Howdy, I have a dual boot Manjaro and windows computer here and I cannot seem to get any reception from my Realtek RTL8192EU 802.11b/g/n WLAN Adapter. I assumed I maybe had to update the drivers, so I connected my PC via USB tethering and I tried going on a github link to install drivers for it, but its Debian based and some of the packages don’t work for arch, and is confusing trying to convert it from apt to pacman.
The adapter is showing up on lsusb command, which is a good sign I suppose and it works on the windows partition. What can I do to get this USB device to work on Manjaro?
I had the same issue a year ago. Installing 8192eu-dkms through pamac solved it.
It might be in the AUR repository, so you might have to enable it.
Hope this helps.
yay is just another AUR helper program - like pamac or the graphical GUI for it (pamac-manager)
There is no special yay repo.
It will work.
Command line switches are the same as in pacman.
Your system has to be fully updated.
The package group “base-devel” has to be installed.
That is what pamac will do when you enable the AUR support.
yeah I updated it an hour ago. I could try again updating it. everything is updated. But I did do a git clone command, and the end of the installation, this popped up:
“ERROR: Missing 4.19.271-1-MANJARO kernel modules tree for module rtl8192eu/5.6.4.”
you really have the 419 kernel installed?
and use it?
I don’t think that the headers for that (or the kernel itself) is still available.
But that is just a guess …
I thought I did, I may have had installed a different package. I tried to install something I read online that supposedly was that (ruh roh don’t do what I did )
well I don’t know what to do now. Should I just continue to use USB tethering then or get a new adapter?
