I’m having a really weird problem. I’m trying to install Manjaro Gnome to a Western Digital SN750 NVME drive which, like most drives in the world, uses a 4K native sector size (4K physical/4K logical). I chose the option to erase the disk and use Manjaro’s automatic partitioning. The graphical installer says the installation completed successfully, but when I reboot there is no EFI entry listed in my computer’s boot menu, just the option to enter the firmware setup. Upon rebooting to the Manjaro live install environment I ran “efibootmgr” which showed there was an entry labeled Manjaro. Running “Gparted” showed an EFI partition with the ESP and Boot flags enabled, a swap partition and an Ext4 root partition. Below is my system configuration. Does anyone know why my computer isn’t booting?
I’m using a System76 Gazelle laptop with the following configuration:
Intel Core i7-6700HQ CPU (4C/8T)
16GB RAM
Western Digital SN750 SSD (NVME)
Intel HD 530 graphics
