Cannot upgrade Manjaro XFCE due to a dependency problem
What is broken? I have KDE Plasma and dav1d 1.3.0 and no problems so far. Even the apps mentioned in the original thread are working for me (obs, Chromium, Falkon)
Sync your mirrors:
https://packages.manjaro.org/?query=dav1d
Solved my issues, could update & reinstall vlc, thank you :slight_smile:
Hmm, yeah can see that the mirrors that is selected for me when running
sudo pacman-mirrors --fasttrack && sudo pacman -Syyu
is only mirrors that is marked out-of-date. Will just manually update to a mirror that is updated.
Edit: Yeah that did the trick, thank you!
There is a lot of confusion among some users. Let’s make it clear: the new version is generally working fine. You only have to take action (downgrade to the old one) if you use some specific programs, wrongly compiled against the older version and do not run anymore, and you really need them right now before they are fixed.
Looks like the mirror in the Netherlands isn’t up to speed. Switched to Germany, did a db refresh and everything was okay.
Firstly, upgrade your kernel to at least 6.1 LTS; then try again.
Manjaro Kernels
Also check your mirror is updated.
Manjaro Mirrors
Or, simply wait until the situation is resolved; I’m guessing it will be soon.
had the same problem on my surface pro,
fixed it, it just updated the 3 packages (two fmpegs and david) after changing mirrors.
thanks @ludblom
I concur; with the exception of OBS.
  • KDE, Wayland/X11, Stable, 6.1 LTS, fully updated at the time of writing.
  • No additional themes; No obvious dependency issues.
I’ve got nothing to complain about – it feels like I’m missing out! :upside_down_face:
@ludbom thank you so much,it works.
