Whenever I try to browse reddit, page elements load messy and I can only scroll for 4-5 posts.
I’m running firefox 84.0.2 on Manjaro Linux KDE (did the latest stable update).
I tried deleting the cache, it works half of the time and only for a single session, then things go back to their broken state. I’ve tried ‘safe mode’ as well, but things didn’t change at all…
Also I tried to post something (actually this very topic) but I can’t either. So it’s pretty unusable!
Anyone has an idea what other thing(s) I could try to fix this?
Works fine for me. Do you have enough of RAM?
Show inxi -Fazym
Greggex
January 20, 2021, 9:53pm
#3
I don’t usually use FF for Reddit. But just tried it and it seems fine. Are you sure that FF is the problem - the Reddit site seems to be a bit flaky lately.
exo
January 20, 2021, 10:14pm
#4
Are you running some extensions that interact with the web page?
Make sure Javascript is NOT disabled in your browser.
That’s extremely weird, have you tried using the ‘old’ reddit?
Really sounds like you’ve got to have some jank extentions or something making a mess.
Yeah but then safe mode with extensions disabled should have corrected the bug, ain’t it?
Sure thing, here it is. But if 16Gb of RAM + Swap can’t handle reddit…
Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=c9136c9f-47f5-4078-8d4c-af348b4a9581 rw quiet udev.log_priority=3
threadirqs resume=/dev/disk/by-uuid/c9136c9f-47f5-4078-8d4c-af348b4a9581
resume_offset=1169408
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 24295F3 v: ThinkPad T530
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 24295F3 serial: <filter> UEFI [Legacy]: LENOVO
v: G4ET93WW (2.53 ) date: 02/22/2013
ID-1: BAT0 charge: 38.0 Wh condition: 73.9/86.6 Wh (85%) volts: 11.3/11.1
model: LGC 45N1011 type: Li-ion serial: <filter> status: Discharging
RAM: total: 15.34 GiB used: 1.98 GiB (12.9%)
Info: Quad Core model: Intel Core i7-3840QM bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 8 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44719
Speed: 1197 MHz min/max: 1200/3800 MHz Core speeds (MHz): 1: 1197 2: 1248
3: 1699 4: 1339 5: 1443 6: 1470 7: 1359 8: 1409
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0166
Device-2: Acer ThinkPad Integrated Camera type: USB driver: uvcvideo
bus ID: 1-1.6:6 chip ID: 5986:02d2
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: LVDS1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.3.3 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.10.7-3-MANJARO
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
v: kernel port: 5080 bus ID: 00:19.0 chip ID: 8086:1502
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel port: efa0 bus ID: 03:00.0 chip ID: 8086:0085
Device-3: Ericsson Business Mobile Networks BV H5321 gw Mobile Broadband
Module
type: USB driver: cdc_acm,cdc_mbim,cdc_wdm bus ID: 3-4:2 chip ID: 0bdb:1926
serial: <filter>
IF: wwp0s20u4i6 state: down mac: <filter>
Local Storage: total: 489.05 GiB used: 143.58 GiB (29.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT525MX300SSD1
size: 489.05 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: R060
ID-1: / raw size: 100 GiB size: 97.93 GiB (97.93%) used: 25.56 GiB (26.1%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
ID-2: /home raw size: 375.19 GiB size: 294.29 GiB (78.44%)
used: 118.02 GiB (40.1%) fs: ext4 dev: /dev/sda6 maj-min: 8:6
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 46.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 0
Processes: 276 Uptime: 1m wakeups: 1 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1458 lib: 479 Shell: Bash v: 5.1.0
running in: konsole inxi: 3.2.02
I’m adding this screenshot. We can see that the scroll bar on the right is at its bottom, a post with the image not loading and the last post cut in half.
@Greggex it works just fine in chromium, so I suppose it’s FF related, but it might be something else…
@exo how can I check if Javascript is disabled? I didn’t purposely deactivated it, but who knows?
Uncheck these, save. You’d think reddit couldn’t be more cancer, but with the ‘new’ bloated site they certainly managed it.
Second this.
Revert back to old design and install “Reddit Enhancement Suite” extension for better experience. It takes some time to get used to but it is so much better than the new design.
Mmh, I can’t even access my settings on ff, and in chromium the only beta-related option is already unchecked…
https://www.reddit.com/settings
Check " Opt out of the redesign"
Btw new design seems to work fine for me.
Ben
February 18, 2021, 5:46am
#14
Close Firefox, rename it’s folder (use Dolphin or do mv .mozilla mozilla
) and restart Firefox.
nam1962
February 18, 2021, 7:46am
#15
Well, on such a matter, always first list the add-ons:
grep -oP '},"name":"\K[^"]+' ~/.mozilla/firefox/*.*default*/addons.json
