Cannot use Cinnamon Desktop Environment
I have been a happy user of Manjaro for about 12 months and I use the Cinnamon Desktop Environment. I have just re-installed Manjaro and followed the instructions at Install Desktop Environments #Cinnamon
but when I log out and back in or reboot I end up in the default Manjaro environment.
The lightdm.log doesn’t indicate any errors
Any ideas of where to look?
Just install the Cinnamon edition?
btw, there isn’t a ‘default Manjaro environment’, there are 3 different flagship editions plus the community editions
This might sound stupid on my behalf, have you checked if you can switch the DE in the login screen? After rebooting the choices is usually still set for the DE you had done the install from.
