Hi, when trying to upgrade yay-bin, I do get the following errors:
Preparing...
Cloning yay-bin build files...
Checking yay-bin dependencies...
Warning: removing pacman breaks dependency 'pacman>=5.2' required by alpm-octopi-utils
Add alpm-octopi-utils to remove
Warning: removing pacman breaks dependency 'pacman<5.3' required by alpm-octopi-utils
Warning: removing pacman breaks dependency 'pacman' required by appstream-glib
Add appstream-glib to remove
Warning: removing pacman breaks dependency 'pacman' required by expac
Add expac to remove
Warning: removing pacman breaks dependency 'pacman>=5.0' required by manjaro-system
Add manjaro-system to remove
Warning: removing pacman breaks dependency 'pacman' required by mhwd
Add mhwd to remove
Warning: removing pacman breaks dependency 'pacman>=5.2' required by octopi
Add octopi to remove
Warning: removing pacman breaks dependency 'pacman<5.3' required by octopi
Warning: removing pacman breaks dependency 'pacman>=5.2' required by packagekit
Add packagekit to remove
Warning: removing pacman breaks dependency 'pacman<5.3' required by packagekit
Warning: removing pacman breaks dependency 'pacman>=5.2' required by pamac-common
Add pamac-common to remove
Warning: removing pacman breaks dependency 'pacman<5.3' required by pamac-common
Warning: removing pacman breaks dependency 'pacman' required by pkgfile
Add pkgfile to remove
Warning: removing pacman breaks dependency 'pacman' required by pyalpm
Add pyalpm to remove
Failed to prepare transaction:
could not satisfy dependencies:
- removing appstream-glib breaks dependency 'appstream-glib' required by flatpak,
- if possible, remove flatpak and retry
- removing pkgfile breaks dependency 'pkgfile' required by manjaro-zsh-config,
- if possible, remove manjaro-zsh-config and retry
- removing pyalpm breaks dependency 'pyalpm' required by namcap,
- if possible, remove namcap and retry
- removing packagekit breaks dependency 'packagekit' required by packagekit-qt5,
- if possible, remove packagekit-qt5 and retry
- removing pamac-common breaks dependency 'pamac-common=10.0.6-2' required by pamac-cli,
- if possible, remove pamac-cli and retry
Also I cannot just remove it since these modules depend on it. Any idea what to do?
