The OP seems to desperately want there to be…
Quick question;
Did you ever see The Matrix franchise?
There is no spoon.
Quick question;
There is no spoon.
This is the last thing I’ll say here:
gwenview
in an up to date Manjaro Plasma VMIt works - not problem at all.
@AdrianM
your sample file remains the only one being problematic
Indeed! So, for problematic / incompatible files, conversion is the only sensible option.
I’d be tempted to alter the title to add “non-standard” or something, but I will resist.
I have no such resistance to that temptation;
given that the title is simply wrong in context of information provided by others; and especially, information from a heif
/heic
addon developer who has taken the time to create a Manjaro forum account to respond.
@AdrianM, you have always the option to use the programs that work with your heif files, like:
eye of mate, eye of gnome, gimp.
There is also the option, to configure your smartphone, to create .jpg files.
I would do the last one.
GIMP requires libheif
, that includes;
heif-info
to show information about HEIC/HEIF filesheif-convert
to convert imagesheif-dec
and heif-enc
to decode and encode imageslibheif
is also a dependency of geeqie and oculante
and an optional dependency of imagemagick
I just tried opening the image in GIMP on the other machine, which I haven’t explicitly added any .heif stuff to, and it works.
The problem is that HEIF/HEIC files created by Xiaomi 14 phones are not in full harmony with standards.
The files have invalid value in “matrix coefficients”
Gwenview decode HEIF files via kimg_heif.so Qt plug-in from kimageformats.
The plug-in uses strict decoding for security reasons and invalid files are rejected.
If we don’t use the strict decoding, the file would be decodable, but potential of security risk would be higher.
Ideal solution would be that Xiaomi customers request the Xiaomi company to update their software to generate 100% compatible files.
There is no problems with files created by iPhone or Samsung phones.
