I have recently succesfully installed manjaro alongside windows 10 on my computer using the [root tip] Dual boot Manjaro and Windows tutorial on this forum
but after restarting my computer i cant get into manjaro and get back in windows.
I am trying to get the option to choose between manjaro and windows when i bootup.
Can you check the UEFI Bios settings ?
How can i check that i am kinda new to this
After starting the PC you have to type fast F2 or F10 or DEL. It really depends on your UEFI and Mainboard. Then you can access it.
What do i need to check?
The boot order/priority of your entries.
In my bios manjaro doesnt show up but it does when i go in the live usb version and use the efibootmgr command
Then please show the output:
efibootmgr -v
Sorry for the late reaction
BootCurrent: 0003
Timeout: 1 seconds
BootOrder: 0000,0002,0003,0001
Boot0000* Windows Boot Manager HD(2,GPT,e8db5088-5cdb-4357-adc9-35813449ef38,0x109
000,0x31800)/File(\EFI\MANJARO\GRUBX64.EFI)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.
{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...a....
Boot0001* manjaro VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0002* Windows Boot Manager HD(2,GPT,e8db5088-5cdb-4357-adc9-35813449ef38,0x109
000,0x31800)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)..BO
Boot0003* UEFI: Generic Flash Disk 8.07 PciRoot(0x0)/Pci(0x14,0x0)/USB(7,0)/CDROM(1
,0x499028,0x8000)..BO
Well, I never saw such an entry with “VenHw”, but the entry is wrong. That could be a bug of your UEFI somehow or it is a bug of efibootmgr
Try to create the entry yourself with efibootmgr
? Since i have no details about your system, I give you an example:
sudo efibootmgr --create --disk /dev/nvme0n1 --part 1 --loader "\EFI\Manjaro\grubx64.efi" --label "manjaro"
You can delete an entry with:
sudo efibootmgr --delete-bootnum 0001
I used the command to create a entry and set the disk to the efi partition /dev/sda3, but when i rebooted i was in windows again and efibootmgr -v now shows this
BootCurrent: 0003
Timeout: 1 seconds
BootOrder: 0000,0002,0003,0004,0001
Boot0000* Windows Boot Manager HD(2,GPT,e8db5088-5cdb-4357-adc9-35813449ef38,0x109000,0x
31800)/File(\EFI\MANJARO\GRUBX64.EFI)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.
6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...a................
Boot0002* Windows Boot Manager HD(2,GPT,e8db5088-5cdb-4357-adc9-35813449ef38,0x109000,0x
Boot0003* UEFI: Generic Flash Disk 8.07 PciRoot(0x0)/Pci(0x14,0x0)/USB(7,0)/CDROM(1,0x499
028,0x8000)..BO
Boot0004* manjaro VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
and when i use the sudo efibootmgr --delete-bootnum 0001
command i get You must specify an entry to delete (see the -b option).
ok it is a bug.
- Update your UEFI to the latest one.
sudo efibootmgr --delete-bootnum --bootnum 0001
Delete all entries of manjaro and recreate them. This have to be done inmanjaro-chroot -a
and keep sure efivarfs is loaded:ls /sys/firmware/efi
and the efi partition is mountedls /boot/efi
. - If that does not help, then file an issue on: GitHub - rhboot/efibootmgr: efibootmgr development tree . Note your UEFI, your verbose entries and the version of efibootmgr.
I think your system is installed aa a BIOS/GPT system.
While the following is not quite an answer to your issue - it may give you a pointer in the right direction Manjaro is installed, bios recognize harddrive, harddrive first in boot order, boots to windows anyway
\WINDOWS\system32\winload.efi means i have a UEFI system right?
Can you give more detail on step 2 i dont really know what i need to do
Model: ATA ST2000DM008-2FR1 (scsi)
Disk /dev/sda: 2000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 17.4kB 16.8MB 16.8MB Microsoft reserved partition msftres
2 16.8MB 1786GB 1786GB ntfs Basic data partition msftdata
3 1786GB 1786GB 537MB fat32 legacy_boot, msftdata
4 1786GB 1790GB 4295MB linux-swap(v1) swap, legacy_boot
5 1790GB 1817GB 26.8GB ext4
6 1817GB 2000GB 183GB ext4
Model: ATA Samsung SSD 860 (scsi)
Disk /dev/sdb: 256GB
Disk Flags:
1 1049kB 556MB 555MB ntfs Basic data partition hidden, diag
2 556MB 660MB 104MB fat32 EFI system partition boot, esp
3 660MB 676MB 16.8MB Microsoft reserved partition msftres
4 676MB 256GB 255GB ntfs Basic data partition msftdata
Model: Generic Flash Disk (scsi)
Disk /dev/sdc: 31.9GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 2468MB 2473MB 4194kB primary esp
Here is a problem. The flag have to be boot, esp
(esp is just an alias for boot). Open gparted or kparted and change the flag and reinstall grub after entering manjaro-chroot -a
manjaro-chroot -a
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
grub-mkconfig -o /boot/grub/grub.cfg
Also remove these flags here: swap, legacy_boot
How do i get gparted?
And when i installed manjaro i gave the efi partition the boot flag and i gave the swap partition no flags, why does it say i have them now?
gparted or kparted should be installed by default on the Live ISO. If not:
pamac install gparted
No idea who or which program does this. It could be calamares somehow or Windows.
