My system will not update as it fails to find texlive-basic 2023 66594-15
Does no one ever use the search function?
sudo pacman-mirrors --geoip
sudo pacman -Syyuu
If this worked, fix pamac with
pamac update --force-refresh
(note, no sudo here)
Thank you for your help, Mithrial.
What you suggested worked very well, and I have made a note of it for if something similar happens again.
I have been using Manjaro for some time, and this is the first time updates using the GUI from the bottom of the screen have failed.
I have never needed to use pacman commands before.
Had the same issue and your fix worked for me as well. Thank you
Also had this issue, fix also worked for me. Thanks! I appreciate it.
I had been googling around off and on for a week or two and this was the first relevant answer I found.
