Kernel: 5.10.79-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=bb1a311a-3fba-4691-ad1c-d323a29a910b rw quiet apparmor=1
security=apparmor resume=UUID=3eae381f-2c33-4c37-831c-12468ad94321
udev.log_priority=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: i3 4.20.1 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME X370-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5220
date: 09/12/2019
Device-1: hidpp_battery_0 model: Logitech Wireless Gaming Mouse
status: Discharging
RAM: total: 15.62 GiB used: 4.26 GiB (27.2%)
Info: 8-Core model: AMD Ryzen 7 1800X bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 1 stepping: 1 microcode: 8001138 cache:
L1: 768 KiB L2: 4 MiB L3: 16 MiB bogomips: 123012
Speed: 2695 MHz min/max: 2200/3850 MHz boost: disabled Core speeds (MHz):
1: 3134 2: 1921 3: 1898 4: 2119 5: 1904 6: 3067 7: 2057 8: 2153 9: 2011
10: 2089 11: 1852 12: 2764 13: 2062 14: 1969 15: 3058 16: 1913
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1080] driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 0a:00.0 chip-ID: 10de:1b80
class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: picom v: git-c4107 driver:
Screen-1: 0 s-res: 5360x1440 s-dpi: 101 s-size: 1348x362mm (53.1x14.3")
s-diag: 1396mm (55")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
Monitor-2: DP-4 res: 3440x1440 dpi: 107 size: 819x346mm (32.2x13.6")
diag: 889mm (35")
OpenGL: renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44
direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 0a:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0c:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-2:3 chip-ID: 0d8c:0005
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.10.79-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: ASUSTeK
driver: wl v: kernel modules: bcma bus-ID: 06:00.0 chip-ID: 14e4:43a0
class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: e000 bus-ID: 08:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp8s0 state: down mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-3:3 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Local Storage: total: 3.64 TiB used: 1.32 TiB (36.2%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000LX001-1RG174
type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: GPT
ID-1: / raw-size: 914.03 GiB size: 898.61 GiB (98.31%)
used: 24.05 GiB (2.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: bb1a311a-3fba-4691-ad1c-d323a29a910b
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: F178-6045
ID-3: /mnt/c5aadcd6-5b50-4927-8820-f4d09c547490 raw-size: 1.82 TiB
size: 1.79 TiB (98.37%) used: 1.29 TiB (71.9%) fs: ext4 dev: /dev/sdb1
maj-min: 8:17 label: raw storage uuid: c5aadcd6-5b50-4927-8820-f4d09c547490
ID-4: /run/media/brodys/76750b29-c665-4edb-b281-836357510979
raw-size: 914.03 GiB size: 898.61 GiB (98.31%) used: 8.05 GiB (0.9%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 76750b29-c665-4edb-b281-836357510979
ID-1: swap-1 type: partition size: 17.19 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 3eae381f-2c33-4c37-831c-12468ad94321
ID-1: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: vfat label: NO_LABEL
uuid: 398A-F366
ID-2: /dev/sda3 maj-min: 8:3 size: 17.18 GiB fs: swap label: swap
uuid: adb685c8-1b08-40cf-98e2-f26e6cd22f30
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 1-3:3 info: Broadcom BCM20702A0 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:21e8
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 5-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 5-1.4:4 info: Logitech Cordless Mouse Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c537 class-ID: 0300
Device-2: 5-2:3 info: C-Media Blue Snowball type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0005 class-ID: 0300
serial: <filter>
Device-3: 5-4:5
info: Razer USA RZ03-0203 Gaming Keyboard [BlackWidow Chroma V2]
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:0221 class-ID: 0300
Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-8: 6-1:2 info: Genesys Logic Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
System Temperatures: cpu: 33.5 C mobo: N/A gpu: nvidia temp: 57 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 37%
Processes: 332 Uptime: 1h 25m wakeups: 25 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1482
lib: 438 flatpak: 0 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.09
i’ve done just about everything i can find in forums and the wiki for this, i have been struggling to get an xbox controller to fully connection and function. last night i was successful with registering it with xpadneo but zero input received. this morning i can not even register it in kde’s bluetooth. im loosing my wits over this and about to throw in the towel. ive disabled ertm and still see the loop issues every once in awhile. ive even tried connecting via windows to update the controller and windows doesnt even see the usb! ive also attempted straight usb connections for the controller on linux with the exact same issue. the kernel should support that by default yet controller wont connect.
