Before, I connect to the Wi-Fi, ethernet, and the VPN at the same time, but now, I can only connect to both Wi-Fi and VPN. Every time I try to connect to the ethernet, this error shows up. I noticed this only started happening after I added new connections (ProtonVPN Openvpn free servers). I also noticed that I have 2 bridge connections (docker0 and br-fa35f3ab6288) this is the result of sudo docker ps
~ » sudo docker ps soumi@Hori
[sudo] password for soumi:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
8d70746815e3 pihole/pihole:latest "/s6-init" 4 weeks ago Up 54 minutes (healthy) 0.0.0.0:53->53/tcp, :::53->53/tcp, 0.0.0.0:80->80/tcp, 0.0.0.0:53->53/udp, :::80->80/tcp, :::53->53/udp, 67/udp pihole
What should I do about this? Thanks
inxi -Fazy
~ » inxi -Fazy soumi@Hori
Kernel: 5.15.6-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=363676ef-6401-4c77-b58f-69e59d05639b rw quiet
resume=UUID=74191adc-235f-4ce2-b1f3-9f9ec427fcac udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: docker wm: kwin_x11 vt: 1
Type: Laptop System: Acer product: Aspire A514-53 v: V1.16
Mobo: IL model: Sneezy_IL v: V1.16 serial: <superuser required>
UEFI: Insyde v: 1.16 date: 01/18/2021
ID-1: BAT0 charge: 32.6 Wh (100.0%) condition: 32.6/53.0 Wh (61.5%)
volts: 16.5 min: 15.4 model: PANASONIC KT004 AP19B5L type: Li-ion
serial: <filter> status: Full cycles: 386
Device-1: hid-f4:73:35:09:1d:b5-battery model: Keyboard K380 serial: N/A
Use of uninitialized value $val2 in string eq at /usr/bin/inxi line 6943.
Use of uninitialized value $val2 in split at /usr/bin/inxi line 6948.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6950.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6953.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6954.
charge: N/A status:
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xA6
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3312 high: 3365 min/max: 400/3400 scaling:
driver: intel_pstate governor: performance cores: 1: 3328 2: 3278 3: 3365
4: 3278 bogomips: 9524
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-6:5
chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x720 s-dpi: 96 s-size: 337x190mm (13.3x7.5")
s-diag: 387mm (15.2")
Monitor-1: eDP-1 res: 1280x720 hz: 60 dpi: 105 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
Monitor-2: HDMI-1 res: 1280x720 hz: 60 dpi: 68
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.5
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0401
Device-2: C-Media USB PnP Sound Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1:2 chip-ID: 0d8c:013a
class-ID: 0300
Sound Server-1: ALSA v: k5.15.6-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
IF-ID-1: br-fa35f3ab6288 state: down mac: <filter>
IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-3: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IF-ID-4: veth0eac795 state: up speed: 10000 Mbps duplex: full
mac: <filter>
bus-ID: 1-10:6 chip-ID: 8087:0026 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 3.0
lmp-v: 5.2 sub-v: 2405 hci-v: 5.2 rev: 2405
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: peripheral accept
service-classes: rendering, capturing, object transfer, audio, telephony
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.4 TiB used: 458.62 GiB (31.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0202A
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: G002 temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:9 vendor: Intel model: HBRPEKNX0202AO
size: 27.25 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: K5110440 temp: 46.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 69.85 GiB size: 68.2 GiB (97.64%) used: 27.82 GiB (40.8%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 489 MiB size: 488 MiB (99.80%)
used: 68.2 MiB (14.0%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
ID-3: /home raw-size: 144.36 GiB size: 141.59 GiB (98.08%)
used: 65.52 GiB (46.3%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-1: swap-1 type: partition size: 14.9 GiB used: 2.5 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 70.0 C mobo: N/A
Processes: 272 Uptime: 55m wakeups: 2 Memory: 7.45 GiB
used: 3.97 GiB (53.4%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1386 pacman: 1375 lib: 367 flatpak: 11 Shell: Zsh
v: 5.8 running-in: terminator inxi: 3.3.10
