixing that first, you can’t fix a problem starting from the end…
Since the library is not complete (too short), it cannot be loaded. You need to download the package manually from a mirror server, extract it and copy it as root to the correct location. That is the only way to fix it, or do a fresh reinstallation (backup files!).
Keep in mind that you can use timeshift, which is recommend, to restore the system files.
