Cant adjust KDE's animation speed
So I freshly installed Manjaro Kyria on my laptop. After install and boot it worked fine. Updated the system and now the desktop animations are too fast. I went to the compositor settings and found that the animation speed control slider is missing.
Image up above.
I tried every different setting there is, but to no avail. This worked fine in the live usb and directly after install. Please help.
That's a change brought in by Plasma 5.18 which you will have received during a post install update instead of Plasma 5.17 which was on the ISO, it's not a problem with your machine or a bug. Also, OpenGL 3.1 is better to use if your hardware supports it.
EDIT - It's been moved
Look in Workspace/Workspace Behaviour/General Behaviour/Animation speed
Many thanks!
I appreciate your effort!
