Cannot mount certain removable media like SDXC card
#1
This issue seems to exist in OpenRC installations only. I can mount other memory cards but trying to mount SDXC card gives me an error ending with this suggestion:
stderr: `fuse: device not found, try ‘modprobe fuse’ first
Indeed, if I run modprobe fuse first I can mount the card.
How can I get around this? How can I put this command in startup (XFCE) to run as root if that is only solution?
Thanks.
#2
There is a fuse-openrc package; do you have that installed?
Then try sudo rc-service fuse start (and it should start at boot). I don’t use it, but I’d guess it’s needed in your case.
#3
Thank you.
I have it installed but service does not start at reboot.
It works when started as you suggest but after reboot service is not running.
#4
Oh yes, it also needs to be added to the default runlevel:
sudo rc-update add fuse default
#5
That worked!
Thank you so much. This has been torturing me for months, since started using Manjaro OpenRC. Could not find an answer anywhere.
:triumph:
closed #6
