Zapaxe
December 26, 2022, 9:55am
#1
I am a noob at linux so please make it sound simple for me to understand.I liked the way manjaro looked so I downloaded manjaro KDE plasma and dual booted it with windows 11.When I am using windows 11 I always use ethernet.When i was installing manjaro i was using ethernet but it said in the installer that you are not connected to a network.I ignored that and i installed manjaro.For the first time when I booted in to manjaro it said that i am connected to a network but cannot acess internet.So i tried using a wifi adapter coz my motherboard dosen’t have built in wifi.But that also didn’t work as it said no available networks.Then i tried it on windows and the wifi adapter seems to be working fine on windows 11.Then i hopped back in to manjaro and tried usb tethering and it worked fine.I used that to search the forums for a fix.In one forum someone was recommending to go check my drivers so I did.My network driver was in open source so i installed it.After that i disconnected usb tehering and plugged my ehternet back.And now it didnt even say that it was “connected to a network but couldnt connect to internet”.Then i unistalled it and reinstalled the driver again and again but it didnt work.I typed this commandinxi -Nazy
to check my ethernet type and here are the results.
vendor: ASRock driver: N/A modules: r8169, r8168 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
brahma
December 26, 2022, 10:15am
#2
what were the commands used for installing/removing the ethernet driver?
Zapaxe
December 26, 2022, 10:43am
#3
i didint use commands.i went to system settings and then hardware configuration.then selected my drive which said open source.I right clicked it and pressed install.this was all done by usb tethering connection
brahma
December 26, 2022, 10:48am
#4
post output from:
mhwd -l -li
Zapaxe
December 26, 2022, 10:52am
#5
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
> 0000:01:00.0 (0300:10de:1401) Display controller nVidia Corporation:
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-nvidia-390xx 2021.11.26 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
brahma
December 26, 2022, 10:53am
#6
ok, you have installed the ethernet driver, so reboot and then post full system info:
inxi -Fazv7
Zapaxe
December 26, 2022, 10:58am
#7
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=bce12070-3f4c-4fd6-8c11-083fffd494c0 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Desktop Mobo: ASRock model: H110M-HDV serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: P7.60 date: 02/26/2018
RAM: total: 15.59 GiB used: 1.19 GiB (7.7%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake
gen: core 7 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 9 microcode: 0xF0
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 24008
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
disabled
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: ZOTAC driver: nouveau
v: kernel non-free: 515.xx+ status: current (as of 2022-07) arch: Maxwell
code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DVI-I-1 empty: DP-1,DVI-D-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1401 class-ID: 0300
Device-2: Generalplus GENERAL WEBCAM type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-7:4 chip-ID: 1b3f:2247
class-ID: 0102
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: nouveau display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: DVI-I-1 model: Sanyo LED MONITOR serial: <filter> built: 2011
res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55")
diag: 547mm (21.5") ratio: 15:9, 16:9 modes: max: 1920x1080 min: 720x400
OpenGL: renderer: NV126 v: 4.3 Mesa 22.1.6 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 1-7:4 chip-ID: 1b3f:2247
bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0102 class-ID: 0403
Device-2: NVIDIA GM206 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fba
class-ID: 0403
Device-3: Generalplus GENERAL WEBCAM type: USB
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
class-ID: 0200
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Local Storage: total: 1.13 TiB used: 480.34 GiB (41.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: KingDian model: S280 240GB
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 7A scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZEX-22MFCA0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: MBR
Optical-1: /dev/sr0 vendor: ATAPI model: DVD A DH16A6L rev: ZH39
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 146.48 GiB size: 143.13 GiB (97.71%) used: 8.76 GiB
(6.1%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: bce12070-3f4c-4fd6-8c11-083fffd494c0
ID-2: /run/media/zapaxe/50C660F5C660DCAA raw-size: 222.86 GiB size: 222.86
GiB (100.00%) used: 188.84 GiB (84.7%) fs: ntfs dev: /dev/sda3
maj-min: 8:3 label: N/A uuid: 50C660F5C660DCAA
ID-3: /run/media/zapaxe/Dilith raw-size: 492.06 GiB size: 492.06 GiB
(100.00%) used: 245.48 GiB (49.9%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17
label: Dilith uuid: 8CF8958AF89572E6
ID-4: /run/media/zapaxe/Rajith raw-size: 292.97 GiB size: 292.97 GiB
(100.00%) used: 37.26 GiB (12.7%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18
label: Rajith uuid: A04EFB8D4EFB5B0C
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: 8A55-343B
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda4 maj-min: 8:4 size: 611 MiB fs: ntfs label: N/A
uuid: 5C260AA9260A846C
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-5:2 info: YK 2.4G Wireless Device type: Mouse,Keyboard
power: 100mA chip-ID: 3938:1080 class-ID: 0301
Device-2: 1-7:4 info: Generalplus GENERAL WEBCAM type: Video,Audio
power: 100mA chip-ID: 1b3f:2247 class-ID: 0102
Device-3: 1-9:5 info: China Resource Semico Usb Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 98mA chip-ID: 1a2c:0044 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 41.0 C pch: 44.5 C mobo: N/A gpu: nouveau
temp: 48.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 291
Processes: 188 Uptime: 3m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: pacman: 1172 lib: 316 flatpak: 0 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.20
brahma
December 26, 2022, 11:01am
#8
the driver was loaded, otherwise you wouldnt see this … now its no longer loaded, since you messed with it…
check in bios if fast boot is disabled - you may not have this option;
and in windows fast startup needs to be disabled, if its not, disable it
Zapaxe
December 26, 2022, 11:07am
#9
Also i have to say that the ssd where windows is installed is a gpt or UEFI drive and the drive where manjaro is installed is a mbr or legacy drive.
brahma
December 26, 2022, 11:20am
#10
why would you do that, if you can use uefi/gpt? … but check the fast boot and the fast startup, and disable them
Zapaxe
December 26, 2022, 11:37am
#11
I disabled fast boot in bios fast startup in windows.I didnt install manjaro in the ssd beacause it was a 256GB ssd and i had 1TB of free space on normal hard drive
brahma
December 26, 2022, 11:39am
#12
ok, but that you are on mbr is not related…
so after you disabled them, check again with:
inxi -N
to see if the ethernet driver is loaded
Zapaxe
December 26, 2022, 11:40am
#13
this is the response
driver: N/A
brahma
December 26, 2022, 11:44am
#14
Zapaxe:
driver: N/A
not loaded, have no idea what happened here, since it was working previously …
run this:
sudo modprobe r8169
did this loaded the driver?
Zapaxe
December 26, 2022, 11:48am
#15
i entered the command it it didnt do anything but now my it is saying it is connected to a network but can connect to internet.
brahma
December 26, 2022, 11:50am
#16
ok so it loaded the driver… so now in system settings/network/connections/wired connection/ipv4 set up your dns/address/netmask/gateway, click apply
Zapaxe
December 26, 2022, 11:53am
#17
can you tell me how to add my dns
brahma
December 26, 2022, 11:54am
#18
select the method as ‘manual’, and in dns servers type your provider dns, or use cloudflare dns: 1.1.1.1 or quad dns: 9.9.9.9
Zapaxe
December 26, 2022, 12:24pm
#19
Now my ethernet works but its really slow.i used quad dns as my dns
brahma
December 26, 2022, 12:31pm
#20
and how is the speed with 1.1.1.1? is it better?
and did you set up everything else, your ip, mask, gateway?
go to the ipv6 tab, and under method disable it, and see if it helps
