How can i solve this issue. I can’t use my printer. Canon MF4410
"File "/usr/lib/cups/filter/rastertoufr2" has insecure permissions (0100755/uid=1000/gid/1000)."
Moderator edit: Moved error from title to post and removed screenshot
Is there an actual error?
This looks more like a message, to let you know. A warning perhaps.
Provide context.
Did the printer ever work with Manjaro
or are you just in the process of setting it up
and due to this message you think this is what is holding you up?
I could use “cndrvcups-lb-bin” in past. And my printer worked but now this didnt work.
Reading this PKGBUILD and trying to understand it is above my skill level.
It looks pretty configurable though.
I have NO idea why it does not work anymore nor why it did work before.
The message you posted is a symptom at best - it’s not the reason why it fails.
The printer worked before.
