Hi Manjaro community,
I’m having persistent issues adjusting screen brightness on my Lenovo laptop running Manjaro XFCE. The brightness keys don’t respond, and I’ve tried multiple solutions without success. Here’s my diagnostic information:
System Information:
Host: conatus Kernel: 5.15.185-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 15.1.1
Desktop: Xfce v: 4.20.1 Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 20366 v: Lenovo Z40-70
serial: <superuser required>
Mobo: LENOVO model: Lancer 4A5 v: 31900059WIN serial: <superuser required>
UEFI: LENOVO v: 9BCN91WW date: 07/21/2015
Info: dual core model: Intel Core i5-4210U bits: 64 type: MT MCP
arch: Haswell rev: 1 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 2394 min/max: 800/2700 cores: 1: 2394 2: 2394 3: 2394
4: 2394 bogomips: 19161
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-7.5 bus-ID: 00:02.0
Device-2: Syntek Lenovo EasyCamera driver: uvcvideo type: USB
bus-ID: 2-6:4
Display: x11 server: X.org v: 1.21.1.18 driver: X: loaded: modesetting
dri: crocus gpu: i915 resolution: 1: 1920x1080~60Hz 2: 1366x768~60Hz
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Info: Tools: de: kscreen-doctor,xfce4-display-settings x11: xprop,xrandr
Brightness Control Diagnostics
- Available backlight interfaces:
ls /sys/class/backlight/
intel_backlight
- Current brightness values:
cat /sys/class/backlight/intel_backlight/{brightness,max_brightness}
10
937
3 Manual brightness adjustment test:
# Attempt to increase brightness
echo 100 | sudo tee /sys/class/backlight/intel_backlight/brightness
100
# Verify change
cat /sys/class/backlight/intel_backlight/brightness
10
# But screen brightness doesn't actually change
- Installed brightness tools:
pacman -Q | grep -E 'xbacklight|brightnessctl|light'
brightnessctl 0.5.1-3
lightdm 1:1.32.0-6
lightdm-gtk-greeter 1:2.0.9-1
lightdm-gtk-greeter-settings 1.2.3-3
nano-syntax-highlighting 2022.11.02.r102.gbb94603-1
xorg-xbacklight 1.2.4-1
zsh-syntax-highlighting 0.8.0-1
Keypress detection test (output when pressing brightness keys):
xev | grep -A2 --line-buffered '^KeyRelease' | sed -n '/keycode /s/^.*keycode \([0-9]*\).* (.*, \(.*\)).*$/\1 \2/p'
233 XF86MonBrightnessUp # That's the key but it's not detected by xev
232 XF86MonBrightnessDown
What I’ve Tried
- Various udev rules for permissions
- Multiple tools (xbacklight, brightnessctl, manual sysfs writes)
- Different keyboard shortcut configurations in XFCE
- Checking for conflicting services
Current Behavior
- Brightness keys are detected (show in xev)
- Can write to brightness file but changes don’t affect actual display
- No error messages in journal/dmesg
Would appreciate any guidance on:
- Why sysfs changes don’t affect actual brightness
- How to properly debug the brightness control pipeline
- Any Lenovo-specific considerations
Note: I used Deepseek in order to help me fix this in MATE, but it just kept getting worse with script after script. So I’m back at XFCE. I tried to fall back to a default state but oh my, it felt like an unnecessary detour for such a “small” problem. The whole thing was like getting out of a toxic relationship (yes, I know I did that myself in the end ).
Thank you!
