Cannot stream or record in OBS Studio
I cannot stream or record in obs-studio. When I click record or stream I receive the following error:
Starting the output failed. Please check the log for details.
Note: If you are using the NVENC or AMD encoders, make sure your video drivers are up to date.
This is after the latest upgrade. However I get the exact same error regardless of whether I use the Flatpak, Snap or native version of the package. Software encoding works perfectly as it should. My initial thinking it might be a setting or bug in the Nvidia drivers. I'm using a GeForce GTX 1050 Ti with the latest drivers available in Manjaro. The rest of my 'lspci' can be found here on Pastebin.
I have attached the OBS logs below.
10:01:39.557: ==== Startup complete ===============================================
10:01:39.557: Service '' not found
10:01:39.558: All scene data cleared
10:01:39.558: ------------------------------------------------
10:01:39.560: pulse-input: Server name: 'pulseaudio 13.0'
10:01:39.560: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
10:01:39.560: pulse-input: Started recording from 'alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-stereo.monitor'
10:01:39.569: pulse-input: Server name: 'pulseaudio 13.0'
10:01:39.569: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
10:01:39.569: pulse-input: Started recording from 'alsa_input.usb-C-Media_Electronics_Inc._USB_Advanced_Audio_Device-00.analog-stereo'
10:01:39.569: Switched to scene 'Scene'
10:01:39.569: ------------------------------------------------
10:01:39.569: Loaded scenes:
10:01:39.569: - scene 'Scene':
10:01:42.104: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds (source: Desktop Audio)
10:01:42.104:
10:01:52.699: ---------------------------------
10:01:52.699: [NVENC encoder: 'simple_h264_stream'] settings:
10:01:52.699: 	rate_control: CBR
10:01:52.699: 	bitrate:      2500
10:01:52.699: 	cqp:          0
10:01:52.699: 	keyint:       250
10:01:52.699: 	preset:       hq
10:01:52.699: 	profile:      high
10:01:52.699: 	width:        1280
10:01:52.699: 	height:       720
10:01:52.699: 	2-pass:       false
10:01:52.699: 	b-frames:     2
10:01:52.699: 	GPU:          0
10:01:52.699:
10:01:52.702: [NVENC encoder: 'simple_h264_stream'] Failed to open NVENC codec: Unknown error occurred
Post title edited. Please don't paste long error messages in the topic title. Keep it clear and concise.
Provide
inxi -Fxxxza --no-host
so we know what we are dealing with ...
Also, it seems you are using simple settings. Try Advanced, so then you should use this option instead
Whatever settings i use, i can't reproduce your issue and i have GeForce GTX 960/PCIe/SSE2 with the video-nvidia-440xx drivers
I experienced the same problem. I used to timeshift to restore the latest driver and kernel updates but it didn't help. Anyway, I was using obs from the snap store. The window capture worked properly in that build but the recording didn't start.
I uninstalled it and installed the obs studio from the arch community repository. The recording in this build is working fine but the window capture isn't working well - all windows say unknown and i am unable to record cs go gameplay. I hope this information helps.
I have the same issue on my GTX 1060. Tested with AUR, Flatpak and Snapcraft.
This seems a driver regression to me, because it already happened in the past and did not affected all gpu models.
I opened an issue report on nvidia forums. Fingers crossed! :crossed_fingers:
So it turned out the mhwd script generates a misconfigured? conf file that doesn't load nvidia-uvm module at boot, which is required by NVENC encoder to work.
PS: the nvidia customer support is very fast! :flushed:
Hey @Leprotto79 would you mind to post here the link for you post on Nvidia forums? I'm having the same issue and would love to follow there
