I’m on a fresh install of Manjaro XFCE, and my audio isn’t working. Neither my speaker nor my headphone work when I plug them in, so I think the devices are working. When I plug them in, in Volume Control > Output Devices, Line Out appears, so it’s being detected, and when I have audio playing, the red audio visualizer thing moves.
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=5783c51f-b1f9-47c0-81c2-36e65a678c12 rw quiet apparmor=1
security=apparmor resume=UUID=ce715921-4886-469a-bf2d-00bbee2dce5c
udev.log_priority=3
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter> Chassis:
type: 3 serial: <filter>
Mobo: Gigabyte model: B75M-D3H v: x.x serial: <filter>
UEFI: American Megatrends v: F12 date: 10/26/2012
Info: Quad Core model: Intel Core i7-3770 bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 8192 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 54296
Speed: 1663 MHz min/max: 1600/3900 MHz Core speeds (MHz): 1: 1596 2: 1645
3: 1610 4: 1691 5: 2021 6: 1790 7: 1596 8: 1604
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: srbds status: Vulnerable: No microcode
Device-1: AMD Curacao PRO [Radeon R7 370 / R9 270/370 OEM]
vendor: PC Partner Limited driver: radeon v: kernel alternate: amdgpu
bus ID: 01:00.0 chip ID: 1002:6811
Display: x11 server: X.Org 1.20.10 driver: ati,radeon unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 3520x1080 s-dpi: 96 s-size: 931x285mm (36.7x11.2")
s-diag: 974mm (38.3")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
Monitor-2: DVI-0 res: 1600x900 hz: 60 dpi: 92 size: 443x249mm (17.4x9.8")
diag: 508mm (20")
OpenGL: renderer: AMD PITCAIRN (DRM 2.50.0 5.9.11-3-MANJARO LLVM 11.0.0)
v: 4.5 Mesa 20.2.3 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aab0
Sound Server: ALSA v: k5.9.11-3-MANJARO
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus ID: 03:00.0
chip ID: 10ec:8168
Device-2: Qualcomm Atheros AR922X Wireless Network Adapter driver: ath9k
v: kernel port: d000 bus ID: 04:02.0 chip ID: 168c:0029
IF: wlp4s2 state: up mac: <filter>
Local Storage: total: 1.36 TiB used: 8.51 GiB (0.6%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-00ZF5A0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 0A80 scheme: MBR
ID-2: /dev/sdb vendor: Samsung model: SSD 750 EVO 500GB size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter>
rev: 1B6Q scheme: MBR
ID-1: / raw size: 465.76 GiB size: 457.45 GiB (98.22%) used: 6.39 GiB (1.4%)
fs: ext4 dev: /dev/sdb1
ID-2: /home raw size: 923.27 GiB size: 907.77 GiB (98.32%)
used: 2.12 GiB (0.2%) fs: ext4 dev: /dev/sda3
ID-1: swap-1 type: partition size: 8.00 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: radeon temp: 41.0 C
Processes: 226 Uptime: 18m Memory: 7.72 GiB used: 1.58 GiB (20.5%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1082 lib: 324
flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.08
