dmt
14 June 2021 13:38
21
Looks like there’s a file that doesn’t match the expression, ie name
instead of name-0
, therefore an empty list is returned.
From re module docs:
The sequence
prog = re.compile(pattern)
result = prog.match(string)
is equivalent to
result = re.match(pattern, string)
It’s faster for lots of checks, works with findall too.
So if the expression is something like this '^(.*?)(-?)[0-9]'
could it work then??
dmt
14 June 2021 14:40
23
I don’t think it’s robust enough, not without knowing the filenames.
It fails with files which don’t have a version number, but I’m not sure if that matters. If there’s another delimiter it may not work. If neither of those are the case (as it should be) the expression in the script should work.
@Baris ls /var/lib/pacman/local
Baris
14 June 2021 14:43
24
[baris@Samanyolu ~]$ ls /var/lib/pacman/local
a52dec-0.7.4-11 kwayland-5.80.0-1 nodejs-15.11.0-1
aalib-1.4rc5-14 kwayland-5.81.0-1 noto-fonts-20201226-1
accounts-qml-module-0.7-3 kwayland-5.82.0-1 noto-fonts-20201226-2
accountsservice-0.6.55-3 kwayland-integration-5.21.3-1 noto-fonts-cjk-20201206-1
acl-2.3.1-1 kwayland-integration-5.21.4-1 noto-fonts-compat-20151217-1
acpi-1.7-3 kwayland-integration-5.21.5-1 noto-fonts-emoji-20200916-1
acpid-2.0.32-2 kwayland-server-5.21.3-1 npth-1.6-3
adobe-source-code-pro-fonts-2.038ro+1.058it+1.018var-1 kwayland-server-5.21.4-1 nspr-4.29-1
adobe-source-han-sans-cn-fonts-2.002-2 kwayland-server-5.21.5-1 nspr-4.30-1
adobe-source-han-sans-cn-fonts-2.003-1 kwidgetsaddons-5.80.0-1 nspr-4.31-1
adobe-source-han-sans-jp-fonts-2.003-1 kwidgetsaddons-5.81.0-1 nss-3.62-1
adobe-source-han-sans-kr-fonts-2.003-1 kwidgetsaddons-5.82.0-1 nss-3.63-1
adobe-source-sans-pro-fonts-3.028-1 kwin-5.21.3-1 nss-3.64-1
adwaita-icon-theme-40.1.1-1 kwin-5.21.4-1 nss-3.66-1
adwaita-icon-theme-40rc-1 kwin-5.21.5-1 nss-mdns-0.14.1-3
albert-0.17.2-1 kwindowsystem-5.81.0-1 ntfs-3g-2017.3.23-5
alembic-1.7.16-1 kwindowsystem-5.82.0-1 ntp-4.2.8.p15-1
ALPM_DB_VERSION kwrited-5.21.3-1 numactl-2.0.14-1
alsa-card-profiles-1:0.3.28-1 kwrited-5.21.4-1 numlockx-1.2-5
alsa-firmware-1.2.4-2 kwrited-5.21.5-1 nvidia-450xx-utils-450.80.02-1
alsa-lib-1.2.4-3 kxmlgui-5.80.0-1 oath-toolkit-2.6.6-1
alsa-oss-1.1.8-3 kxmlgui-5.81.0-1 oath-toolkit-2.6.6-2
alsa-plugins-1:1.2.2-2 kxmlgui-5.82.0-1 oath-toolkit-2.6.7-1
alsa-topology-conf-1.2.4-2 lame-3.100-3 obs-studio-26.1.2-2
alsa-ucm-conf-1.2.4-2 lapack-3.9.0-3 ocl-icd-2.2.14-1
alsa-utils-1.2.4-2 latte-dock-0.9.11-1 okular-20.12.3-1
android-tools-31.0.0-3 lcms2-2.12-1 okular-21.04.0-1
android-udev-20210501-1 ldb-1:2.2.0-3 okular-21.04.1-1
aom-3.1.0-1 ldb-1:2.3.0-1 onboard-1.4.1-6
apparmor-3.0.1-3 ldc-2:1.25.1-1 openal-1.21.1-1
appimagelauncher-2.2.0-5 ldns-1.7.1-2 opencl-headers-2:2020.12.18-1
appstream-0.14.3-1 less-1:563-1 opencl-nvidia-460.56-2
appstream-glib-0.7.18-2 less-1:581.2-1 opencollada-1:1.6.68-2
appstream-qt-0.14.3-1 less-563-1 opencolorio1-1.1.1-2
archlinux-appstream-data-20210218-1 lib32-aalib-1.4rc5-2 openconnect-1:8.10-1
archlinux-appstream-data-20210321-1 lib32-alsa-lib-1.2.4-2 opencore-amr-0.1.5-5
archlinux-appstream-data-20210423-1 lib32-alsa-plugins-1.2.2-1 opencv-4.5.1-1
archlinux-keyring-20210110-1 lib32-atk-2.36.0-2 openexr-2.5.5-1
argon2-20190702-3 lib32-at-spi2-atk-2.38.0-1 openexr-3.0.1-2
aria2-1.35.0-2 lib32-at-spi2-core-2.38.0-1 openexr-3.0.3-1
aribb24-1.0.3-3 lib32-brotli-1.0.9-1 openimagedenoise-1.3.0-1
ark-21.04.1-1 lib32-bzip2-1.0.8-2 openimageio-2.2.12.0-1
asciidoc-9.1.0-1 lib32-cairo-1.17.4-5 openjpeg2-2.4.0-1
aspell-0.60.8-2 lib32-cdparanoia-10.2-3 openmpi-4.0.5-2
aspell-en-2020.12.07-1 lib32-celt-0.11.3-4 openmpi-4.0.5-3
atk-2.36.0-1 lib32-colord-1.4.5-2 openresolv-3.12.0-1
atkmm-2.28.1-1 lib32-curl-7.75.0-1 openshadinglanguage-1.11.12.0-1
at-spi2-atk-2.38.0-1 lib32-curl-7.76.1-1 openssh-8.5p1-1
at-spi2-core-2.40.1-1 lib32-curl-7.77.0-1 openssh-8.6p1-1
attica-5.82.0-1 lib32-dbus-1.12.20-1 openssl-1.1.1.j-1
attr-2.5.1-1 lib32-dconf-0.38.0-1 openssl-1.1.1.k-1
audiofile-0.3.6-6 lib32-e2fsprogs-1.46.2-2 opensubdiv-3.4.3-5
audit-3.0.1-1 lib32-expat-2.2.10-1 openvdb-8.0.1-1
autoconf-2.71-1 lib32-expat-2.3.0-2 openvpn-2.5.1-1
automake-1.16.3-1 lib32-expat-2.4.1-1 openvpn-2.5.2-1
avahi-0.8+15+ge8a3dd0-3 lib32-flac-1.3.3-1 openxr-1.0.14-1
avahi-0.8+20+gd1e71b3-1 lib32-fontconfig-2:2.13.91+48+gfcb0420-2 opus-1.3.1-2
b43-fwcutter-019-3 lib32-freetype2-2.10.4-1 orc-0.4.32-1
baloo-5.82.0-1 lib32-fribidi-1.0.10-1 osinfo-db-20210426-1
baloo-widgets-21.04.1-1 lib32-gcc-libs-10.2.0-6 os-prober-1.78-0.1
bash-5.1.008-3 lib32-gcc-libs-11.1.0-1 ostree-2020.8-1
bashrc-manjaro-5.1.008-3 lib32-gdk-pixbuf2-2.42.2-1 ostree-2021.2-1
bc-1.07.1-4 lib32-giflib-5.2.1-1 oxygen-5.21.3-1
binutils-2.36.1-2 lib32-glew-2.2.0-1 oxygen-5.21.4-1
bison-3.7.6-1 lib32-glib2-2.66.7-1 oxygen-5.21.5-1
blas-3.9.0-3 lib32-glibc-2.33-4 oxygen-icons-1:5.80.0-1
blender-17:2.92.0-7 lib32-glibc-2.33-5 oxygen-icons-1:5.81.0-1
blosc-1.21.0-1 lib32-glib-networking-2.66.0-1 oxygen-icons-1:5.82.0-1
bluedevil-1:5.21.5-1 lib32-glu-9.0.1-1 p11-kit-0.23.22-1
bluez-5.58-1 lib32-gmp-6.2.1-1 p7zip-1:17.03-1
bluez-libs-5.58-1 lib32-gnutls-3.7.1-1 p7zip-1:17.04-1
bluez-qt-5.82.0-1 lib32-gpm-1.20.7-2 p7zip-17.03-2
boost-libs-1.75.0-3 lib32-gst-plugins-base-1.18.3-1 pacman-5.2.2-4
botan-2.18.0-1 lib32-gst-plugins-base-libs-1.18.3-1 pacman-5.2.2-5
botan-2.18.1-1 lib32-gst-plugins-good-1.18.3-1 pacman-5.2.2-6
box2d-2.4.1-1 lib32-gstreamer-1.18.3-1 pacman-mirrors-4.19.5-2
brave-1.25.68-1 lib32-gtk3-3.24.27-2 pacman-mirrors-4.21.0-1
breath2-icon-themes-1.0.10-3 lib32-harfbuzz-2.8.0-1 pacman-mirrors-4.21.3-2
breath2-icon-themes-1.0.11-1 lib32-icu-68.2-1 pam-1.5.1-1
breath2-icon-themes-1.0.13-1 lib32-icu-69.1-1 pamac-cli-10.0.5-1
breath2-wallpaper-1.0.10-2 lib32-imlib2-1.7.1-1 pamac-cli-10.0.6-2
breath2-wallpaper-1.0.11-1 lib32-jack2-1.9.17-1 pamac-common-10.0.5-1
breath2-wallpaper-1.0.13-1 lib32-json-glib-1.6.2-1 pamac-common-10.0.6-2
breeze-5.21.3-1 lib32-keyutils-1.6.3-1 pamac-flatpak-plugin-10.0.5-1
breeze-5.21.4-1 lib32-krb5-1.18.3-1 pamac-flatpak-plugin-10.0.6-2
breeze-5.21.5-1 lib32-krb5-1.19.1-1 pamac-gtk-10.0.5-1
breeze-icons-5.80.0-1 lib32-lcms2-2.12-1 pamac-gtk-10.0.6-2
breeze-icons-5.81.0-1 lib32-libasyncns-0.8+3+g68cd5af-2 pamac-snap-plugin-10.0.5-1
breeze-icons-5.82.0-1 lib32-libavc1394-0.5.4-2 pamac-snap-plugin-10.0.6-2
brotli-1.0.9-4 lib32-libcaca-0.99.beta19-2 pamac-tray-icon-plasma-0.1.2-4
btrfs-progs-5.11-1 lib32-libcanberra-0.30+2+gc0620e4-3 pambase-20200721.1-2
btrfs-progs-5.11.1-1 lib32-libcanberra-gstreamer-0.30+2+gc0620e4-3 pango-1:1.48.3-1
btrfs-progs-5.12.1-1 lib32-libcanberra-pulse-0.30+2+gc0620e4-3 pango-1:1.48.4-1
bubblewrap-0.4.1-1 lib32-libcap-2.49-1 pango-1:1.48.5-1
bubblewrap-0.4.1-2 lib32-libcap-2.50-1 pangomm-2.46.0-1
bzip2-1.0.8-4 lib32-libcups-2.3.3-1 paprefs-1.1-2
ca-certificates-20181109-4 lib32-libdatrie-0.2.13-1 parted-3.4-2
ca-certificates-mozilla-3.62-1 lib32-libdrm-2.4.104-1 partitionmanager-20.12.3-1
ca-certificates-mozilla-3.63-1 lib32-libdrm-2.4.105-1 partitionmanager-21.04.0-1
ca-certificates-mozilla-3.64-1 lib32-libdrm-2.4.106-1 partitionmanager-21.04.1-1
ca-certificates-mozilla-3.66-1 lib32-libdv-1.0.0-5 pasystray-0.7.1-2
ca-certificates-utils-20181109-4 lib32-libelf-0.183-3 patch-2.7.6-8
cairo-1.17.4-5 lib32-libelf-0.184-1 pavucontrol-1:4.0-2
cairomm-1.12.2-4 lib32-libepoxy-1.5.5-1 pciutils-3.7.0-1
calf-0.90.3-4 lib32-libffi-3.3-2 pcre2-10.36-1
cantarell-fonts-1:0.301-1 lib32-libgcrypt-1.9.2-1 pcre2-10.37-1
cantata-2.4.2-1 lib32-libgcrypt-1.9.3-1 pcre-8.44-1
c-ares-1.17.1-1 lib32-libglvnd-1.3.2-1 pcsclite-1.9.1-1
cblas-3.9.0-3 lib32-libglvnd-1.3.3-1 pepper-flash-32.0.0.465-1
cdparanoia-10.2-8 lib32-libgpg-error-1.41-1 perl-5.32.1-1
cdrdao-1.2.4-2 lib32-libgpg-error-1.42-1 perl-5.34.0-1
cdrtools-3.02a09-4 lib32-libgudev-234-1 perl-alien-build-2.38-1
celt-0.11.3-4 lib32-libgusb-0.3.6-1 perl-alien-build-2.40-3
ceph-libs-15.2.10-1 lib32-libice-1.0.10-1 perl-alien-libxml2-0.17-1
ceph-libs-15.2.12-1 lib32-libid3tag-0.15.1b-2 perl-alien-libxml2-0.17-2
ceph-libs-15.2.8-2 lib32-libidn2-2.3.0-1 perl-capture-tiny-0.48-4
cfitsio-1:3.49-1 lib32-libidn2-2.3.1-1 perl-capture-tiny-0.48-5
chromaprint-1.5.0-3 lib32-libiec61883-1.2.0-2 perl-clone-0.45-2
cifs-utils-6.12-1 lib32-libjpeg-turbo-2.0.6-1 perl-clone-0.45-3
cifs-utils-6.13-2 lib32-libldap-2.4.57-1 perl-dbi-1.643-2
cinnamon-desktop-4.8.1-1 lib32-libldap-2.4.58-1 perl-dbi-1.643-3
ckbcomp-1.194-1 lib32-libltdl-2.4.6+42+gb88cebd5-1 perl-encode-locale-1.05-7
clang-11.1.0-1 lib32-libnsl-1.3.0-1 perl-encode-locale-1.05-8
colord-1.4.5-1 lib32-libnsl-1.3.0-2 perl-error-0.17029-2
colord-sane-1.4.5-1 lib32-libogg-1.3.4-2 perl-error-0.17029-3
compiler-rt-11.1.0-1 lib32-libpciaccess-0.16-1 perl-ffi-checklib-0.27-2
confuse-3.3-3 lib32-libpng-1.6.37-3 perl-ffi-checklib-0.28-2
convertlit-1.8-10 lib32-libproxy-0.4.17-1 perl-file-basedir-0.08-5
coreutils-8.32-1 lib32-libpsl-0.21.1-1 perl-file-basedir-0.08-6
cpupower-5.11-1 lib32-libpulse-14.2-2 perl-file-chdir-0.1011-4
cpupower-5.12-1 lib32-libraw1394-2.1.2-2 perl-file-desktopentry-0.22-7
crda-4.14-3 lib32-librsvg-2.50.3-1 perl-file-desktopentry-0.22-8
crda-4.14-4 lib32-libshout-2.4.5-1 perl-file-listing-6.14-1
cronie-1.5.5-2 lib32-libsm-1.2.3-1 perl-file-listing-6.14-2
cronie-1.5.6-1 lib32-libsndfile-1.0.31-1 perl-file-mimeinfo-0.30-1
cronie-1.5.7-2 lib32-libsoup-2.72.0-1 perl-file-mimeinfo-0.30-2
cryptsetup-2.3.5-1 lib32-libssh2-1.9.0-1 perl-file-which-1.23-4
cryptsetup-2.3.5-4 lib32-libtasn1-4.16.0-2 perl-file-which-1.24-1
cryptsetup-2.3.6-1 lib32-libthai-0.1.28-1 perl-file-which-1.24-2
cuda-11.2.1-4 lib32-libtheora-1.1.1-12 perl-html-parser-3.76-1
cups-1:2.3.3op2-1 lib32-libtiff-4.2.0-1 perl-html-parser-3.76-2
cups-1:2.3.3op2-3 lib32-libtirpc-1.3.1-1 perl-html-tagset-3.20-10
cups-filters-1.28.7-1 lib32-libunistring-0.9.10-1 perl-html-tagset-3.20-11
cups-filters-1.28.8-1 lib32-libunwind-1.5.0-1 perl-http-cookies-6.10-1
cups-pdf-3.0.1-5 lib32-libusb-1.0.24-1 perl-http-cookies-6.10-2
cups-pdf-3.0.1-6 lib32-libva-2.10.0-1 perl-http-daemon-6.06-2
cups-pk-helper-0.2.6-4 lib32-libva-2.11.0-1 perl-http-daemon-6.06-3
curl-7.75.0-1 lib32-libva-intel-driver-2.4.1-1 perl-http-date-6.05-3
curl-7.76.1-1 lib32-libva-mesa-driver-20.3.4-3 perl-http-date-6.05-4
curl-7.77.0-1 lib32-libva-mesa-driver-21.0.1-1 perl-http-message-6.29-1
dav1d-0.8.2-1 lib32-libva-mesa-driver-21.0.3-3 perl-http-message-6.32-2
dav1d-0.9.0-1 lib32-libva-mesa-driver-21.1.2-0 perl-http-negotiate-6.01-8
db-5.3.28-5 lib32-libva-vdpau-driver-0.7.4-6 perl-http-negotiate-6.01-9
dbus-1.12.20-1 lib32-libvdpau-1.4-1 perl-io-html-1.004-1
dbus-glib-0.110-2 lib32-libvisual-0.4.0-6 perl-io-html-1.004-2
dbus-glib-0.112-1 lib32-libvorbis-1.3.7-1 perl-ipc-system-simple-1.30-2
dbus-python-1.2.16-4 lib32-libvpx-1.9.0-1 perl-ipc-system-simple-1.30-3
dcd-1:0.13.1-1 lib32-libwebp-1.2.0-1 perl-libwww-6.53-1
dconf-0.40.0-1 lib32-libx11-1.7.0-1 perl-libwww-6.54-2
ddcutil-1.0.1-1 lib32-libx11-1.7.1-1 perl-lwp-mediatypes-6.02-8
ddcutil-1.1.0-1 lib32-libxau-1.0.9-1 perl-lwp-mediatypes-6.02-9
desktop-file-utils-0.26-1 lib32-libxcb-1.14-1 perl-mailtools-2.21-4
device-mapper-2.03.11-5 lib32-libxcomposite-0.4.5-1 perl-mailtools-2.21-5
device-mapper-2.03.12-1 lib32-libxcrypt-4.4.18-1 perl-net-http-6.20-1
dfmt-0.13.2-2 lib32-libxcrypt-4.4.19-1 perl-net-http-6.21-1
dhclient-4.4.2-2 lib32-libxcrypt-4.4.20-1 perl-net-http-6.21-2
dhclient-4.4.2.P1-1 lib32-libxcursor-1.2.0-1 perl-parse-yapp-1.21-3
dhcpcd-9.4.0-1 lib32-libxdamage-1.1.5-1 perl-parse-yapp-1.21-4
diffutils-3.7-3 lib32-libxdmcp-1.1.3-1 perl-path-tiny-0.118-1
ding-libs-0.6.1-3 lib32-libxext-1.3.4-1 perl-path-tiny-0.118-2
discord-0.0.15-1 lib32-libxfixes-5.0.3-2 perl-timedate-2.33-2
discount-2.2.7-1 lib32-libxft-2.3.3-1 perl-timedate-2.33-3
djvulibre-3.5.28-2 lib32-libxi-1.7.10-2 perl-try-tiny-0.30-5
djvulibre-3.5.28-3 lib32-libxinerama-1.1.4-1 perl-try-tiny-0.30-6
dmd-1:2.095.1-1 lib32-libxkbcommon-1.1.0-1 perl-uri-5.09-1
dmd-docs-1:2.095.1-1 lib32-libxml2-2.9.10-3 perl-uri-5.09-2
dmidecode-3.3-1 lib32-libxml2-2.9.10-4 perl-www-robotrules-6.02-8
dmraid-1.0.0.rc16.3-13 lib32-libxmu-1.1.3-1 perl-www-robotrules-6.02-9
dnsmasq-2.84-1 lib32-libxrandr-1.5.2-1 perl-xml-libxml-2.0206-1
dnsmasq-2.85-1 lib32-libxrender-0.9.10-2 perl-xml-libxml-2.0207-1
dnssec-anchors-20190629-3 lib32-libxshmfence-1.3-2 perl-xml-libxml-2.0207-2
docbook-xml-4.5-9 lib32-libxss-1.2.3-1 perl-xml-namespacesupport-1.12-4
docbook-xsl-1.79.2-7 lib32-libxt-1.2.1-1 perl-xml-parser-2.46-2
dolphin-21.04.1-1 lib32-libxtst-1.2.3-2 perl-xml-parser-2.46-3
dolphin-plugins-20.12.3-1 lib32-libxv-1.0.11-2 perl-xml-sax-1.02-1
dolphin-plugins-21.04.0-1 lib32-libxxf86vm-1.1.4-2 perl-xml-sax-base-1.09-4
dolphin-plugins-21.04.1-1 lib32-llvm-libs-11.1.0-1 perl-xml-writer-0.625-6
dosfstools-4.2-1 lib32-lm_sensors-1:3.6.0.r41.g31d1f125-1 perl-xml-writer-0.625-7
dotconf-1.3-6 lib32-mesa-20.3.4-3 phodav-2.5-1
double-conversion-3.1.5-2 lib32-mesa-21.0.1-1 phonon-qt5-4.11.1-2
dscanner-0.11.0-1 lib32-mesa-21.0.3-3 phonon-qt5-gstreamer-4.10.0-2
dtools-2.095.1-1 lib32-mesa-21.1.2-0 pinentry-1.1.0-5
dub-1.24.1-1 lib32-mesa-demos-8.4.0-2 pinentry-1.1.1-1
dvdauthor-0.7.2-10 lib32-mesa-vdpau-20.3.4-3 pipewire-1:0.3.23-1
dvd+rw-tools-7.1-9 lib32-mpg123-1.26.4-1 pipewire-1:0.3.24-1
dvgrab-3.5-9 lib32-ncurses-6.2-1 pipewire-1:0.3.26-1
e2fsprogs-1.46.2-1 lib32-nettle-3.7.1-1 pipewire-1:0.3.28-1
ebook-tools-0.2.2-7 lib32-nspr-4.30-1 pipewire-media-session-1:0.3.23-1
ecryptfs-utils-111-4 lib32-nspr-4.31-1 pipewire-pulse-1:0.3.23-1
editorconfig-core-c-0.12.4-1 lib32-nss-3.63-1 pixman-0.40.0-1
efibootmgr-17-2 lib32-nss-3.64-1 pkcs11-helper-1.27.0-1
efivar-37-4 lib32-nss-3.66-1 pkgconf-1.7.3-1
electron-12.0.6-1 lib32-openssl-1:1.1.1.j-1 pkgfile-21-2
elfutils-0.183-3 lib32-openssl-1:1.1.1.k-1 plasma5-themes-breath2-1.0.10-2
embree-3.12.2-1 lib32-opus-1.3.1-1 plasma5-themes-breath2-1.0.11-1
emovix-0.9.0-8 lib32-orc-0.4.32-1 plasma5-themes-breath2-1.0.13-1
enchant-2.2.15-1 lib32-p11-kit-0.23.22-1 plasma-desktop-5.21.3-1
enchant-2.2.15-2 lib32-pam-1.5.1-1 plasma-desktop-5.21.4-1
etcher-1.5.119-1 lib32-pango-1:1.48.3-1 plasma-desktop-5.21.5-1
exempi-2.5.2-1 lib32-pcre-8.44-1 plasma-framework-5.80.0-1
exfat-utils-1.3.0-2 lib32-pixman-0.40.0-1 plasma-framework-5.81.0-1
exiv2-0.27.3-1 lib32-polkit-0.118-1 plasma-framework-5.82.0-1
expat-2.2.10-2 lib32-popt-1.18-1 plasma-integration-5.21.3-1
expat-2.3.0-1 lib32-readline-8.1.001-1 plasma-integration-5.21.4-1
expat-2.4.1-1 lib32-readline-8.1.0-2 plasma-integration-5.21.5-1
f2fs-tools-1.14.0-1 lib32-rest-0.8.1-3 plasma-nm-5.21.3-1
faac-1.30-2 lib32-speex-1.2.0-2 plasma-nm-5.21.4-1
faad2-2.10.0-1 lib32-speexdsp-1.2.0-1 plasma-nm-5.21.5-1
fakeroot-1.25.3-2 lib32-sqlite-3.34.1-1 plasma-pa-5.21.3-1
ffmpeg-2:4.3.2-2 lib32-sqlite-3.35.4-1 plasma-pa-5.21.4-1
ffmpeg-2:4.3.2-5 lib32-sqlite-3.35.5-1 plasma-pa-5.21.5-1
ffmpeg-2:4.4-2 lib32-systemd-247.4-1 plasma-simplemenu-1.0.12-1
ffmpeg-2:4.4-3 lib32-systemd-247.6-1 plasma-systemmonitor-5.21.3-1
ffmpegthumbs-20.12.3-1 lib32-systemd-247.7-1 plasma-systemmonitor-5.21.4-1
ffmpegthumbs-21.04.0-1 lib32-taglib-1.12-1 plasma-systemmonitor-5.21.5-1
ffmpegthumbs-21.04.1-1 lib32-tdb-1.4.3-1 plasma-workspace-5.21.3-1
fftw-3.3.9-1 lib32-twolame-0.4.0-2 plasma-workspace-5.21.4-1
fig2dev-3.2.8-1 lib32-util-linux-2.36.2-1 plasma-workspace-5.21.5-1
file-5.39-1 lib32-v4l-utils-1.20.0-1 plasma-workspace-wallpapers-5.21.3-1
file-5.40-2 lib32-vulkan-icd-loader-1.2.172-1 plasma-workspace-wallpapers-5.21.4-1
file-5.40-5 lib32-vulkan-icd-loader-1.2.176-1 plasma-workspace-wallpapers-5.21.5-1
filelight-20.12.3-1 lib32-vulkan-intel-20.3.4-3 plotutils-2.6-10
filelight-21.04.0-1 lib32-vulkan-radeon-20.3.4-3 polkit-0.118-1
filelight-21.04.1-1 lib32-wavpack-5.4.0-1 polkit-kde-agent-5.21.3-1
filesystem-2021.01.19-1 lib32-wayland-1.19.0-1 polkit-kde-agent-5.21.4-1
findutils-4.8.0-1 lib32-xz-5.2.5-2 polkit-kde-agent-5.21.5-1
firefox-89.0-1 lib32-zlib-1.2.11-3 polkit-qt5-0.113.0-2
flac-1.3.3-2 lib32-zstd-1.4.9-1 poppler-21.03.0-1
flac-1.3.3-3 libaccounts-glib-1.25-3 poppler-21.04.0-2
flashrom-1.2-2 libaccounts-qt-1.16-2 poppler-21.05.0-1
flatpak-1.10.2-1 libaec-1.0.4-1 poppler-data-0.4.10-1
flatpak-1.11.1-1 libaio-0.3.112-2 poppler-glib-21.03.0-1
flex-2.6.4-3 libao-1.2.2-5 poppler-glib-21.04.0-2
fluidsynth-2.1.7-1 libappimage-1.0.3-3 poppler-glib-21.05.0-1
fluidsynth-2.1.8-1 libarchive-3.5.1-1 poppler-qt5-21.03.0-1
fmt-7.1.3-1 libass-0.15.0-2 poppler-qt5-21.04.0-2
fontconfig-2:2.13.91+48+gfcb0420-2 libass-0.15.1-1 poppler-qt5-21.05.0-1
fontconfig-2:2.13.93-4 libassuan-2.5.4-2 popt-1.18-1
foomatic-db-3:20210222-1 libassuan-2.5.5-1 portaudio-1:19.6.0-7
foomatic-db-3:20210528-1 libasyncns-0.8+3+g68cd5af-3 portaudio-1:19.7.0-1
foomatic-db-engine-4:20200206-1 libatasmart-0.19-5 postgresql-libs-13.2-1
foomatic-db-gutenprint-ppds-5.3.4-1 libavc1394-0.5.4-4 potrace-1.16-2
frameworkintegration-5.80.0-1 libavif-0.9.0-1 powerdevil-5.21.3-1
frameworkintegration-5.81.0-1 libavif-0.9.0-2 powerdevil-5.21.4-1
frameworkintegration-5.82.0-1 libavtp-0.1.0-2 powerdevil-5.21.5-1
freeglut-3.2.1-2 libblockdev-2.25-2 powertop-2.13-1
freetype2-2.10.4-1 libbluray-1.2.1-1 powertop-2.14-1
frei0r-plugins-1.7.0-1 libbluray-1.3.0-1 ppp-2.4.8-1
fribidi-1.0.10-1 libbs2b-3.1.0-7 ppp-2.4.9-1
fuse2-2.9.9-4 libbsd-0.10.0-2 pptpclient-1.10.0-2
fuse3-3.10.2-1 libburn-1.5.4-1 print-manager-20.12.3-1
fuse3-3.10.3-1 libbytesize-2.5-1 print-manager-21.04.0-1
fuse-common-3.10.2-1 libcaca-0.99.beta19-3 print-manager-21.04.1-1
fuse-common-3.10.3-1 libcaca-0.99.beta19-4 prison-5.80.0-1
fwupd-1.5.7-1 libcaca-0.99.beta19-5 prison-5.81.0-1
fwupd-1.5.8-1 libcacard-2.7.0-2 prison-5.82.0-1
fwupd-1.5.9-1 libcanberra-0.30+2+gc0620e4-3 procps-ng-3.3.17-1
fwupd-1.6.0-3 libcanberra-gstreamer-0.30+2+gc0620e4-3 protobuf-3.15.6-1
fwupd-efi-1.0-1 libcanberra-pulse-0.30+2+gc0620e4-3 protobuf-3.15.8-1
game-devices-udev-0.12-1 libcap-2.49-1 protobuf-3.16.0-1
game-devices-udev-0.13-1 libcap-2.50-1 psmisc-23.4-1
gavl-1.4.0-4 libcap-ng-0.8.2-1 pstoedit-3.75-4
gawk-5.1.0-1 libcddb-1.3.2-6 ptex-2.3.2-2
gc-8.0.4-4 libcdio-2.1.0-2 pugixml-1.11.4-1
gcab-1.4-1 libcdio-paranoia-10.2+2.0.1-2 pulseaudio-14.2-3
gcc-10.2.0-6 libcdr-0.1.6-3 pulseaudio-alsa-1:1.2.2-2
gcc-libs-10.2.0-6 libcloudproviders-0.3.1-2 pulseaudio-bluetooth-14.2-3
gcc-libs-11.1.0-1 libcroco-0.6.13-2 pulseaudio-ctl-1.67-1
gcr-3.38.1-1 libcups-1:2.3.3op2-1 pulseaudio-equalizer-14.2-3
gcr-3.40.0-1 libcups-1:2.3.3op2-3 pulseaudio-equalizer-ladspa-3.0.2-4
gd-2.3.2-2 libdaemon-0.14-5 pulseaudio-jack-14.2-3
gdbm-1.19-2 libdatrie-0.2.13-1 pulseaudio-lirc-14.2-3
gdk-pixbuf2-2.42.2-1 libdbusmenu-glib-16.04.0-4 pulseaudio-qt-1.2-2
gdk-pixbuf2-2.42.4-1 libdbusmenu-gtk3-16.04.0-4 pulseaudio-qt-1.3-1
gdk-pixbuf2-2.42.6-1 libdbusmenu-qt5-0.9.3+16.04.20160218-5 pulseaudio-rtp-14.2-3
gdl-3.34.0-2 libdc1394-2.2.6-2 pulseaudio-zeroconf-14.2-3
geoclue-2.5.7-2 libdca-0.0.7-1 pulseeffects-5.0.1-1
geoclue-2.5.7-3 libde265-1.0.8-1 purpose-5.80.0-1
geocode-glib-3.26.2-1 libdmtx-0.7.5-2 purpose-5.81.0-1
gettext-0.21-1 libdrm-2.4.104-1 purpose-5.82.0-1
ghostscript-9.53.3-3 libdrm-2.4.105-1 pybind11-2.6.2-1
ghostscript-9.54.0-2 libdrm-2.4.106-1 python2-2.7.18-2
giflib-5.2.1-2 libdv-1.0.0-9 python2-appdirs-1.4.4-3
gimp-help-en-2.10.0-3 libdvbpsi-1:1.3.3-2 python2-ordered-set-3.1.1-3
git-2.31.0-1 libdvdcss-1.4.2-2 python2-packaging-20.9-1
git-2.31.1-1 libdvdcss-1.4.3-1 python2-pyparsing-2.4.7-3
glew-2.2.0-2 libdvdnav-6.1.0-2 python2-setuptools-2:44.1.1-1
glfw-x11-3.3.3-1 libdvdnav-6.1.1-1 python2-six-1.15.0-3
glib2-2.66.7-1 libdvdread-6.1.1-1 python-3.9.2-1
glib2-2.68.0-5 libdvdread-6.1.2-1 python-3.9.4-1
glib2-2.68.1-1 libebml-1.4.1-1 python-3.9.5-3
glib2-2.68.2-1 libebml-1.4.2-1 python-appdirs-1.4.4-3
glibc-2.33-4 libebur128-1.2.6-1 python-cachecontrol-0.12.6-3
glibc-2.33-5 libedit-20210216_3.1-1 python-cairo-1.20.0-3
glibc-locales-2.32-2 libedit-20210419_3.1-1 python-cffi-1.14.5-1
glibmm-2.66.0-1 libelf-0.183-3 python-chardet-3.0.4-7
glib-networking-1:2.68.0-1 libelf-0.184-1 python-chardet-4.0.0-1
glib-networking-1:2.68.1-1 libepoxy-1.5.5-1 python-chardet-4.0.0-2
glib-networking-2.66.0-1 libepoxy-1.5.7-1 python-colorama-0.4.4-3
glslang-11.2.0-3 libepoxy-1.5.8-1 python-contextlib2-0.6.0.post1-3
glslang-11.4.0-1 libevdev-1.11.0-1 python-cryptography-3.4.6-1
glu-9.0.1-2 libevent-2.1.12-1 python-cryptography-3.4.7-1
gmp-6.2.1-1 libexif-0.6.22-1 python-distlib-0.3.1-2
gnome-icon-theme-3.12.0-6 libfakekey-0.3-2 python-distro-1.5.0-3
gnome-icon-theme-symbolic-3.12.0-6 libfbclient-3.0.7.33374-1 python-dnspython-1:1.16.0-3
gnome-keyring-1:3.36.0-3 libfdk-aac-2.0.1-2 python-docopt-0.6.2-9
gnome-themes-extra-3.28-2 libfdk-aac-2.0.2-1 python-gobject-3.38.0-3
gnupg-2.2.27-1 libffi-3.3-4 python-gobject-3.40.0-1
gnustep-base-1.27.0-2 libfontenc-1.1.4-3 python-gobject-3.40.1-1
gnustep-base-1.27.0-3 libftdi-1.5-1 python-html5lib-1.1-6
gnustep-base-1.28.0-1 libftdi-1.5-2 python-idna-2.10-3
gnutls-3.7.1-1 libgcrypt-1.9.2-1 python-idna-3.1-1
go-2:1.16.4-1 libgcrypt-1.9.3-1 python-keyutils-0.6-6
gobject-introspection-runtime-1.66.1-3 libgee-0.20.3-2 python-lxml-4.6.2-2
gobject-introspection-runtime-1.68.0-1 libgee-0.20.4-1 python-markdown-3.3.4-1
google-chrome-91.0.4472.101-1 libgit2-1:1.1.0-1 python-msgpack-1.0.2-2
gpgme-1.15.1-1 libglvnd-1.3.3-1 python-npyscreen-4.10.5-5
gpm-1.20.7.r38.ge82d1a6-3 libgme-0.6.3-1 python-numpy-1.20.1-1
gptfdisk-1.0.7-1 libgnomekbd-3.26.1+2+g8d02ebd-2 python-ordered-set-4.0.2-3
grantlee-5.2.0-3 libgpg-error-1.41-1 python-packaging-20.9-1
graphene-1.10.4-1 libgpg-error-1.42-1 python-pep517-0.10.0-1
graphene-1.10.6-1 libgphoto2-2.5.27-1 python-pep517-0.10.0-2
graphicsmagick-1.3.36-1 libgudev-236-1 python-pep517-0.9.1-3
graphite-1:1.3.14-1 libgusb-0.3.5-1 python-pillow-8.1.0-1
grep-3.6-1 libgusb-0.3.6-1 python-pillow-8.1.2-1
groff-1.22.4-4 libheif-1.11.0-1 python-pillow-8.2.0-2
groff-1.22.4-5 libheif-1.11.0-2 python-pip-20.3.1-1
grub-2.04-22 libheif-1.11.0-3 python-ply-3.11-7
grub-theme-manjaro-20.2-12 libheif-1.12.0-1 python-progress-1.5-5
gsettings-desktop-schemas-3.38.0-1 libibus-1.5.24-1 python-pycparser-2.20-3
gsettings-desktop-schemas-40.0-1 libical-3.0.10-1 python-pycups-2.0.1-3
gsettings-desktop-schemas-40.0-2 libical-3.0.9-1 python-pycurl-7.43.0.6-4
gsettings-desktop-schemas-40.0-3 libice-1.0.10-3 python-pyopenssl-20.0.1-1
gsfonts-20200910-1 libid3tag-0.15.1b-11 python-pyparsing-2.4.7-3
gsfonts-20200910-2 libidn-1.36-1 python-pyqt5-5.15.4-1
gsl-2.6-2 libidn-1.37-1 python-pyqt5-sip-12.8.1-3
gsm-1.0.19-1 libidn2-2.3.0-1 python-pyqt5-sip-12.9.0-1
gssdp-1.2.3-1 libidn2-2.3.1-1 python-pysmbc-1.0.23-2
gssproxy-0.8.4-1 libiec61883-1.2.0-6 python-pyxdg-0.26-8
gst-libav-1.18.4-1 libieee1284-0.2.11-11 python-reportlab-3.5.65-1
gst-plugin-gtk-1.18.4-1 libimagequant-2.14.1-1 python-reportlab-3.5.66-1
gst-plugin-pipewire-1:0.3.23-1 libimagequant-2.15.1-1 python-reportlab-3.5.67-1
gst-plugins-bad-1.18.4-1 libimobiledevice-1.3.0-3 python-requests-2.25.1-1
gst-plugins-bad-1.18.4-3 libinih-52-2 python-resolvelib-0.5.4-1
gst-plugins-bad-1.18.4-6 libinih-53-1 python-retrying-1.3.3-9
gst-plugins-bad-1.18.4-7 libinput-1.17.0-1 python-setuptools-1:54.1.1-1
gst-plugins-bad-libs-1.18.4-1 libinput-1.17.1-1 python-setuptools-1:54.2.0-1
gst-plugins-bad-libs-1.18.4-3 libinput-1.17.2-2 python-setuptools-1:56.0.0-1
gst-plugins-bad-libs-1.18.4-6 libinput-1.17.3-1 python-setuptools-1:56.2.0-1
gst-plugins-bad-libs-1.18.4-7 libinstpatch-1.1.6-1 python-six-1.15.0-3
gst-plugins-base-1.18.4-1 libisoburn-1.5.4-1 python-six-1.16.0-1
gst-plugins-base-libs-1.18.4-1 libisofs-1.5.4-1 python-toml-0.10.2-3
gst-plugins-good-1.18.4-1 libjcat-0.1.6-1 python-urllib3-1.26.3-1
gst-plugins-good-1.18.4-2 libjpeg-turbo-2.0.6-1 python-urllib3-1.26.4-1
gst-plugins-ugly-1.18.4-1 libjpeg-turbo-2.1.0-1 python-urllib3-1.26.5-1
gst-plugins-ugly-1.18.4-2 libkate-0.4.1-7 python-webencodings-0.5.1-6
gstreamer-1.18.4-1 libkcddb-20.12.3-1 python-yaml-5.4.1.1-1
gtk2-2.24.33-1 libkcddb-21.04.0-1 python-yaml-5.4.1.1-2
gtk3-1:3.24.27-4 libkcddb-21.04.1-1 qbittorrent-4.3.3-1
gtk3-1:3.24.28-1 libkdcraw-20.12.3-1 qca-2.3.2-1
gtk3-1:3.24.29-1 libkdcraw-21.04.0-1 qca-2.3.2-2
gtkmm3-3.24.4-1 libkdcraw-21.04.1-1 qgpgme-1.15.1-1
gtksourceview4-4.8.1-1 libkexiv2-20.12.3-1 qpdf-10.3.1-1
gtkspell3-3.0.10-2 libkexiv2-21.04.0-1 qpdf-10.3.2-1
gtk-theme-breath-5.9.0-1 libkexiv2-21.04.1-1 qqc2-desktop-style-5.80.0-1
gtk-update-icon-cache-1:4.0.3-1 libkipi-20.12.3-1 qqc2-desktop-style-5.81.0-1
gtk-update-icon-cache-1:4.0.3+61+gcb05be0aa5-1 libkipi-21.04.0-1 qqc2-desktop-style-5.82.0-1
gtk-update-icon-cache-1:4.2.0-5 libkipi-21.04.1-1 qrencode-4.1.1-1
gtk-update-icon-cache-1:4.2.1-1 libksane-20.12.3-1 qt5-base-5.15.2+kde+r192-1
gtk-vnc-1.2.0-1 libksane-21.04.0-1 qt5-base-5.15.2+kde+r196-1
guile-2.2.6-2 libksane-21.04.1-1 qt5-charts-5.15.2-1
gupnp-1.2.4-1 libksba-1.4.0-2 qt5-declarative-5.15.2-1
gupnp-1.2.6-1 libkscreen-5.21.3-1 qt5-declarative-5.15.2+kde+r24-1
gupnp-igd-1.2.0-1 libkscreen-5.21.4-1 qt5-declarative-5.15.2+kde+r26-1
gutenprint-5.3.4-1 libkscreen-5.21.5-1 qt5-graphicaleffects-5.15.2-1
gvfs-1.46.2-1 libksysguard-5.21.3.1-1 qt5-imageformats-5.15.2-1
gvfs-1.48.0-2 libksysguard-5.21.4-1 qt5-location-5.15.2-2
gvfs-1.48.1-1 libksysguard-5.21.5-1 qt5-location-5.15.2-3
gvfs-afc-1.46.2-1 libktorrent-20.12.3-1 qt5-multimedia-5.15.2-1
gvfs-afc-1.48.0-2 libktorrent-21.04.0-1 qt5-networkauth-5.15.2-1
gvfs-afc-1.48.1-1 libktorrent-21.04.1-1 qt5-quickcontrols2-5.15.2-1
gvfs-gphoto2-1.46.2-1 libldac-2.0.2.3-1 qt5-quickcontrols-5.15.2-1
gvfs-gphoto2-1.48.0-2 libldap-2.4.57-1 qt5-script-5.15.2-1
gvfs-gphoto2-1.48.1-1 libldap-2.4.58-1 qt5-sensors-5.15.2-1
gvfs-mtp-1.46.2-1 libldap-2.4.58-2 qt5-speech-5.15.2-1
gvfs-mtp-1.48.0-2 libldap-2.4.58-3 qt5-svg-5.15.2-1
gvfs-mtp-1.48.1-1 liblouis-3.17.0-1 qt5-svg-5.15.2+kde+r7-1
gvfs-nfs-1.46.2-1 liblphobos-2:1.25.1-1 qt5-tools-5.15.2-3
gvfs-nfs-1.48.0-2 liblqr-0.4.2-3 qt5-tools-5.15.2+kde+r17-1
gvfs-nfs-1.48.1-1 liblrdf-0.6.1-4 qt5-translations-5.15.2-1
gvfs-smb-1.46.2-1 libmad-0.15.1b-9 qt5-virtualkeyboard-5.15.2-1
gvfs-smb-1.48.0-2 libmanette-0.2.6-1 qt5-wayland-5.15.2-1
gvfs-smb-1.48.1-1 libmanette-0.2.6-2 qt5-wayland-5.15.2+kde+r19-1
gwenview-20.12.3-1 libmatroska-1.6.2-1 qt5-wayland-5.15.2+kde+r23-1
gwenview-21.04.0-1 libmatroska-1.6.3-1 qt5-webchannel-5.15.2-1
gwenview-21.04.1-1 libmbim-1.24.6-1 qt5-webengine-5.15.3-3
gzip-1.10-3 libmfx-20.5.1-1 qt5-webengine-5.15.3-4
harfbuzz-2.8.0-1 libmfx-21.1.3-2 qt5-webengine-5.15.3-5
harfbuzz-2.8.0-3 libmicrodns-0.2.0-1 qt5-webkit-5.212.0alpha4-10
harfbuzz-2.8.1-1 libmicrohttpd-0.9.72-1 qt5-webkit-5.212.0alpha4-9
harfbuzz-icu-2.8.0-1 libmikmod-3.3.11.1-4 qt5-websockets-5.15.2-1
harfbuzz-icu-2.8.0-3 libmm-glib-1.16.2-1 qt5-x11extras-5.15.2-1
harfbuzz-icu-2.8.1-1 libmm-glib-1.16.4-1 raptor-2.0.15-15
haveged-1.9.14-1 libmms-0.6.4-3 raptor-2.0.15-16
hdf5-1.12.0-2 libmng-2.0.3-3 rav1e-0.4.0-1
hdparm-9.60-1 libmnl-1.0.4-3 rav1e-0.4.1-1
hdparm-9.61-1 libmodplug-0.8.9.0-3 re2-1:20210202-1
hicolor-icon-theme-0.17-2 libmpc-1.2.1-1 re2-1:20210401-1
hidapi-0.10.1-1 libmpcdec-1:0.1+r475-3 readline-8.1.001-1
hplip-1:3.21.2-1 libmpdclient-2.19-3 readline-8.1.0-2
hplip-1:3.21.4-1 libmpeg2-0.5.1-7 recordmydesktop-0.3.8.1-9
htop-3.0.5-1 libmtp-1.1.18-1 reiserfsprogs-3.6.27-3
http-parser-2.9.4-1 libmusicbrainz5-5.1.0-4 rest-0.8.1-3
hunspell-1.7.0-3 libndp-1.7-2 rnnoise-0.4.1-1
hwids-20201207-1 libndp-1.8-1 rpcbind-1.2.5-3
hwinfo-21.72-1 libnet-1:1.1.6-1 rsync-3.2.3-3
hwinfo-21.73-1 libnetfilter_conntrack-1.0.8-1 rtkit-0.13-1
hwinfo-21.74-1 libnewt-0.52.21-5 rtmpdump-1:2.4.r96.fa8646d-6
hwloc-2.4.0-1 libnfnetlink-1.0.1-4 rttr-0.9.6-3
hwloc-2.4.1-1 libnfs-4.0.0-4 rubberband-1.9.1-1
hyphen-2.8.8-3 libnftnl-1.1.9-1 ruby-2.7.2-1
hyphen-en-2.8.8-3 libnghttp2-1.43.0-1 ruby-3.0.1-1
iana-etc-20210202-1 libnice-0.1.18-1 rubygems-3.2.13-1
icoutils-0.32.3-3 libnl-3.5.0-2 rubygems-3.2.15-1
icu-68.2-1 libnl-3.5.0-3 ruby-irb-1.3.4-1
icu-69.1-1 libnm-1.30.2-1 ruby-irb-1.3.5-1
ijs-0.35-3 libnm-1.30.4-1 ruby-reline-0.2.4-1
illyria-wallpaper-1.4-1 libnm-1.30.4-3 ruby-reline-0.2.5-1
imagemagick-7.0.11.10-1 libnma-1.8.30-1 run-parts-4.11.2-1
imagemagick-7.0.11.13-3 libnotify-0.7.9-1 run-parts-4.8.6.1-2
imagemagick-7.0.11.3-1 libnsl-1.3.0-1 samba-4.14.0-1
imagemagick-7.0.11.5-1 libnsl-1.3.0-2 samba-4.14.2-1
imagewriter-1.10.1432200249.1d253d9.2.5-1 libofa-0.9.3-9 samba-4.14.4-1
imath-3.0.3-1 libogg-1.3.4-2 sane-1.0.32-3
imlib2-1.7.1-1 libomxil-bellagio-0.9.3-3 sbc-1.5-2
inetutils-1.9.4-8 libopenaptx-0.2.0-1 scour-0.38.2-1
inetutils-1.9.4-9 libosinfo-1.9.0-1 screenfetch-3.9.1-1
iniparser-4.1-3 libp11-kit-0.23.22-1 sddm-0.19.0-3
inkscape-1.0.2-4 libpaper-1.1.28-1 sddm-0.19.0-4
intel-ucode-20210216-1 libpcap-1.10.0-1 sddm-0.19.0-5.0
inxi-3.3.03.1-1 libpciaccess-0.16-2 sddm-0.19.0-6
inxi-3.3.04.1-1 libpgm-5.3.128-1 sddm-breath2-theme-1.0.11-1
iproute2-5.11.0-1 libphobos-1:2.095.1-1 sddm-breath2-theme-1.0.13-1
iproute2-5.12.0-1 libpipeline-1.5.3-1 sddm-kcm-5.21.3-1
iptables-1:1.8.7-1 libpipewire02-0.2.7-1 sddm-kcm-5.21.4-1
iputils-20200821-1 libplacebo-3.120.2-1 sddm-kcm-5.21.5-1
iputils-20210202-1 libplacebo-3.120.3-1 sdl-1.2.15-14
iso-codes-4.6.0-1 libplist-2.2.0-3 sdl2-2.0.14-1
iw-5.9-1 libpng-1.6.37-3 sed-4.8-1
jack-0.125.0-9 libproxy-0.4.17-1 serd-0.30.10-1
jack2-1.9.17-2 libproxy-0.4.17-2 shaderc-2020.5-1
jansson-2.13.1-1 libpsl-0.21.1-1 shaderc-2021.0-1
jasper-2.0.25-1 libpulse-14.2-2 shadow-4.8.1-4
jasper-2.0.27-1 libpulse-14.2-3 shared-mime-info-2.0+57+gc1d1c70-1
jasper-2.0.28-1 libqaccessibilityclient-0.4.1-2 signond-8.60-3
java-runtime-common-3-3 libqalculate-3.17.0-1 signon-kwallet-extension-20.12.3-1
jbig2dec-0.19-1 libqalculate-3.18.0-2 signon-kwallet-extension-21.04.0-1
jemalloc-1:5.2.1-3 libqalculate-3.19.0-1 signon-kwallet-extension-21.04.1-1
jfsutils-1.1.15-7 libqmi-1.28.2-1 signon-plugin-oauth2-0.25-1
jre-openjdk-15.0.2.u7-1 libqmi-1.28.4-1 signon-ui-0.17+20171022-2
jre-openjdk-headless-15.0.2.u7-1 libqrtr-glib-1.0.0-1 skanlite-2.2.0-1
js78-78.10.0-1 libquicktime-1.2.4-23 slang-2.3.2-2
js78-78.10.1-1 libraqm-0.7.1-1 smartmontools-7.2-1
js78-78.8.0-1 libraw-0.20.2-1 smbclient-4.14.0-1
js78-78.9.0-1 libraw1394-2.1.2-3 smbclient-4.14.2-1
json-c-0.15-1 librevenge-0.0.4-3 smbclient-4.14.4-1
jsoncpp-1.9.4-1 librsvg-2:2.50.3-1 s-nail-14.9.22-1
json-glib-1.6.2-1 librsvg-2:2.50.5-1 snapd-2.49.1-1
k3b-1:20.12.3-1 librsvg-2:2.50.6-1 snapd-2.49.2-1
k3b-1:21.04.0-1 libsamplerate-0.2.1-1 snapd-2.50-1
k3b-1:21.04.1-1 libsasl-2.1.27-3 snapd-2.51-1
kaccounts-integration-20.12.3-1 libseccomp-2.5.1-2 snapd-glib-1.54-1
kaccounts-integration-21.04.0-1 libsecret-0.20.4-1 snappy-1.1.8-2
kaccounts-integration-21.04.1-1 libshout-1:2.4.5-1 socat-1.7.3.4-2
kaccounts-providers-20.12.3-1 libsidplay-1.36.59-10 socat-1.7.4.1-1
kaccounts-providers-21.04.0-1 libsidplayfp-2.1.1-1 sof-firmware-1.6.1-1
kaccounts-providers-21.04.1-1 libsidplayfp-2.1.2-1 sof-firmware-1.7-2
kactivities-5.80.0-1 libsigc++-2.10.6-1 solid-5.80.0-1
kactivities-5.81.0-1 libsigsegv-2.13-1 solid-5.81.0-1
kactivities-5.82.0-1 libsm-1.2.3-2 solid-5.82.0-1
kactivities-stats-5.80.0-1 libsmbios-2.4.3-3 sonnet-5.80.0-1
kactivities-stats-5.81.0-1 libsndfile-1.0.31-1 sonnet-5.81.0-1
kactivities-stats-5.82.0-1 libsodium-1.0.18-2 sonnet-5.82.0-1
kactivitymanagerd-5.21.3-1 libsoup-2.72.0+10+gfe1e295d-1 sord-0.16.8-1
kactivitymanagerd-5.21.4-1 libsoup-2.72.0+5+g0b094bff-3 sound-theme-freedesktop-0.8-4
kactivitymanagerd-5.21.5-1 libsoxr-0.1.3-2 soundtouch-2.2-1
kamera-20.12.3-1 libspectre-0.2.9-2 spandsp-0.0.6-3
kamera-21.04.0-1 libspeechd-0.10.2-1 spectacle-20.12.3-1
kamera-21.04.1-1 libspnav-0.2.3-3 spectacle-21.04.0-1
karchive-5.80.0-1 libsrtp-1:2.3.0-1 spectacle-21.04.1-1
karchive-5.81.0-1 libssh-0.9.5-1 spectre-meltdown-checker-0.43-1
karchive-5.82.0-1 libssh2-1.9.0-2 spectre-meltdown-checker-0.44-1
kate-20.12.3-1 libssh2-1.9.0-3 speech-dispatcher-0.10.2-1
kate-21.04.0-1 libstemmer-0+713-2 speex-1.2.0-3
kate-21.04.1-1 libsynctex-2020.54586-11 speexdsp-1.2.0-2
kauth-5.80.0-1 libtar-1.2.20-5 spice-gtk-0.39-3
kauth-5.81.0-1 libtasn1-4.16.0-1 spirv-tools-2020.7-1
kauth-5.82.0-1 libtasn1-4.17.0-1 spirv-tools-2021.1-1
kbd-2.4.0-2 libteam-1.31-2 splix-2.0.0-15
kbookmarks-5.80.0-1 libteam-1.31-3 sqlite-3.35.1-2
kbookmarks-5.81.0-1 libthai-0.1.28-2 sqlite-3.35.3-1
kbookmarks-5.82.0-1 libtheora-1.1.1-5 sqlite-3.35.5-1
kcalc-20.12.3-1 libtiff-4.2.0-1 squashfs-tools-4.4-2
kcalc-21.04.0-1 libtiff-4.3.0-1 squashfs-tools-4.4_git.1-1
kcalc-21.04.1-1 libtirpc-1.3.1-1 squashfuse-0.1.103-3
kcmutils-5.80.0-1 libtirpc-1.3.2-1 squashfuse-0.1.104-2
kcmutils-5.81.0-1 libtommath-1.2.0-3 sratom-0.6.8-1
kcmutils-5.82.0-1 libtool-2.4.6+42+gb88cebd5-14 srt-1.4.2-1
kcodecs-5.80.0-1 libtool-2.4.6+42+gb88cebd5-16 srt-1.4.3-1
kcodecs-5.81.0-1 libtorrent-rasterbar-1:1.2.11-1 sshfs-3.7.1-1
kcodecs-5.82.0-1 libunistring-0.9.10-3 steam-manjaro-1.0.0.69-1
kcolorpicker-0.1.5-1 libunwind-1.5.0-1 steam-manjaro-1.0.0.70-1
kcolorpicker-0.1.6-1 libupnp-1.14.2-1 stoken-0.92-4
kcompletion-5.80.0-1 libupnp-1.14.6-1 stremio-beta-4.4.137-0
kcompletion-5.81.0-1 libupnp-1.14.7-1 sudo-1.9.6.p1-1
kcompletion-5.82.0-1 liburing-0.7-2 sudo-1.9.7-1
kconfig-5.80.0-1 liburing-2.0-1 svt-av1-0.8.6-2
kconfig-5.81.0-1 libusb-1.0.24-2 svt-av1-0.8.7-1
kconfig-5.82.0-1 libusb-compat-0.1.7-1 svt-hevc-1.5.0-1
kconfigwidgets-5.80.0-1 libusbmuxd-2.0.2-1 svt-hevc-1.5.1-1
kconfigwidgets-5.81.0-1 libutempter-1.2.1-1 swh-plugins-0.4.17-4
kconfigwidgets-5.82.0-1 libuv-1.41.0-1 syntax-highlighting-5.80.0-1
kcontacts-1:5.80.0-1 libva-2.10.0-1 syntax-highlighting-5.81.0-1
kcontacts-1:5.81.0-1 libva-2.11.0-1 syntax-highlighting-5.82.0-1
kcontacts-1:5.82.0-1 libva-intel-driver-2.4.1-1 sysfsutils-2.1.1-1
kcoreaddons-5.80.0-1 libva-mesa-driver-20.3.4-3 system-config-printer-1.5.15-1
kcoreaddons-5.81.0-1 libva-mesa-driver-21.0.1-1.0 systemd-247.4-1
kcoreaddons-5.82.0-1 libva-mesa-driver-21.0.3-3 systemd-247.6-1.0
kcrash-5.80.0-1 libva-mesa-driver-21.1.2-0 systemd-247.7-1
kcrash-5.81.0-1 libva-vdpau-driver-0.7.4-5 systemd-fsck-silent-239-1
kcrash-5.82.0-1 libvdpau-1.4-1 systemd-kcm-1.2.1-5
kdbusaddons-5.80.0-1 libvirt-1:7.3.0-1 systemd-libs-247.4-1
kdbusaddons-5.81.0-1 libvirt-glib-4.0.0-1 systemd-libs-247.6-1.0
kdbusaddons-5.82.0-1 libvirt-python-1:7.3.0-1 systemd-libs-247.7-1
kdeclarative-5.80.0-1 libvisio-0.1.7-4 systemd-sysvcompat-247.4-1
kdeclarative-5.81.0-1 libvisual-0.4.0-8 systemd-sysvcompat-247.6-1.0
kdeclarative-5.82.0-1 libvorbis-1.3.7-2 systemd-sysvcompat-247.7-1
kde-cli-tools-5.21.3-1 libvpx-1.10.0-1 systemsettings-5.21.3-1
kde-cli-tools-5.21.4-1 libvpx-1.9.0-1 systemsettings-5.21.4-1
kde-cli-tools-5.21.5-1 libwacom-1.10-1 systemsettings-5.21.5-1
kdeconnect-20.12.3-1 libwacom-1.9-1 t1lib-5.1.2-8
kdeconnect-21.04.0-1 libwebp-1.2.0-1 taglib-1.12-1
kdeconnect-21.04.1-2 libwmf-0.2.12-2 talloc-2.3.2-1
kdecoration-5.21.3-1 libwpd-0.10.3-2 tar-1.34-1
kdecoration-5.21.4-1 libwpe-1.10.0-1 tbb-2020.3-1
kdecoration-5.21.5-1 libwpe-1.8.0-1 tcl-8.6.11-1
kded-5.80.0-1 libwpg-0.3.3-2 tdb-1.4.3-4
kded-5.81.0-1 libx11-1.7.0-4 telegram-desktop-2.7.4-2
kded-5.82.0-1 libx11-1.7.1-1 terminus-font-4.49.1-1
kdegraphics-thumbnailers-20.12.3-1 libx86emu-3.1-1 terminus-font-4.49.1-2
kdegraphics-thumbnailers-21.04.0-1 libxau-1.0.9-3 tevent-1:0.10.2-3
kdegraphics-thumbnailers-21.04.1-1 libxaw-1.0.13-3 texinfo-6.7-3
kde-gtk-config-5.21.3-1 libxaw-1.0.14-1 texlive-bin-2020.54586-11
kde-gtk-config-5.21.4-1 libxcb-1.14-1 texlive-core-2020.57066-1
kde-gtk-config-5.21.5-1 libxcomposite-0.4.5-3 thin-provisioning-tools-0.9.0-1
kdelibs4support-5.80.0-1 libxcrypt-4.4.18-1 threadweaver-5.80.0-1
kdelibs4support-5.81.0-1 libxcrypt-4.4.19-1 threadweaver-5.81.0-1
kdelibs4support-5.82.0-1 libxcrypt-4.4.20-1 threadweaver-5.82.0-1
kdenetwork-filesharing-20.12.3-1 libxcursor-1.2.0-2 thunderbird-78.10.1-0.2
kdenetwork-filesharing-21.04.0-1 libxdamage-1.1.5-3 thunderbird-78.10.2-1
kdenetwork-filesharing-21.04.1-1 libxdmcp-1.1.3-3 thunderbird-78.9.1-0.1
kdenlive-21.04.1-1 libxext-1.3.4-3 timeshift-20.11.1.r3.g08d0e59-2
kdeplasma-addons-5.21.3-1 libxfixes-5.0.3-4 tinyxml-2.6.2-7
kdeplasma-addons-5.21.4-1 libxfixes-6.0.0-1 tlp-1.3.1-2
kdeplasma-addons-5.21.5-1 libxfont2-2.0.4-3 tpm2-tss-3.0.3-1
kdesu-5.80.0-1 libxft-2.3.3-2 tpm2-tss-3.1.0-1
kdesu-5.81.0-1 libxi-1.7.10-3 transcode-1.1.7-37
kdesu-5.82.0-1 libxinerama-1.1.4-3 tslib-1.22-1
kdialog-20.12.3-1 libxkbcommon-1.1.0-2 ttf-dejavu-2.37+18+g9b5d1b2f-2
kdnssd-5.80.0-1 libxkbcommon-1.3.0-1 ttf-dejavu-2.37+18+g9b5d1b2f-3
kdnssd-5.81.0-1 libxkbcommon-x11-1.1.0-2 ttf-droid-20121017-10
kdnssd-5.82.0-1 libxkbcommon-x11-1.3.0-1 ttf-droid-20121017-9
kdoctools-5.80.0-1 libxkbfile-1.1.0-2 ttf-hack-3.003-3
kdoctools-5.81.0-1 libxklavier-5.4-3 ttf-inconsolata-1:3.000-2
kdoctools-5.82.0-1 libxml2-2.9.10-8 ttf-inconsolata-1:3.000-3
kdsoap-1.10.0-1 libxml2-2.9.10-9 ttf-indic-otf-0.2-11
kdsoap-ws-discovery-client-git20200927-1 libxmlb-0.3.0-1 ttf-liberation-2.1.3-1
keditbookmarks-20.12.3-1 libxmu-1.1.3-2 ttf-liberation-2.1.4-1
keditbookmarks-21.04.0-1 libxpm-3.5.13-2 ttf-opensans-1.101-2
keditbookmarks-21.04.1-1 libxrandr-1.5.2-3 twolame-0.4.0-2
kemoticons-5.80.0-1 libxrender-0.9.10-4 tzdata-2021a-1
kemoticons-5.81.0-1 libxres-1.2.0-2 uchardet-0.0.7-1
kemoticons-5.82.0-1 libxres-1.2.1-1 udiskie-2.3.3-1
kernel-alive-0.5-1 libxshmfence-1.3-2 udisks2-2.9.2-1
keyutils-1.6.3-1 libxslt-1.1.34-5 unarchiver-1.10.7-2
kfilemetadata-5.80.0-1 libxss-1.2.3-3 unarchiver-1.10.7-3
kfilemetadata-5.81.0-1 libxt-1.2.1-1 unarchiver-1.10.7-4
kfilemetadata-5.82.0-1 libxtst-1.2.3-4 unixodbc-2.3.9-1
kfind-20.12.3-1 libxv-1.0.11-4 upower-0.99.11-3
kfind-21.04.0-1 libxvmc-1.0.12-3 usb_modeswitch-2.6.1-1
kfind-21.04.1-1 libxxf86vm-1.1.4-4 usbmuxd-1.1.1-1
kgamma5-5.21.3-1 libyaml-0.2.5-1 usbredir-0.9.0-1
kgamma5-5.21.4-1 libyuv-r2212+dfaf7534-2 usbutils-013-1
kgamma5-5.21.5-1 libzip-1.7.3-2 util-linux-2.36.2-1
kget-20.12.3-1 licenses-20200427-1 util-linux-libs-2.36.2-1
kget-21.04.0-1 lilv-0.24.12-1 v4l-utils-1.20.0-1
kget-21.04.1-1 linux510-5.10.34-1 v86d-0.1.10-5.1
kglobalaccel-5.80.0-1 linux510-5.10.41-1 vamp-plugin-sdk-2.10.0-1
kglobalaccel-5.80.0-2 linux-api-headers-5.10.13-1 vcdimager-2.0.1-4
kglobalaccel-5.81.0-1 linux-api-headers-5.12.3-1 vi-1:070224-4
kglobalaccel-5.82.0-1 linux-firmware-20210315.r1846.3568f96-1 vi-1:070224-5
kguiaddons-5.80.0-1 linux-firmware-20210322.r1859.3f026a2-1 vid.stab-1.1-3
kguiaddons-5.81.0-1 linux-firmware-20210518.r1928.f846292-1 vlc-3.0.12-3
kguiaddons-5.82.0-1 lirc-1:0.10.1-8 vlc-3.0.12-6
khelpcenter-20.12.3-1 llvm-libs-11.1.0-1 vlc-3.0.14-1
khelpcenter-21.04.0-1 lmdb-0.9.29-1 vmaf-1.5.3-1
khelpcenter-21.04.1-1 lm_sensors-1:3.6.0.r41.g31d1f125-1 volume_key-0.3.12-5
kholidays-1:5.80.0-1 log4cplus-2.0.5-1 vpnc-1:0.5.3.r468.r81-2
kholidays-1:5.81.0-1 logrotate-3.18.0-1 vte3-0.62.3-1
kholidays-1:5.82.0-1 lsb-release-1.4-13 vte3-0.64.0-1
khotkeys-5.21.3-1 lshw-B.02.19.2-1 vte3-0.64.1-1
khotkeys-5.21.4-1 l-smash-2.14.5-2 vte-common-0.62.3-1
khotkeys-5.21.5-1 lsof-4.94.0-1 vte-common-0.64.0-1
khtml-5.80.0-1 lsp-plugins-1.1.29-1 vte-common-0.64.1-1
khtml-5.81.0-1 lua52-5.2.4-5 vulkan-icd-loader-1.2.172-1
khtml-5.82.0-1 lua52-socket-20200329-1 vulkan-icd-loader-1.2.176-1
ki18n-5.80.0-1 luit-20201003-1 vulkan-intel-20.3.4-3
ki18n-5.81.0-1 lvm2-2.03.11-5 vulkan-radeon-20.3.4-3
ki18n-5.82.0-1 lvm2-2.03.12-1 w3m-0.5.3.git20200507-2
kiconthemes-5.80.0-1 lz4-1:1.9.3-1 wallpapers-2018-1.2-1
kiconthemes-5.80.0-2 lz4-1:1.9.3-2 wallpapers-juhraya-1.1-2
kiconthemes-5.81.0-1 lzip-1.22-1 wavpack-5.4.0-1
kiconthemes-5.82.0-1 lzo-2.10-3 wayland-1.19.0-1
kidletime-5.80.0-1 m4-1.4.18-3 wayland-protocols-1.20-1
kidletime-5.81.0-1 mailcap-2.1.49-1 wayland-protocols-1.21-1
kidletime-5.82.0-1 mailcap-2.1.53-1 web-installer-url-handler-1.0.2-1
kimageannotator-0.4.2-1 make-4.3-3 webkit2gtk-2.30.5-1
kimageannotator-0.5.0-2 man-db-2.9.4-1 webkit2gtk-2.32.0-1
kimageformats-5.80.0-1 manjaro-alsa-20210109-1 webkit2gtk-2.32.0-2
kimageformats-5.81.0-2 manjaro-application-utility-1.3.3-4.1 webkit2gtk-2.32.1-1
kimageformats-5.82.0-2 manjaro-base-skel-20171029-3 webrtc-audio-processing-0.3.1-2
kinfocenter-5.21.3-1 manjaro-browser-settings-20201114-1 wget-1.21.1-1
kinfocenter-5.21.4-1 manjaro-documentation-en-20181009-1 which-2.21-5
kinfocenter-5.21.5-1 manjaro-firmware-20160419-1 wildmidi-0.4.3-3
kinit-5.80.0-1 manjaro-hello-0.6.6-5 wildmidi-0.4.4-1
kinit-5.81.0-1 manjaro-hotfixes-2018.08-6 wireless-regdb-2020.11.20-1
kinit-5.82.0-1 manjaro-icons-20191015-1 woff2-1.0.2-3
kio-5.80.1-1 manjaro-kde-settings-20200804-1 wpa_supplicant-2:2.9-8
kio-5.80.1-2 manjaro-keyring-20201216-1 wpebackend-fdo-1.8.1-1
kio-5.81.0-1 manjaro-printer-20200215-2 wpebackend-fdo-1.8.2-1
kio-5.82.0-1 manjaro-pulse-20210109-1 wpebackend-fdo-1.8.3-1
kio-extras-20.12.3-1 manjaro-release-21.0-1 wpebackend-fdo-1.9.92-1
kio-extras-21.04.0-2 manjaro-release-21.0.1-1 x264-3:0.160.r3011.cde9a93-1
kio-extras-21.04.1-2 manjaro-release-21.0.4-1 x264-3:0.161.r3039.544c61f-1
kirigami2-5.80.0-1 manjaro-release-21.0.6-1 x265-3.4-1
kirigami2-5.81.0-1 manjaro-settings-manager-0.5.6-11 x265-3.5-1
kirigami2-5.82.0-1 manjaro-settings-manager-0.5.6-13 xapian-core-1:1.4.18-1
kitemmodels-5.80.0-1 manjaro-settings-manager-0.5.6-14 xapp-2.0.7-1
kitemmodels-5.81.0-1 manjaro-settings-manager-kcm-0.5.6-11 xbitmaps-1.1.2-2
kitemmodels-5.82.0-1 manjaro-settings-manager-kcm-0.5.6-13 xcb-proto-1.14.1-3
kitemviews-5.80.0-1 manjaro-settings-manager-kcm-0.5.6-14 xcb-util-0.4.0-3
kitemviews-5.81.0-1 manjaro-settings-manager-knotifier-0.5.6-11 xcb-util-cursor-0.1.3-3
kitemviews-5.82.0-1 manjaro-settings-manager-knotifier-0.5.6-13 xcb-util-image-0.4.0-3
kjobwidgets-5.80.0-1 manjaro-settings-manager-knotifier-0.5.6-14 xcb-util-keysyms-0.4.0-3
kjobwidgets-5.81.0-1 manjaro-system-20210523-1 xcb-util-renderutil-0.3.9-3
kjobwidgets-5.82.0-1 manjaro-system-20210612-1 xcb-util-wm-0.4.1-3
kjs-5.80.0-1 manjaro-wallpapers-18.0-1.4-3 xdg-dbus-proxy-0.1.2-2
kjs-5.81.0-1 manjaro-zsh-config-0.20-3 xdg-dbus-proxy-0.1.2-3
kjs-5.82.0-1 man-pages-5.10-1 xdg-desktop-portal-1.8.0-1
kmenuedit-5.21.3-1 man-pages-5.11-1 xdg-desktop-portal-1.8.1-1
kmenuedit-5.21.4-1 mariadb-libs-10.5.9-1 xdg-desktop-portal-kde-5.21.3-1
kmenuedit-5.21.5-1 mbedtls-2.25.0-1 xdg-desktop-portal-kde-5.21.4-1
kmod-28-1 md4c-0.4.7-1 xdg-desktop-portal-kde-5.21.5-1
kmod-29-1 md4c-0.4.8-1 xdg-user-dirs-0.17-3
knewstuff-5.80.0-1 mdadm-4.1-2 xdg-utils-1.1.3+19+g9816ebb-1
knewstuff-5.81.0-1 media-player-info-24-2 xdman-2020.7.2.11-2
knewstuff-5.82.0-1 memtest86+-5.01-4 xf86-input-elographics-1.4.2-2
knotifications-5.80.0-1 mesa-20.3.4-3 xf86-input-evdev-2.10.6-2
knotifications-5.81.0-1 mesa-21.0.1-1.0 xf86-input-libinput-0.30.0-1
knotifications-5.82.0-1 mesa-21.0.3-3 xf86-input-libinput-1.0.1-1
knotifyconfig-5.80.0-1 mesa-21.1.2-0 xf86-input-void-1.4.1-5
knotifyconfig-5.81.0-1 mesa-demos-8.4.0-4 xf86-video-amdgpu-19.1.0-2
knotifyconfig-5.82.0-1 mesa-vdpau-20.3.4-3 xf86-video-ati-1:19.1.0-2
konsole-20.12.3-1 mhwd-0.6.5-2 xf86-video-intel-1:2.99.917+916+g31486f40-1
konsole-21.04.0-2 mhwd-amdgpu-19.1.0-1 xf86-video-nouveau-1.0.17-1
konsole-21.04.1-1 mhwd-ati-19.1.0-1 xfsprogs-5.10.0-2
konversation-20.12.3-1 mhwd-db-0.6.5-7 xfsprogs-5.11.0-1
konversation-21.04.0-1 mhwd-nvidia-390xx-390.141-1 xfsprogs-5.11.0-2
konversation-21.04.1-1 mhwd-nvidia-390xx-390.143-1 xine-lib-1.2.11-3
kpackage-5.80.0-1 mhwd-nvidia-460.56-2 xine-ui-0.99.12-2
kpackage-5.81.0-1 mhwd-nvidia-460.67-1 xkeyboard-config-2.32-1
kpackage-5.82.0-1 mhwd-nvidia-460.73.01-1 xmlsec-1.2.31-1
kparts-5.80.0-1 mhwd-nvidia-465.31-1 xmlsec-1.2.32-1
kparts-5.81.0-1 microsoft-edge-dev-88.0.673.0-1 xorg-fonts-encodings-1.0.5-2
kparts-5.82.0-1 milou-5.21.3-1 xorg-mkfontscale-1.2.1-2
kpeople-5.80.0-1 milou-5.21.4-1 xorgproto-2021.3-1
kpeople-5.81.0-1 milou-5.21.5-1 xorgproto-2021.4-1
kpeople-5.82.0-1 minizip-1:1.2.11-4 xorg-server-1.20.10-3
kpeoplevcard-0.1+r38.32d50a9-1 mjpegtools-2.2.0-1 xorg-server-1.20.11-1
kpmcore-20.12.3-1 mjpegtools-2.2.0beta-1 xorg-server-common-1.20.10-3
kpmcore-21.04.0-1 mkinitcpio-29-1.0 xorg-server-common-1.20.11-1
kpmcore-21.04.1-1 mkinitcpio-busybox-1.32.1-2 xorg-setxkbmap-1.3.2-2
kpty-5.80.0-1 mkinitcpio-busybox-1.32.1-3 xorg-twm-1.0.11-1
kpty-5.81.0-1 mkinitcpio-openswap-0.1.0-3 xorg-xauth-1.1-2
kpty-5.82.0-1 mlt6-6.26.1-4 xorg-xdpyinfo-1.3.2-4
kquickcharts-5.80.0-1 mobile-broadband-provider-info-20201225-1 xorg-xhost-1.0.8-2
kquickcharts-5.81.0-1 modemmanager-1.16.2-1 xorg-xinit-1.4.1-3
kquickcharts-5.82.0-1 modemmanager-1.16.4-1 xorg-xkbcomp-1.4.5-1
krb5-1.18.3-1 modemmanager-qt-5.80.0-1 xorg-xkill-1.0.5-2
krb5-1.19.1-1 modemmanager-qt-5.81.0-1 xorg-xmessage-1.0.5-2
krunner-5.80.0-1 modemmanager-qt-5.82.0-1 xorg-xmodmap-1.0.10-2
krunner-5.81.0-1 mpd-0.22.6-3 xorg-xprop-1.2.5-1
krunner-5.82.0-1 mpd-0.22.6-4 xorg-xrandr-1.5.1-2
krusader-2.7.2-4 mpd-0.22.8-1 xorg-xrdb-1.2.0-2
kscreen-5.21.3-1 mpfr-4.1.0-1 xorg-xset-1.2.4-2
kscreen-5.21.4-1 mpfr-4.1.0-2 xorg-xsetroot-1.1.2-2
kscreen-5.21.5-1 mpg123-1.26.3-2 xterm-366-1
kscreenlocker-5.21.3-1 mpg123-1.26.5-1 xvidcore-1.3.7-2
kscreenlocker-5.21.4-1 mpg123-1.27.2-1 xxhash-0.8.0-1
kscreenlocker-5.21.5-1 mpv-1:0.33.1-2 xz-5.2.5-1
kservice-5.80.0-1 mtdev-1.1.6-1 yajl-2.1.0-4
kservice-5.81.0-1 mtools-4.0.26-1 yakuake-20.12.3-1
kservice-5.82.0-1 mtpfs-1.1-4 yakuake-21.04.0-1
ksshaskpass-5.21.3-1 mujs-1.1.2-1 yakuake-21.04.1-1
ksshaskpass-5.21.4-1 nano-5.6.1-1 yaml-cpp-0.6.3-2
ksshaskpass-5.21.5-1 nano-5.7-1 yay-git-10.2.3.r7.g040c8fe-1
ksysguard-5.21.3-1 ncurses-6.2-1 yelp-3.38.3-1
ksysguard-5.21.4-1 ncurses-6.2-2 yelp-xsl-3.38.3-1
ksysguard-5.21.5-1 ndctl-71.1-1 zam-plugins-3.14-1
ksystemlog-20.12.3-1 neofetch-7.1.0-2 zbar-0.23.1-6
ksystemlog-21.04.0-1 neon-0.31.2-1 zenity-3.32.0+55+gd7bedff-1
ksystemlog-21.04.1-1 nerd-fonts-noto-sans-mono-2.0.0-1 zensu-0.3-1
ktexteditor-5.80.0-1 netpbm-10.73.33-1 zeromq-4.3.3-2
ktexteditor-5.81.0-1 net-snmp-5.9.1-1 zeromq-4.3.4-1
ktexteditor-5.82.0-2 net-snmp-5.9-3 zimg-3.0.1-2
ktextwidgets-5.80.0-1 nettle-3.7.1-1 zita-alsa-pcmi-0.3.2-3
ktextwidgets-5.81.0-1 nettle-3.7.2-1 zita-convolver-4.0.3-2
ktextwidgets-5.82.0-1 networkmanager-1.30.2-1 zita-resampler-1.8.0-1
kunitconversion-5.80.0-1 networkmanager-1.30.4-1 zlib-1:1.2.11-4
kunitconversion-5.81.0-1 networkmanager-1.30.4-3 zsh-5.8-1
kunitconversion-5.82.0-1 networkmanager-openconnect-1.2.7dev+49+gc512d5a-1 zsh-autosuggestions-0.6.4-1
kuserfeedback-1.0.0-1 networkmanager-openconnect-1.2.7dev+65+gca4187c-1 zsh-completions-0.32.0-1
kvantum-qt5-0.19.0-1 networkmanager-openvpn-1.8.12-1 zsh-completions-0.33.0-1
kwallet-5.80.0-1 networkmanager-openvpn-1.8.14-1 zsh-history-substring-search-1.0.2-1
kwallet-5.81.0-1 networkmanager-pptp-1.2.9dev+10+gb41b0d0-3 zsh-syntax-highlighting-0.7.1-1
kwallet-5.82.0-1 networkmanager-pptp-1.2.9dev+10+gb41b0d0-4 zsh-theme-powerlevel10k-1.14.6-1
kwalletmanager-20.12.3-1 networkmanager-qt-5.80.0-1 zstd-1.4.9-1
kwalletmanager-21.04.0-1 networkmanager-qt-5.81.0-1 zstd-1.5.0-1
kwalletmanager-21.04.1-1 networkmanager-qt-5.82.0-1 zvbi-0.2.35-4
kwallet-pam-5.21.3-1 networkmanager-vpnc-1.2.7dev+20+gdca3aea-2 zxing-cpp-1.1.1-1
kwallet-pam-5.21.4-1 nfsidmap-2.5.3-1 zxing-cpp-1.2.0-1
kwallet-pam-5.21.5-1 nfs-utils-2.5.3-1 zziplib-0.13.72-1
dmt
14 June 2021 14:46
25
This will be the problem.
Baris:
ALPM_DB_VERSION
dmt
14 June 2021 14:52
27
Because it doesn’t match the regular expression '^(.*?)-[0-9]'
, all the other files do.
start of a line, or in this case a filename
captures any number of any char, but as few as possible
-[0-9]
matches the char -
followed by any number in the range 0-9
It’s looking for the start of the filename upto -
followed by a number, eg -0
. That file doesn’t contain anything like that so it doesn’t match.
Since we have no matches the list of matches is empty.
gan
14 June 2021 14:58
29
But ALPM_DB_VERSION not have to be deleted, because isn’t a duplicate package. At this point, if I were Baris, I would try manually. I don’t think there are many others alternatives, besides reinstall Manjaro.
dmt
14 June 2021 15:00
30
We could edit the script to ignore it.
Not tested but should work.
#!/usr/bin/env python
import os,re, datetime
d = '/var/lib/pacman/local'
packages = os.listdir(d)
packages.sort()
pkgname_search = re.compile('^(.*?)-[0-9]')
old_packages = []
for pkg1 in packages:
if pkg1 in old_packages or pkg1 == 'ALPM_DB_VERSION':
continue
#get package name
pkgname = pkgname_search.findall(pkg1)[0]
#look for other items with the same package name
for pkg2 in packages:
if pkg2 == pkg1 or pkg2 == 'ALPM_DB_VERSION':
continue
if pkg2 in old_packages:
continue
if pkgname == pkgname_search.findall(pkg2)[0]:
# We now have two duplicate packages, we want to delete the old one
old_package = pkg1
path1 = os.path.join(d,pkg1)
path2 = os.path.join(d,pkg2)
if os.stat(path1).st_mtime > os.stat(path2).st_mtime:
old_package = pkg2
old_packages.append(old_package)
#print ('duplicate found:\t')
#print (pkg1)
#print (pkg2)
#print ('old:', old_package)
oldpath = os.path.join(d,old_package)
target = os.path.join('/var/lib/pacman/OLD',old_package)
cmd = 'mv "%s" "%s"' % (oldpath, target)
#double-check that the oldpath still exists (it may have been removed in a previous pass)
if os.path.exists(oldpath):
print(cmd)
os.system(cmd)
Better scripts in posts 43 and 44.
gan
14 June 2021 15:03
31
Yes, this could be very useful!
Unfortunately, I don’t know python language. But if anyone could do it, it will be ok!
Baris
14 June 2021 15:08
32
My Python knowledge is not enough for it.
Thank you!
dmt
14 June 2021 15:23
33
You’re welcome.
Does that mean it worked?
Baris
14 June 2021 15:28
34
When i run it without root:
With root:
dmt
14 June 2021 15:30
35
It’s changing root owned files so needs root.
You didn’t run this:
Baris
14 June 2021 15:49
36
No, i did.
[baris@Samanyolu ~]$ sudo mkdir /var/lib/pacman/OLD
[sudo] password for baris:
mkdir: cannot create directory ‘/var/lib/pacman/OLD’: File exists
dmt
14 June 2021 15:58
37
Of course, sorry I had a brainfart and forgot to check the error message again before posting.
ls /var/lib/pacman/OLD | grep breath
ls /var/lib/pacman/local | grep breath
Baris
14 June 2021 16:03
38
[baris@Samanyolu ~]$ ls /var/lib/pacman/local | grep breathe
[baris@Samanyolu ~]$ ls /var/lib/pacman/OLD | grep breath
dmt
14 June 2021 16:07
39
Ok, I was right the first time, seems to be a bug with checking the path.
I tested on my machine, luckily I had a few dups, this seems to work.
import os,re, datetime, pathlib
packages.sort()
old_packages = []
# print(pkg1)
continue
#get package name
# print(pkg2)
continue
continue
old_package = pkg1
old_package = pkg2
#print (pkg1)
#print (pkg2)
opath = pathlib.Path(oldpath)
# if os.path.exists(oldpath):
if opath.exists():
print(cmd)
os.system(cmd)
EDIT:
Baris
14 June 2021 16:10
40
Warning: Could not start program '/home/baris/rmDuplicate.sh' with arguments '/home/baris/rmDuplicate.sh'.
Warning: execve: Exec format error
