I think legacy_boot flag could be set when you boot in legacy BIOS mode. Could be a sign you mixed BIOS and UEFI somehow.
When i use the pamac install gparted
command i get Error: target not found: gparted
It is KDE? right? Then just type sudo kparted
and enter. It start. (or gparted)
Still getting the same error
That is bad… I believe any official ISO has gparted or kparted installed.
Update database:
sudo pacman -Sy
Install then:
sudo pacman -S gparted
It worked now i have gparted
I changed the flags using gparted and reinstalled grub and i am able to boot manjaro but when i boot i get
/dev/sda5: clean, 244000/16384000 files, 1989978/6553600 blocks
And than a black screen
It looks like it first uses the nonfree drivers and than it blinks and shows the same text again but with free drivers and than a black screen
