Good Evening All.
I did a complete wipe and fresh install of Manjaro off the current live iso and verified the checksum. The main problem is I’ve been trying for ages to get nvidia-340xx to install as nouveau is not always stable on my machine. I’ve tried to install it with LTS 5.4 as I’ve read that n…340x is no longer supported on the latest kernel.
After installing the kernel I reboot and am not given any option in grub to pick a kernel! It loads right up.
Also, when i try to install nvidia-340xx I get the message
error: target not found: linux58-nvidia-340xx
I was getting this with other installs (this is reinstall number 4!) no matter what kernel I am on, and now I can’t even select the old kernel.
I’ve run pacman-mirrors and pacman -Syyu. I ran update-grub and all looks clear.
I’m at my whit’s end, expert help is appreciated. Much thanks, even if you just read this.
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=bc66d51d-7d18-4ee9-8648-772b4bd7fcc0 rw quiet apparmor=1
security=apparmor resume=UUID=182120c7-4bb8-4138-9fc5-625e8fde0b5a
udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Apple product: MacBook5,1 v: 1.0 serial: <filter>
Chassis: type: 10 v: Mac-F42D89C8 serial: <filter>
Mobo: Apple model: Mac-F42D89C8 v: Proto serial: <filter> UEFI: Apple
v: MB51.88Z.007D.B03.0904271443 date: 04/27/09
ID-1: BAT0 charge: 36.9 Wh condition: 37.0/58.3 Wh (63%) volts: 12.5/10.8
model: Newer Tech ASMB013 type: Li-ion serial: N/A status: Full cycles: 58
Topology: Dual Core model: Intel Core2 Duo P7350 bits: 64 type: MCP
arch: Penryn family: 6 model-id: 17 (23) stepping: 6 microcode: 60F
L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 7963
Speed: 1592 MHz min/max: 1596/1995 MHz Core speeds (MHz): 1: 1592 2: 1596
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: NVIDIA C79 [GeForce 9400M] vendor: Apple MacBook5 1
driver: nouveau v: kernel bus ID: 02:00.0 chip ID: 10de:0863
Device-2: Apple Built-in iSight type: USB driver: uvcvideo bus ID: 1-4:2
chip ID: 05ac:8507 serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.3x8.3")
s-diag: 398mm (15.7")
Monitor-1: LVDS-1 res: 1280x800 hz: 60 dpi: 114 size: 286x179mm (11.3x7.0")
diag: 337mm (13.3")
OpenGL: renderer: NVAC v: 3.3 Mesa 20.1.7 direct render: Yes
Device-1: NVIDIA MCP79 High Definition Audio driver: snd_hda_intel v: kernel
bus ID: 00:08.0 chip ID: 10de:0ac0
Sound Server: ALSA v: k5.8.6-1-MANJARO
Device-1: NVIDIA MCP79 Ethernet driver: forcedeth v: kernel port: 21e0
bus ID: 00:0a.0 chip ID: 10de:0ab0
IF: enp0s10 state: down mac: <filter>
Device-2: Broadcom and subsidiaries BCM4322 802.11a/b/g/n Wireless LAN
vendor: Apple AirPort Extreme driver: wl v: kernel modules: ssb port: 1000
bus ID: 03:00.0 chip ID: 14e4:432b
IF: wls3 state: up mac: <filter>
Local Storage: total: 232.89 GiB used: 8.04 GiB (3.5%)
ID-1: /dev/sda model: Mercury Electra 6G SSD size: 232.89 GiB block size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 5A0
scheme: GPT
ID-1: / raw size: 223.79 GiB size: 219.28 GiB (97.98%) used: 8.04 GiB (3.7%)
fs: ext4 dev: /dev/sda2
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3
System Temperatures: cpu: 69.0 C mobo: N/A gpu: nouveau temp: 72 C
Processes: 151 Uptime: 6h 53m Memory: 7.53 GiB used: 1.49 GiB (19.8%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1188 lib: 341
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
sudo dmesg -l emerg,alert,crit,err,warn
[ 1.144379] clocksource: timekeeping watchdog on CPU1: Marking clocksource 'tsc-early' as unstable because the skew is too large:
[ 1.144382] clocksource: 'hpet' wd_now: 18e946f wd_last: ccf066 mask: ffffffff
[ 1.144384] clocksource: 'tsc-early' cs_now: d330a8d91 cs_last: d08336c96 mask: ffffffffffffffff
[ 1.144403] TSC found unstable after boot, most likely due to broken BIOS. Use 'tsc=unstable'.
[ 2.586253] Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[ 8.427144] applesmc applesmc.768: hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[ 9.020045] applesmc: send_byte(0x00, 0x0300) fail: 0x00
[ 9.020048] applesmc: LKSB: write data fail
[ 9.280061] applesmc: send_byte(0x00, 0x0300) fail: 0x00
[ 9.280064] applesmc: LKSB: write data fail
[ 9.487945] wl: loading out-of-tree module taints kernel.
[ 9.487954] wl: module license 'MIXED/Proprietary' taints kernel.
[ 9.487956] Disabling lock debugging due to kernel taint
[ 9.597940] wlan0: Broadcom BCM432b 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[ 9.800783] ACPI Warning: \_SB.PCI0.IXVE.IGPU._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200528/nsarguments-59)
[ 10.388487] uvcvideo 1-4:1.0: Entity type for entity Processing 3 was not initialized!
[ 10.388492] uvcvideo 1-4:1.0: Entity type for entity Camera 1 was not initialized!
[ 11.109029] kauditd_printk_skb: 26 callbacks suppressed
[ 16.311799] kauditd_printk_skb: 9 callbacks suppressed
[ 673.016673] CE: hpet increased min_delta_ns to 11521 nsec
[23703.348518] kauditd_printk_skb: 13 callbacks suppressed
[23790.854861] ata1.00: exception Emask 0x0 SAct 0x3fff200 SErr 0x1d0000 action 0x6 frozen
[23790.854865] ata1: SError: { PHYRdyChg CommWake 10B8B Dispar }
[23790.854869] ata1.00: failed command: WRITE FPDMA QUEUED
[23790.854876] ata1.00: cmd 61/08:48:c0:15:8e/00:00:05:00:00/40 tag 9 ncq dma 4096 out
res 40/00:01:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[23790.854878] ata1.00: status: { DRDY }
[23790.854880] ata1.00: failed command: WRITE FPDMA QUEUED
[23790.854886] ata1.00: cmd 61/08:60:c8:15:8e/00:00:05:00:00/40 tag 12 ncq dma 4096 out
res 40/00:01:00:4f:c2/00:00:00:00:00/00 Emask 0x4 (timeout)
[23790.854888] ata1.00: status: { DRDY }
[23790.854890] ata1.00: failed command: WRITE FPDMA QUEUED
[23790.854896] ata1.00: cmd 61/08:68:28:70:8e/00:00:05:00:00/40 tag 13 ncq dma 4096 out
[23790.854898] ata1.00: status: { DRDY }
[23790.854900] ata1.00: failed command: WRITE FPDMA QUEUED
[23790.854911] ata1.00: cmd 61/08:70:30:70:8e/00:00:05:00:00/40 tag 14 ncq dma 4096 out
res 40/00:00:00:4f:c2/00:00:00:00:00/00 Emask 0x4 (timeout)
[23790.854913] ata1.00: status: { DRDY }
[23790.854914] ata1.00: failed command: WRITE FPDMA QUEUED
[23790.854919] ata1.00: cmd 61/08:78:d0:15:8e/00:00:05:00:00/40 tag 15 ncq dma 4096 out
res 40/00:ff:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[23790.854920] ata1.00: status: { DRDY }
[23790.854922] ata1.00: failed command: WRITE FPDMA QUEUED
[23790.854927] ata1.00: cmd 61/08:80:38:70:8e/00:00:05:00:00/40 tag 16 ncq dma 4096 out
[23790.854928] ata1.00: status: { DRDY }
[23790.854930] ata1.00: failed command: WRITE FPDMA QUEUED
[23790.854935] ata1.00: cmd 61/08:88:d8:15:8e/00:00:05:00:00/40 tag 17 ncq dma 4096 out
[23790.854936] ata1.00: status: { DRDY }
[23790.854938] ata1.00: failed command: WRITE FPDMA QUEUED
[23790.854943] ata1.00: cmd 61/08:90:e0:15:8e/00:00:05:00:00/40 tag 18 ncq dma 4096 out
[23790.854944] ata1.00: status: { DRDY }
[23790.854946] ata1.00: failed command: WRITE FPDMA QUEUED
[23790.854950] ata1.00: cmd 61/08:98:40:70:8e/00:00:05:00:00/40 tag 19 ncq dma 4096 out
[23790.854952] ata1.00: status: { DRDY }
[23790.854954] ata1.00: failed command: WRITE FPDMA QUEUED
[23790.854958] ata1.00: cmd 61/08:a0:e8:15:8e/00:00:05:00:00/40 tag 20 ncq dma 4096 out
[23790.854960] ata1.00: status: { DRDY }
[23790.854961] ata1.00: failed command: WRITE FPDMA QUEUED
[23790.854966] ata1.00: cmd 61/08:a8:f0:15:8e/00:00:05:00:00/40 tag 21 ncq dma 4096 out
[23790.854968] ata1.00: status: { DRDY }
[23790.854969] ata1.00: failed command: WRITE FPDMA QUEUED
[23790.854974] ata1.00: cmd 61/08:b0:48:70:8e/00:00:05:00:00/40 tag 22 ncq dma 4096 out
[23790.854976] ata1.00: status: { DRDY }
[23790.854977] ata1.00: failed command: WRITE FPDMA QUEUED
[23790.854982] ata1.00: cmd 61/08:b8:50:70:8e/00:00:05:00:00/40 tag 23 ncq dma 4096 out
[23790.854983] ata1.00: status: { DRDY }
[23790.854985] ata1.00: failed command: WRITE FPDMA QUEUED
[23790.854990] ata1.00: cmd 61/08:c0:f8:15:8e/00:00:05:00:00/40 tag 24 ncq dma 4096 out
[23790.854991] ata1.00: status: { DRDY }
[23790.854993] ata1.00: failed command: WRITE FPDMA QUEUED
[23790.854998] ata1.00: cmd 61/20:c8:00:16:8e/00:00:05:00:00/40 tag 25 ncq dma 16384 out
[23790.854999] ata1.00: status: { DRDY }
journalctl -x -p3 -b1
-- Logs begin at Sun 2020-09-20 12:47:40 PDT, end at Sun 2020-09-20 21:02:16 PDT. --
Sep 20 13:02:42 brassmonkey kernel: ERROR @wl_cfg80211_scan :
Sep 20 13:02:58 brassmonkey kernel: ERROR @wl_cfg80211_scan :
Sep 20 13:03:54 brassmonkey kernel: ERROR @wl_notify_scan_status :
Sep 20 13:03:54 brassmonkey wpa_supplicant[773]: bgscan simple: Failed to enable signal strength monitoring
Sep 20 13:06:26 brassmonkey kernel: ERROR @wl_notify_scan_status :
Sep 20 13:06:37 brassmonkey kernel: ERROR @wl_notify_scan_status :
Sep 20 13:50:54 brassmonkey kglobalaccel5[5421]: This application failed to start because no Qt platform plugin could be i>
Available platform plugins are: wayland-org.kde.kwin.qpa, eglfs, linuxfb,>
Sep 20 13:50:54 brassmonkey systemd-coredump[5430]: Failed to send coredump datagram: Connection reset by peer
Sep 20 13:50:54 brassmonkey systemd-coredump[5457]: Failed to connect to coredump service: Connection refused
Sep 20 13:50:54 brassmonkey systemd-coredump[5433]: Failed to send coredump datagram: Connection reset by peer
