Cannot login to Dovecot with PAM authentication anymore
#1
I run a local Dovecot server to archive my e-mails. Since recently, PAM authentication does not work anymore.
Journalctl complains that /etc/pam.d/imap is missing:
dovecot[2032]: auth-worker(2042): Error: pam(rk,127.0.0.1,<NJswDoCCrpp/AAAB>): pam_authenticate() failed: Authentication failure (/etc/pam.d/imap missing?)
So I created the file with a single line:
auth sufficient pam_unix.so
This changes the complaint in journalctl to:
dovecot[2032]: auth-worker(2042): Error: pam(rk,127.0.0.1,<rUqq5n+Ccpp/AAAB>): pam_acct_mgmt() failed: Authentication failure
My Dovecot configuration /etc/dovecot/dovecot.conf looks like this:
listen = 127.0.0.1
syslog_facility = mail
mail_location = maildir:~/Mail
ssl = no
protocol imap {
auth_mechanisms = plain
passdb {
	driver = pam
	args = %s
userdb {
	driver = passwd
How can I make PAM authentication work again?
#2
Create a pam file for dovecot
https://wiki.archlinux.org/index.php/Dovecot#PAM_Authentication
The new version of pam now requires it.
#3
According to the Wiki, I created the missing file with exactly these two lines copy-pasted from Wiki. Now, the systemd-journal says:
 dovecot[2210]: auth-worker(2223): Error: pam(rk,127.0.0.1,<4wueq4CCzJp/AAAB>): pam_acct_mgmt() failed: Authentication failure
I interpret this as invalid credentials (username or password wrong), but they are correct. What do I still miss about it?
#4
Another try, changed
args = %s
to
args = session=yes dovecot
yields:
Error: pam(rk,127.0.0.1,<3WXM5YCCCJt/AAAB>): pam_open_session() failed: Cannot make/remove an entry for the specified session
#5
This error looks similar to this one
https://bbs.archlinux.org/viewtopic.php?id=244119
The user changed the /etc/pam.d/dovecot to
auth     required        pam_unix.so nullok
account  required        pam_unix.so
password  required        pam_unix.so
session  required        pam_unix.so
#6
Thanks, that did it.
Funnily enough, exactly in the moment you answered, I was reading
https://bbs.archlinux.org/viewtopic.php?id=166245
and wondered if I should expand my /etc/pam.d/dovecot by some lines.
