Cannot update using ' sudo pacman -Syyu '
This might work
pamac update --aur --force-refresh
install syncthing from the official repo (in needed);
sudo pacman -S syncthing
and then build syncthingtray;
pamac build syncthingtray
Could not build, out put:
    ~  pamac build syncthingtray                                                               ✔  8s 
Preparing...
Checking syncthingtray dependencies...
cp: cannot access '/var/lib/pacman/sync/download-vackQq': Permission denied
Resolving dependencies...
Checking inter-conflicts...
To build (1):
  syncthingtray  1.7.3-1    AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Cloning syncthingtray build files...
hint: Using 'master' as the name for the initial branch. This default branch name
hint: is subject to change. To configure the initial branch name to use in all
hint: of your new repositories, which will suppress this warning, call:
hint:
hint:   git config --global init.defaultBranch <name>
hint:
hint: Names commonly chosen instead of 'master' are 'main', 'trunk' and
hint: 'development'. The just-created branch can be renamed via this command:
hint:
hint:   git branch -m <name>
hint:
hint:
hint:
Generating syncthingtray information...
Authenticating as: JKL (jkl-pc)
Password:
Building syncthingtray...
==> Making package: syncthingtray 1.7.3-1 (Fri 14 Mar 2025 07:58:02 PM)
==> Retrieving sources...
  -> Downloading syncthingtray-1.7.3.tar.gz...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100 2112k    0 2112k    0     0  2539k      0 --:--:-- --:--:-- --:--:-- 2539k
    syncthingtray-1.7.3.tar.gz ... Passed
==> Extracting sources...
  -> Extracting syncthingtray-1.7.3.tar.gz with bsdtar
==> Starting build()...
-- The C compiler identification is GNU 14.2.1
-- The CXX compiler identification is GNU 14.2.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Using system qtforkawesome
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- systemd support enabled
-- Configuring project syncthingconnector
-- Using default CXX11-ABI (not forcing old CXX11-ABI of libstdc++).
-- For the check target to work, it is required to call enable_testing() on the source directory root.
CMake Warning at /usr/share/c++utilities/cmake/modules/BasicConfig.cmake:412 (message):
  Format rules for clang-format not found.
Call Stack (most recent call first):
  syncthingconnector/CMakeLists.txt:150 (include)
-- Project has D-Bus interface declarations which will be processed.
-- Linking syncthingconnector against Qt module Qt5::Network.
-- Linking syncthingconnector against Qt module Qt5::Core.
-- Linking syncthingconnector against Qt module Qt5::DBus.
-- Qt variable QT_INSTALL_TRANSLATIONS queried from qmake: /usr/share/qt/translations
-- Qt variable QT_INSTALL_TRANSLATIONS resolved to path: /usr/share/qt/translations
-- Project has translations which will be released.
-- Using template for qtconfig.h.in from QT_UTILITIES installation.
-- Using template for global.h.in from CPP_UTILITIES installation.
-- Using template for version.h.in from CPP_UTILITIES installation.
-- Using template for Config.cmake.in from CPP_UTILITIES installation.
-- Using template for template.pc.in from CPP_UTILITIES installation.
-- Found PkgConfig: /usr/bin/pkg-config (found version "2.3.0")
-- Checking for one of the modules 'cppunit>=1.13.0'
-- Linking test target against syncthingconnector
-- Using template for doxygen.in from CPP_UTILITIES installation.
-- Generating target for generating API documentation for syncthingconnector with Doxygen
-- Using template for config.h.in from CPP_UTILITIES installation.
-- Configuring project syncthingtesthelper
  testhelper/CMakeLists.txt:45 (include)
-- Linking syncthingtesthelper against Qt module Qt5::Network.
-- Linking syncthingtesthelper against Qt module Qt5::Core.
-- Linking test target against syncthingtesthelper
-- Generating target for generating API documentation for syncthingtesthelper with Doxygen
-- Performing Test STD_FILESYSTEM_TEST_0
-- Performing Test STD_FILESYSTEM_TEST_0 - Success
-- Linking syncthingctl against special library for std::filesystem support is not required.
-- Configuring project syncthingctl
  cli/CMakeLists.txt:38 (include)
-- Using Qt QML as JavaScript provider.
-- Using template for jsdefs.h.in from QT_UTILITIES installation.
-- Using template for jsincludes.h.in from QT_UTILITIES installation.
-- Linking syncthingctl against Qt module Qt5::Qml.
-- Linking syncthingctl against Qt module Qt5::Core.
-- Using template for desktop.in from CPP_UTILITIES installation.
-- Using template for appdata.xml.in from CPP_UTILITIES installation.
-- Using template for bash-completion.sh.in from CPP_UTILITIES installation.
-- Generating files for bash completion.
-- Generating target for generating API documentation for syncthingctl with Doxygen
CMake Error at syncthingmodel/CMakeLists.txt:61 (find_package):
  Could not find a configuration file for package "qtforkawesome" that is
  compatible with requested version "0.3.0".
  The following configuration files were considered but not accepted:
    /usr/share/qtforkawesome/cmake/qtforkawesomeConfig.cmake, version: 0.1.0
-- Configuring incomplete, errors occurred!
==> ERROR: A failure occurred in build().
    Aborting...
The issue must be something to do with your system, as it builds fine on my mini-PC:
-- Installing: /var/tmp/pamac-build-scotty/syncthingtray/pkg/syncthingtray/usr/share/icons/hicolor/scalable/apps/syncthingtray.svg
-- Up-to-date: /var/tmp/pamac-build-scotty/syncthingtray/pkg/syncthingtray/usr/share/bash-completion/completions
-- Installing: /var/tmp/pamac-build-scotty/syncthingtray/pkg/syncthingtray/usr/share/bash-completion/completions/syncthingtray
-- Installing: /var/tmp/pamac-build-scotty/syncthingtray/pkg/syncthingtray/usr/share/applications/syncthingtray.desktop
-- Installing: /var/tmp/pamac-build-scotty/syncthingtray/pkg/syncthingtray/usr/share/metainfo/io.github.martchus.syncthingtray.metainfo.xml
==> Tidying install...
  -> Removing libtool files...
  -> Purging unwanted files...
  -> Removing static library files...
  -> Stripping unneeded symbols from binaries and libraries...
  -> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "syncthingtray"...
  -> Generating .PKGINFO file...
  -> Generating .BUILDINFO file...
  -> Generating .MTREE file...
  -> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: syncthingtray 1.7.3-1 (Sat 15 Mar 2025 11:37:50)
==> Cleaning up...
Checking keyring...        [1/1]
Checking integrity...        [1/1]
Loading packages files...        [1/1]
Checking file conflicts...        [1/1]
Checking available disk space...        [1/1]
Installing syncthingtray (1.7.3-1)...        [1/1]
Arming ConditionNeedsUpdate...        [1/3]
Updating icon theme caches...        [2/3]
Updating the desktop file MIME type cache...        [3/3]
Try removing that strange directory first:
sudo rm -fr /var/lib/pacman/sync/download-vackQq
After that, refresh your databases:
pamac update --force-refresh
Then try building syncthingtray again:
Still not working.
Preparing...
To build (1):
Password:
==> Making package: syncthingtray 1.7.3-1 (Fri 14 Mar 2025 11:01:28 PM)
  -> Found syncthingtray-1.7.3.tar.gz
==> Removing existing $pkgdir/ directory...
    Aborting...
Do you have the base-devel package installed? It is required (along with git) for building many AUR packages.
It is installed.
    ~  sudo pacman -Syu base-devel         ✔
[sudo] password for jkl-pc:
 core is up to date
 extra is up to date
 multilib is up to date
warning: base-devel-1-3 is up to date -- reinstalling
resolving dependencies...
Packages (1) base-devel-1-3
:: Proceed with installation? [Y/n] n
The pinned comment on the AUR website says:
Important remarks:
Like with any other package a rebuild is required when the soname of a dependency like boost changes
It is required to build dependencies (that are not provided by Arch Linux itself) before building this package. So you need to build c++utilities, qtutilities, qtforkawesome and syncthingtray in that order.
AUR (en) - syncthingtray
Vielleicht lieber yay statt pamac benutzen?
Than you all for the support, All good now.
Would you please share with us how you solved it?
My assumption is that the error they were encountering was because they had not re-built the other AUR packages that syncthingtray depends upon, as per @Nachlese’s post:
I didn’t pick up on that as syncthingtray built fine on my system, because it built & installed those dependencies in the same transaction. However, those AUR packages were already installed on the OP’s machine, and they were not rebuilt with the re-build of syncthingtray.
The OP might want to install the rebuild-detector package from the repos. After any update they can run the command checkrebuild -v which should (hopefully) advise which AUR packages need to be rebuilt against updated dependencies.
As the OP posted that everything is now good about an hour after @Nachlese’s post, I’m assuming that is what fixed it.
However, as the original issue for this topic was to do with updating their system, and another member also posted their own update issues, @fdietreich is going to have to work out which reply helped the most and mark it as a solution.
