Hi. I have a laptop with FullHD. I bought a new monitor with 2k + 165Hz resolution and connected it to my laptop by HDMI. But the display settings prevent me from choosing 2k, max is 1920x1200 60Hz.
I have windows 10 as second OS and everything is fine on it.
My inxi -Fazy
is:
Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=299e9fe8-41e6-46fb-9da6-fe70dbe3a01f rw quiet splash apparmor=1
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: Acer product: Swift SF314-58 v: V1.03 serial: <filter>
Mobo: CM model: Strongbow_CM v: V1.03 serial: <filter> UEFI: Insyde v: 1.03
date: 09/11/2019
ID-1: BAT0 charge: 39.6 Wh (100.0%) condition: 39.6/47.8 Wh (82.9%)
volts: 12.2 min: 11.2 model: LGC KT0030G020 type: Li-ion serial: <filter>
status: Not charging
Info: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: EA cache: L2: 6 MiB
bogomips: 33615
Speed: 900 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 900 8: 900
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Acer Incorporated ALI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-7:6
chip-ID: 04f2:b5c5 class-ID: 0e02 serial: <filter>
Display: wayland server: X.Org 1.21.1.2 compositor: gnome-shell driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3")
s-diag: 1055mm (41.6")
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 60 dpi: 157
size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
Monitor-2: XWAYLAND1 res: 1920x1080 hz: 60 dpi: 81
size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Acer Incorporated ALI
driver: sof-audio-pci alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF-ID-1: br-09dd24c538f9 state: down mac: <filter>
IF-ID-2: br-dd491e6c3770 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: vethffeaeb7 state: up speed: 10000 Mbps duplex: full mac: <filter>
bus-ID: 1-10:7 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 238.47 GiB used: 40.44 GiB (17.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM256GDJTNG-8310A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: 80002C00 temp: 28.9 C scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 40.39 GiB (41.3%)
fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
used: 52.5 MiB (54.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 41.0 C mobo: 30.0 C
Processes: 287 Uptime: 37m wakeups: 1 Memory: 19.39 GiB
used: 3.33 GiB (17.2%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: 1226 pacman: 1222 lib: 309 flatpak: 0
snap: 4 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
