Oh my, I didn’t realise you said that in the first place… and now IT WORKS! Muahaha thanks so much
I would suggest that you use the Arch wiki in favor of these other sources of info on how to do stuff.
Manjaro is derived from Arch and almost all things are exactly the same and well documented in that wiki.
If you now use a swap file you’ll then need the “resume_offset” parameter again!
Further I’d suggest to install at least one other kernel - just to be safe and to be able to test whether this problem is kernel related - it’s probably not, though.
edit:
I just saw that you got it working now.
Good on you!
No problem mate, of course they look OK. Glad that it all worked out in the end
