Canon Imageclass MF216N-Installation
Hi guys I'm posting a solution and how to install the drivers for the Canon Imageclass MF216N
  1. Make sure you enable AUR package by going to add and remove progams under preference enable AUR.
  2. Sudo pacman -S Yay so that you can install packages from AUR
  3. Yay Canon Imageclass
  4. choose cndrvcups-lb 3.70-1(+70 0.36%) it should be the first one
  5. There are two repository to choose from install it from #2
  6. At the end of the install it will say ERROR a failure occurred in build, error in making cndrvcups-common-lb
  7. Yay cndrvcups-common-lb and it will install this missing file
  8. You can add the printer from the local cups interface or from the print-settings. Print test page to confirm
