the device i am using a dell 5190 2in1 and i cant seam to use my touch screen i have tryed using a couple different kernels but still nothing. its not listed as a usb device ether
Please post the output of inxi -Fazy
, sudo dmesg | egrep -i '(touch|screen|i2c|hid|input)'
, and libinput list-devices
inxi -fanzy gave System: Kernel: 5.10.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64 root=UUID=c1db7fb5-4e85-412c-9de3-305b2ea24cb1 rw rootflags=subvol=@ quiet apparmor=1 security=apparmor udev.log_priority=3 Desktop: KDE Plasma 5.20.3 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux Machine: Type: Laptop System: Google product: Coral v: rev2 serial: <filter> Chassis: type: 9 serial: <filter> Mobo: Google model: Coral v: rev2 serial: <filter> BIOS: coreboot v: N/A date: 11/27/2018 Battery: ID-1: BAT0 charge: 33.8 Wh condition: 38.3/42.0 Wh (91%) volts: 12.2/11.4 model: BYD DELL FY type: Li-ion serial: <filter> status: Discharging cycles: 106 CPU: Info: Quad Core model: Intel Celeron N3450 bits: 64 type: MCP arch: Goldmont family: 6 model-id: 5C (92) stepping: 9 microcode: 38 L2 cache: 1024 KiB flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8756 Speed: 2089 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 2089 2: 2089 3: 2088 4: 2088 Vulnerabilities: Type: itlb_multihit status: Not affected Type: l1tf status: Not affected Type: mds status: Not affected Type: meltdown status: Not affected Type: spec_store_bypass status: Not affected Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling Type: srbds status: Not affected Type: tsx_async_abort status: Not affected Graphics: Device-1: Intel HD Graphics 500 driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5a85 Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-5:2 chip ID: 0bda:5520 serial: <filter> Device-3: Realtek Integrated_Webcam_5M type: USB driver: uvcvideo bus ID: 1-8:4 chip ID: 0bda:565d serial: <filter> Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1 Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0") s-diag: 414mm (16.3") Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 133 size: 260x140mm (10.2x5.5") diag: 295mm (11.6") OpenGL: renderer: Mesa Intel HD Graphics 500 (APL 2) v: 4.6 Mesa 20.2.2 direct render: Yes Audio: Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Imaging Unit driver: N/A bus ID: 00:03.0 chip ID: 8086:5a88 Device-2: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster driver: snd_soc_skl v: kernel alternate: snd_hda_intel,snd_sof_pci bus ID: 00:0e.0 chip ID: 8086:5a98 Sound Server: ALSA v: k5.10.0-1-MANJARO Network: Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: 1040 bus ID: 01:00.0 chip ID: 8086:095a IF: wlp1s0 state: up mac: <filter> Drives: Local Storage: total: 29.12 GiB used: 17.09 GiB (58.7%) ID-1: /dev/mmcblk1 model: hB8aP size: 29.12 GiB block size: physical: 512 B logical: 512 B serial: <filter> rev: 0x8 scheme: MBR SMART Message: Unknown smartctl error. Unable to get data. Partition: ID-1: / raw size: 25.11 GiB size: 25.11 GiB (100.00%) used: 15.75 GiB (62.7%) fs: btrfs dev: /dev/mmcblk1p2 ID-2: /home raw size: 25.11 GiB size: 25.11 GiB (100.00%) used: 15.75 GiB (62.7%) fs: btrfs dev: /dev/mmcblk1p2 Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default) ID-1: swap-1 type: partition size: 4.00 GiB used: 1.34 GiB (33.4%) priority: -2 dev: /dev/mmcblk1p3 Sensors: System Temperatures: cpu: 83.0 C mobo: N/A Fan Speeds (RPM): N/A Info: Processes: 242 Uptime: 1d 18h 06m Memory: 3.72 GiB used: 2.40 GiB (64.5%) Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1319 lib: 392 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
[quote=“pobrn, post:2, topic:38153”]
[/quote] gave no output
