Can't connect to samba after update; Service is running (2022-08-13++)
Yea I’m now having the same problem.
The latest version of SAMBA will NOT allow shares the 2nd disk on my system mounted at /mnt/blah. This HAS been working fine for the last 2+ year though…
Possible dupilcate:
I am facing the same problem.
I configured my system from the arch wiki instructions Samba - ArchWiki
My config
[global]
        workgroup = Beast
        server role = standalone server
        server string = %h server (Samba %v)
        invalid users = root
        security = user
        usershare path = /var/lib/samba/usershares
        usershare max shares = 100
        usershare allow guests = yes
        usershare owner only = yes
[homes]
        comment = Home Directories
        browseable = no
        valid users = %S
        writable = yes
Samba status
❯ systemctl status smb
● smb.service - Samba SMB Daemon
     Loaded: loaded (/usr/lib/systemd/system/smb.service; enabled; preset: disabled)
     Active: active (running) since Tue 2022-08-16 06:40:27 AEST; 22min ago
       Docs: man:smbd(8)
             man:samba(7)
             man:smb.conf(5)
   Main PID: 1326 (smbd)
     Status: "smbd: ready to serve connections..."
      Tasks: 4 (limit: 38407)
     Memory: 31.3M
        CPU: 193ms
     CGroup: /system.slice/smb.service
             ├─1326 /usr/bin/smbd --foreground --no-process-group
             ├─1333 /usr/bin/smbd --foreground --no-process-group
             ├─1334 /usr/bin/smbd --foreground --no-process-group
             └─9352 /usr/bin/smbd --foreground --no-process-group
Aug 16 06:40:27 Manjaro systemd[1]: Starting Samba SMB Daemon...
Aug 16 06:40:27 Manjaro smbd[1326]: [2022/08/16 06:40:27.380204,  0] ../../source3/smbd/server.c:1741(main)
Aug 16 06:40:27 Manjaro smbd[1326]:   smbd version 4.16.4 started.
Aug 16 06:40:27 Manjaro smbd[1326]:   Copyright Andrew Tridgell and the Samba Team 1992-2022
Aug 16 06:40:27 Manjaro systemd[1]: Started Samba SMB Daemon.
Adding a share with samba user does not work
net usershare add share_name_here /mnt/Data/share_folder "Comment" "my_host\samba_user:f"
net usershare add: cannot convert name "my_host\samba_user" to a SID. The transport connection is now disconnected..
It works if I use the user’s SID but I still cannot access the share.
I configured mine using the following Manjaro Wiki article:
hi, I tried your way, I created my own predictable structure data/…bla**, stock, with changed permission, ownership, and all possible combos, but it does not work.
Hello, Manjaro Users
I still have a problem with Samba on Manjaro 21.3.7 (2022-08-16)
Can someone confirm that Samba issues are still present and not being fixed in this version?
Thank you
Apidech T.
Facing that issue too, thanks for a topic.
Still a problem, I even reverted to 4.16.2-1 of smb and smbclient but same problem. It must be related to something else in the recent update.
I can see shares using net usershare list
But cannot access or see it using smbclient -L or a Windows network map from explorer.
Here are some results from investigations:
❯ cat /etc/samba/smb.conf
[global]
        workgroup = MyWorkgroup
        security = user
[homes]
        browseable = no
        valid users = %S
        writable = yes
❯ net usershare list
Min
❯ smbclient -L 192.168.1.100 -U smb_user
Password for [.....]:
        Sharename       Type      Comment
SMB1 disabled -- no workgroup available
     Active: active (running) since Wed 2022-08-17 06:53:17 AEST; 2h 2min ago
       Docs: man:smbd(8)
             man:samba(7)
             man:smb.conf(5)
   Main PID: 1353 (smbd)
      Tasks: 3 (limit: 38407)
     Memory: 30.5M
        CPU: 567ms
             ├─1353 /usr/bin/smbd --foreground --no-process-group
             ├─1360 /usr/bin/smbd --foreground --no-process-group
             └─1361 /usr/bin/smbd --foreground --no-process-group
Aug 17 06:53:17 Manjaro systemd[1]: Starting Samba SMB Daemon...
Aug 17 06:53:17 Manjaro smbd[1353]: [2022/08/17 06:53:17.519333,  0] ../../source3/smbd/server.c:1741(main)
Aug 17 06:53:17 Manjaro smbd[1353]:   smbd version 4.16.4 started.
Aug 17 06:53:17 Manjaro smbd[1353]:   Copyright Andrew Tridgell and the Samba Team 1992-2022
Aug 17 06:53:17 Manjaro systemd[1]: Started Samba SMB Daemon.
❯ journalctl -S "6 hour ago" -xu smb.service
░░ Subject: A start job for unit smb.service has begun execution
░░ Defined-By: systemd
░░ A start job for unit smb.service has begun execution.
░░ The job identifier is 97.
░░ Subject: A start job for unit smb.service has finished successfully
░░ A start job for unit smb.service has finished successfully.
░░ The job identifier is 97.         ✔
For me, this was an AppArmor issue. My shares are located outside of my home directory and i had to whitelist them in /etc/apparmor.d/local/usr.sbin.smbd.
https://wiki.archlinux.org/title/samba#Permission_issues_on_AppArmor
Thanks ! That made the trick for me!
This fixes the problem for me too.
Hooray, hooray - thanks to TheInvi(n)sible!
:clap:
I wish there were more Invisible like you making a difference!!!
:metal: :partying_face: :metal:
Hi my share are also located outside of home directory how can I whitelist it
let’s say this is my location
/mnt/befadfl-asdklf-wuqio-0e1/cupcakes/pineapple
I’ve opened nano to edit it I just don’t know what word to enter
Have a look at the example in the linked Arch wiki. Replace /data with your path. Save it and then restart AppArmor service or reboot your System.
"/data/" rk,
"/data/**" lrwk,
hey thanks but what’s rk, lrwk written in arch wiki , do I have to add it too if so which one rk or lrwk or both
Upgrade without samba and smbclient.
Same issue after doing a full upgrade.
About 5 times, I restored and confirmed using snapshot.
I’ll leave it alone for the time being.
My personal opinion and expectation is that editing a working smb.conf is just a waste of time.
Kernel: 5.18.14-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Desktop: Cinnamon v: 5.4.9 Distro: Manjaro Linux base: Arch Linux
r ead, w rite and so on. A more detailed description can be found in the AppArmor documentation:
Hi, I’m having the same problem but my shares are in the home folder. Same problem on multiple computers.
This fix seems to work. I believe you need BOTH AppArmor settings. And then you need to RESTART AppArmor via “sudo systemctl restart apparmor”
Hey thanks a lot! You saved my day. I couldn’t figure out what went suddenly wrong and wasted hours to find the reason (thought it was a recent Windows update).
In my case, a folder under my /home/user was shared, but not my Dropbox folder under /media/… It also didn’t matter that until today I shared a link to that Dropbox folder under my /home/user directory.
Your solution works perfectly!
