I’m having trouble updating a system that hasn’t been attended for over a year, there’s dependency problems and outdated GPG keys.
error: key "428F7ECC7117F726" could not be looked up remotely
error: required key missing from keyring
I tried some of the recommendations I found in the forum for refreshing keys and removing old dependencies, but I’m still stuck:
[fraum-mnjr crew]# sudo pacman -Syuvv
Root : /
Conf File : /etc/pacman.conf
DB Path : /var/lib/pacman/
Cache Dirs: /var/cache/pacman/pkg/
Hook Dirs : /usr/share/libalpm/hooks/ /etc/pacman.d/hooks/
Lock File : /var/lib/pacman/db.lck
Log File : /var/log/pacman.log
GPG Dir : /etc/pacman.d/gnupg/
Targets : None
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Some packages should be upgraded first...
resolving dependencies...
Packages (3) archlinux-keyring-20210110-1 manjaro-keyring-20201216-1
manjaro-system-20210612-1
Total Installed Size: 1.48 MiB
Net Upgrade Size: 0.39 MiB
:: Proceed with installation? [Y/n] y
(3/3) checking keys in keyring [######################] 100%
downloading required keys...
error: key "6D42BDD116E0068F" could not be looked up remotely
error: failed to commit transaction (unexpected error)
:: Replace geoclue2 with extra/geoclue? [Y/n] y
:: Replace hunspell-en_US with extra/hunspell-en_us? [Y/n] y
:: Replace intel-tbb with extra/tbb? [Y/n] y
:: Replace lib32-libcanberra-pulse with multilib/lib32-libcanberra? [Y/n] y
:: Replace libcanberra-pulse with extra/libcanberra? [Y/n] y
:: Replace libdmx with extra/xorgproto-transfer? [Y/n] y
:: Replace libmagick with extra/imagemagick? [Y/n] y
:: Replace libsystemd with core/systemd-libs? [Y/n] y
:: Replace libutil-linux with core/util-linux-libs? [Y/n] y
:: Replace libwbclient with extra/smbclient? [Y/n] y
:: Replace manjaro-xfce-gtk3-settings with community/manjaro-xfce-settings? [Y/n] y
warning: mhwd-nvidia: local (1:415.27-1) is newer than core (465.31-1)
:: Replace pamac with extra/pamac-gtk? [Y/n] y
:: Replace pygobject-devel with extra/python-gobject? [Y/n] y
:: Replace pygobject2-devel with community/python2-gobject2? [Y/n] y
:: Replace python-dbus with extra/dbus-python? [Y/n] y
:: Replace python-dbus-common with extra/dbus-python? [Y/n] y
:: Replace python-xdg with extra/python-pyxdg? [Y/n] y
:: Replace qtkeychain with extra/qtkeychain-qt5? [Y/n] y
:: Replace steam-devices with community/game-devices-udev? [Y/n] y
:: Replace xorg-mkfontdir with extra/xorg-mkfontscale? [Y/n] y
:: There are 2 providers available for libgdk-3.so=0-64:
:: Repository extra
1) gtk3
:: Repository community
2) gtk3-typeahead
Enter a number (default=1): 2
:: gtk3-typeahead and gtk3-classic are in conflict (gtk3). Remove gtk3-classic? [y/N] y
:: python-pyqt5 and pyqt5-common are in conflict. Remove pyqt5-common? [y/N] y
:: dbus-python and python2-dbus are in conflict. Remove python2-dbus? [y/N] y
warning: dependency cycle detected:
warning: bashrc-manjaro will be installed before its bash dependency
warning: harfbuzz will be installed before its freetype2 dependency
warning: libglvnd will be installed before its mesa dependency
warning: smbclient will be installed before its cifs-utils dependency
warning: usbmuxd will be installed before its libimobiledevice dependency
warning: lib32-keyutils will be installed before its lib32-krb5 dependency
warning: lib32-harfbuzz will be installed before its lib32-freetype2 dependency
warning: lib32-mesa will be installed before its lib32-libglvnd dependency
Packages (1250) a52dec-0.7.4-11 aalib-1.4rc5-14 accountsservice-0.6.55-3
acl-2.3.1-1 acpi-1.7-3 acpid-2.0.32-2
adapta-maia-theme-3.94.0.149-2
adobe-source-code-pro-fonts-2.038ro+1.058it+1.018var-1
// ultra long package list here
zstd-1.5.0-1 zvbi-0.2.35-4 zxing-cpp-1.2.0-1
Total Installed Size: 7190.40 MiB
Net Upgrade Size: 1326.38 MiB
(1227/1227) checking keys in keyring [######################] 100%
error: key "7258734B41C31549" could not be looked up remotely
error: key "3B94A80E50A477C7" could not be looked up remotely
error: key "150C200743ED46D8" could not be looked up remotely
error: key "5A45B06B81CAB876" could not be looked up remotely
error: key "45A650E2638C536D" could not be looked up remotely
error: key "9D4C5AA15426DA0A" could not be looked up remotely
Maybe some of the typical recommendations are outdated… Can someone help me out here?
