Hi!
I have windows as the second OS, I can connect to my wifi that uses n standard.
But I can’t do it using Linux.
Infinity “Configuring interface”.
Also, I have second wifi that uses ac standard, and Linux can connect to it.
I think because I have wifi-adapter “Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter” for 802.11ac standard. But how it works on windows? Maybe I should install some drivers on linux?
Thanks in advance!
Drivers for that adapter are already included in the kernel. It’s the ath10k
module.
Searching these forums, our archived forum and the Arch forums should yield good results.
Disclaimer: Manjaro is not Arch. Arch is not Manjaro. Please do not post in the Arch forums unless your are using Arch.
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel port: 4000 bus ID: 02:00.0
chip ID: 168c:003e
vendor: Acer Incorporated ALI driver: r8168 v: 8.048.03-NAPI modules: r8169
port: 3000 bus ID: 03:00.1 chip ID: 10ec:8168
Maybe dmesg shows more information:
sudo dmesg | grep ath10k
Also a full journal log could help to see a hint of your problem:
journalctl -b1 --no-pager
And sure in the forum are a lot of problems with that driver.
sudo dmesg | grep ath10k:
[ 19.958657] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 20.395159] ath10k_pci 0000:02:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 11ad:0807
[ 20.395164] ath10k_pci 0000:02:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[ 20.396339] ath10k_pci 0000:02:00.0: firmware ver WLAN.RM.4.4.1-00157-QCARMSWPZ-1 api 6 features wowlan,ignore-otp,mfp crc32 90eebe
fb
[ 20.502041] ath10k_pci 0000:02:00.0: board_file api 2 bmi_id N/A crc32 318825bf
[ 20.594287] ath10k_pci 0000:02:00.0: htt-ver 3.60 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 20.744129] ath10k_pci 0000:02:00.0 wlp2s0: renamed from wlan0
The last log entry is dated November 29. I don’t know why, I tried to connect to wifi after this date.
