HI Folks,
I searched around forums and I think i’m a bit confused :
I have Manjaro on auto login - which is fine.
I also have Surfshark VPN, and I have that in autostart, so when I turn on the computer - the VPN connects automatically - which is good.
The only thing is that there is a popup every time asking for a Keyring password, I always hit continue and the popup disappears then surfshark app loads after a warning about blank passwords …and then finally I have to select my VPN connection.
That all seems a bit of a faff !
Is there anyway to automate all that ?
thanks
Johnny3Gloves
Kernel: 6.6.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=17480e2f-6383-4189-8c7d-ca2681b5aefd rw quiet apparmor=1
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: M5A97 R2.0 v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 2603
date: 06/26/2015
System RAM: total: 16 GiB available: 15.52 GiB used: 2.53 GiB (16.3%)
Info: model: AMD FX-6350 bits: 64 type: MT MCP arch: Piledriver level: v2
built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0
microcode: 0x6000852
Topology: cpus: 1x cores: 6 smt: enabled cache: L1: 288 KiB
desc: d-6x16 KiB; i-3x64 KiB L2: 6 MiB desc: 3x2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1816 high: 3900 min/max: 1400/3900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400
3: 1400 4: 3900 5: 1400 6: 1400 bogomips: 50731
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht
hw_pstate ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean
vme vmmcall wdt xop xsave
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: eVga.com. driver: nvidia
v: 535.129.03 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2023-11; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1b81 class-ID: 0300
Device-2: Logitech Webcam C310 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 10-1.4:8
chip-ID: 046d:081b class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.9 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 157 s-size: 621x341mm (24.45x13.43")
s-diag: 708mm (27.89")
Monitor-1: Unknown-1 mapped: HDMI-0 res: 3840x2160 hz: 60 dpi: 157
size: 621x341mm (24.45x13.43") modes: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 535.129.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.269 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1070 driver: nvidia v: 535.129.03
device-ID: 10de:1b81 surfaces: xcb,xlib
Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: Logitech Webcam C310 driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.6.1-1-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off with: nsmd status: off tools: N/A
Server-3: PipeWire v: 0.3.84 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
vendor: ASUSTeK P8 series driver: r8168 v: 8.052.01-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8812AE 802.11ac PCIe Wireless Network Adapter
vendor: ASUSTeK driver: rtl8821ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: c000 bus-ID: 05:00.0 chip-ID: 10ec:8812 class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
IF-ID-1: surfshark_ipv6 state: unknown speed: N/A duplex: N/A mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
IF-ID-2: surfshark_wg state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 1.35 TiB used: 184.23 GiB (13.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: J4.3 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 model: SATA3 240GB SSD size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: 0A0 scheme: MBR
ID-1: / raw-size: 931.51 GiB size: 915.81 GiB (98.31%)
used: 184.23 GiB (20.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 17480e2f-6383-4189-8c7d-ca2681b5aefd
ID-1: /dev/sdb1 maj-min: 8:17 size: 512 MiB fs: vfat label: N/A
uuid: 993C-E256
ID-2: /dev/sdb2 maj-min: 8:18 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdb5 maj-min: 8:21 size: 223.07 GiB fs: ext4 label: N/A
uuid: e03f1481-6694-465e-9597-1352991e2612
ID-4: /dev/sdc1 maj-min: 8:33 size: 223 GiB fs: ntfs label: WIN10
uuid: 01D6F7FD2E83E270
ID-5: /dev/sdc2 maj-min: 8:34 size: 585 MiB fs: ntfs label: N/A
uuid: 28E8365DE8362A08
Hub-1: 1-0:1 info: full speed or root hub ports: 5 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Device-1: 1-5:2 info: Sunplus Innovation Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 98mA chip-ID: 1bcf:0005 class-ID: 0301
Hub-2: 2-0:1 info: full speed or root hub ports: 5 rev: 2.0
Hub-3: 3-0:1 info: full speed or root hub ports: 5 rev: 2.0
Hub-4: 4-0:1 info: full speed or root hub ports: 4 rev: 2.0
Hub-5: 5-0:1 info: full speed or root hub ports: 5 rev: 1.1
Hub-6: 6-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-7: 7-0:1 info: full speed or root hub ports: 4 rev: 1.1
Hub-8: 8-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-9: 9-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-10: 10-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-11: 10-1:2 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Hub-12: 10-1.1:4 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-13: 10-1.1.1:7 info: ASIX AX68004 ports: 7 rev: 1.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b95:6804
Device-1: 10-1.3:6 info: SteelSeries ApS Apex 3 TKL type: keyboard,HID
driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 400mA chip-ID: 1038:1622 class-ID: 0300
Device-2: 10-1.4:8 info: Logitech Webcam C310 type: video,audio
Hub-14: 10-2:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-15: 10-2.1:5 info: ASIX AX68004 ports: 7 rev: 1.0
Hub-16: 11-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 24.4 C mobo: N/A gpu: nvidia temp: 45 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Processes: 222 Uptime: 9m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 2009
pm: pacman pkgs: 1972 libs: 415 tools: pamac pm: flatpak pkgs: 21 pm: snap
pkgs: 16 Shell: Zsh v: 5.9 default: Bash v: 5.2.15 running-in: konsole
inxi: 3.3.31
