So here’s what I want
Screen blank 2 minutes, lock 3 minutes, suspend 5 minutes, hibernate 15. I can’t seem to get it to hibernate (full off automatically) no matter how much I try. Doing it manually seems to work.
As a side note, I can’t seem to get the integrated usb camera to shut down either, and I never use it
Lenovo ThinkPad X1 Carbon Gen 8
Intel® Core™ i7-10610U × 8
Mesa Intel® UHD Graphics (CML GT2)
Gnome 43.2
Wayland
tlp 1.5.0
systemd 252.5
logind.conf
[Login]
UserStopDelaySec=30
HandleLidSwitch=suspend-then-hibernate
IdleAction=suspend-then-hibernate
IdleActionSec=15min
sleep.conf
[Sleep]
SuspendMode=suspend-then-hibernate
HibernateMode=suspend
HibernateState=disk
HibernateDelaySec=15min
tlp.conf
CPU_BOOST_ON_AC=1
CPU_BOOST_ON_BAT=1
CPU_ENERGY_PERF_POLICY_ON_BAT=power
CPU_HWP_DYN_BOOST_ON_AC=1
CPU_HWP_DYN_BOOST_ON_BAT=1
CPU_MAX_PERF_ON_BAT=90
CPU_MIN_PERF_ON_BAT=10
CPU_SCALING_GOVERNOR_ON_AC=ondemand
CPU_SCALING_GOVERNOR_ON_BAT=powersave
CPU_SCALING_MAX_FREQ_ON_BAT=800000
CPU_SCALING_MIN_FREQ_ON_BAT=400000
DEVICES_TO_DISABLE_ON_BAT="bluetooth nfc wwan"
DEVICES_TO_DISABLE_ON_BAT_NOT_IN_USE="bluetooth nfc wifi wwan"
DEVICES_TO_DISABLE_ON_LAN_CONNECT="wifi wwan"
DEVICES_TO_DISABLE_ON_STARTUP="bluetooth nfc wwan"
DEVICES_TO_ENABLE_ON_STARTUP="wifi"
DISK_IDLE_SECS_ON_BAT=5
INTEL_GPU_BOOST_FREQ_ON_BAT=1150
INTEL_GPU_MAX_FREQ_ON_BAT=600
INTEL_GPU_MIN_FREQ_ON_BAT=300
NMI_WATCHDOG=0
PCIE_ASPM_ON_BAT=powersupersave
PLATFORM_PROFILE_ON_AC=balanced
PLATFORM_PROFILE_ON_BAT=low-power
RESTORE_THRESHOLDS_ON_BAT=1
START_CHARGE_THRESH_BAT0=75
STOP_CHARGE_THRESH_BAT0=95
USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN=
USB_EXCLUDE_AUDIO=0
USB_EXCLUDE_PRINTER=0
mkinitcpio.conf
BINARIES=("/usr/bin/btrfs")
COMPRESSION="zstd"
FILES=""
HOOKS="base systemd sd-plymouth autodetect keyboard keymap sd-vconsole block sd-encrypt modconf filesystems resume"
MODULES="crc32c-intel i915"
Any help? trying to make the battery charge as long as possible. P.S. TLP does boost take priority or max?
PPS, if any devs read this I would love a manjaro-laptop-power-settings that could set all this up for me.
