I’m trying to write a personal app but can’t find the C++ compiler and QtCreate won’t work without it. Any pointers would help this new Manjaro user.
Run sudo pacman -Syu base-devel
, when prompted, select “all”. Or sudo pacman -Syu clang
if you want to use clang. Although it’s interesting that you were able to install QtCreator(?) without installing a C++ compiler since clang
is a hard dependency of it.
Thanks! Your suggestion seemed to work, I found the compiler and now I need to muck around. Manjaro kde plasma is my first and only linux experience, although I used SGI unix as part of a large (~100 developers) team back in the 1980’s and 90’s. I’m just playing around in my retirement now. Thanks again, I’ll mark this closed now.
