1.1.1.1 is much better thank you so much.now my ethernet works.
disable also the ipv6 as instructed above…
also install the proper video drivers, you have only nvidia - intel gpu is disabled in bios - and are on the open source drivers, which are not good, so install the proprietary one: system settings/hardware configuration and click ‘auto install proprietary drivers’, then reboot, and post output from:
inxi -G
to verify that nvidia drivers are loaded
