Cannot set mirror country through GUI settings
I have another problem.
I set the mirror server to United States
I close and reopen the settings window and I see that the mirror server has changed to Worldwide. (??)
Please post you own problems in you own topic, 1 problem pro topic. Post split, free of charge this time.
How about setting the mirror pool with the terminal then?
https://wiki.manjaro.org/index.php/Pacman-mirrors#Mirrors_for_your_country_only
The pamacGUI is known to have issues. It is better to use the command line. :backhand_index_pointing_down:
sudo pacman-mirrors -c United_States && sudo pacman -Syu
I believe this is a bug in the Add / Remove Applications (Pamac) software.
It is expected that pamac executes pacman-mirrors -c <country> - obviously it does not.
When this happens you need to use the terminal command.
First get a list of supported countries (the reason being that double word countres (for cli reasons) are spelled using a _ (lodash) instead of space)
pacman-mirrors --list
Then build a mirror pool for the country e.g. United_States
sudo pacman-mirrors --country United_States
Or maybe it attempts to do it but does not elevate its privileges through polkit first. :thinking:
Don’t know what track OP is, but on my unstable seems to be working.
