Cannot update due to package issue
When I try to update my system this is what it does.
(575/575) checking for file conflicts [######################] 100%
error: failed to commit transaction (conflicting files)
/usr/lib/python3.8/site-packages/service_identity-18.1.0-py3.8.egg-info/PKG-INFO exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity-18.1.0-py3.8.egg-info/SOURCES.txt exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity-18.1.0-py3.8.egg-info/dependency_links.txt exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity-18.1.0-py3.8.egg-info/not-zip-safe exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity-18.1.0-py3.8.egg-info/requires.txt exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity-18.1.0-py3.8.egg-info/top_level.txt exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/init.py exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/pycache/init.cpython-38.opt-1.pyc exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/pycache/init.cpython-38.pyc exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/pycache/_common.cpython-38.opt-1.pyc exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/pycache/_common.cpython-38.pyc exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/pycache/_compat.cpython-38.opt-1.pyc exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/pycache/_compat.cpython-38.pyc exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/pycache/cryptography.cpython-38.opt-1.pyc exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/pycache/cryptography.cpython-38.pyc exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/pycache/exceptions.cpython-38.opt-1.pyc exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/pycache/exceptions.cpython-38.pyc exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/pycache/pyopenssl.cpython-38.opt-1.pyc exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/pycache/pyopenssl.cpython-38.pyc exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/_common.py exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/_compat.py exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/cryptography.py exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/exceptions.py exists in both 'python-service-identity' and 'python-service_identity'
/usr/lib/python3.8/site-packages/service_identity/pyopenssl.py exists in both 'python-service-identity' and 'python-service_identity'
glslang: /usr/lib/cmake/HLSLTargets-release.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/HLSLTargets.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/OGLCompilerTargets-release.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/OGLCompilerTargets.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/OSDependentTargets-release.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/OSDependentTargets.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/SPIRVTargets-release.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/SPIRVTargets.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/SPVRemapperTargets-release.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/SPVRemapperTargets.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/glslang-default-resource-limitsTargets-release.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/glslang-default-resource-limitsTargets.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/glslangTargets-release.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/glslangTargets.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/glslangValidatorTargets-release.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/glslangValidatorTargets.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/spirv-remapTargets-release.cmake exists in filesystem (owned by lib32-glslang)
glslang: /usr/lib/cmake/spirv-remapTargets.cmake exists in filesystem (owned by lib32-glslang)
The first part oddly looks like someone who used sudo pip install at one point or another.
By the way, which branch are you using? I think Python 3.8 is only a thing in Unstable for now, right?
Try...
sudo pacman -Syu --overwrite=/usr/lib/*
... in a terminal.
Well to Answer your question frog. I am using the unstable branch of Manjaro. Thank you Aragorn I appreciate the help. Also appreciate Frog for trying to help. Aragorn your post is marked as the solution in case anyone else has this issue come up.
