Hi everyone! My teacher told me to install lamp for my code course at college. Well, it worked using the package available in the aur but somehow I can’t configure it. I found the tutorial in this forum, but I’m stuck and have no Idea how to move forward.
And all of them seemed to work well, bu I got this message when I run sudo systemctl status httpd
× httpd.service - Apache Web Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; preset: disabled)
Active: failed (Result: exit-code) since Fri 2022-09-16 00:28:02 -05; 3s ago
Duration: 64ms
Process: 82463 ExecStart=/usr/bin/httpd -k start -DFOREGROUND (code=exited, status=1/FAILURE)
Main PID: 82463 (code=exited, status=1/FAILURE)
CPU: 21ms
set 16 00:28:02 snakepit systemd[1]: Started Apache Web Server.
set 16 00:28:02 snakepit httpd[82463]: AH00534: httpd: Configuration error: More than one MPM loaded.
set 16 00:28:02 snakepit systemd[1]: httpd.service: Main process exited, code=exited, status=1/FAILURE
set 16 00:28:02 snakepit systemd[1]: httpd.service: Failed with result 'exit-code'.
I hope anybody has an idea on how to fix this. Thanks!
Since you made changes to httpd.conf , make sure you use only one Multi-Processing Module. Apache supports 3 (prefork, worker or event), choose only one.
If you want to use php, choose prefork.
Yes, he told me to use Ubuntu instead. Right now we’re only using NetBeans so I’m not missing anything, and I’m installing Ubuntu on VM to use lamp, but I’d like to use it in Manjaro too.
For an educational environment requires stability, predicatablity and a one to one reference of the material used in your education.
Manjaro does not provide such environment - it is fundamentally different from Ubuntu - so stay with the virtual machine approach - it will serve the purpose just fine.
