Hi
After switching to LightDM I can no longer login to Gnome. I get an “Oh no something went wrong” error with an icon and a logout button which takes me back to the login screen.
I can login to i3wm but not Gnome. I get several options to log in to:
- Gnome
- Gnome
- Gnome Xorg
- i3
- i3 with debug
Everyone of the gnome ones seems to fail.
What I did was:
- uninstall GDM and 3 GDM related packages
- installed lightDM and the settings and greeter
- added a startup script for my nvidia setup
My inxi output (in i3 where I’m typing this):
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6d47e3af-06dc-4c7e-8911-b128fad8df5c rw quiet
cryptdevice=UUID=5a8341b1-c666-4441-a050-661f3f785c79:luks-5a8341b1-c666-4441-a050-661f3f785c79
root=/dev/mapper/luks-5a8341b1-c666-4441-a050-661f3f785c79
resume=/dev/mapper/luks-f053e508-c248-4022-a23f-a1ef2360e42f
udev.log_priority=3
Desktop: i3 4.19.1 info: i3bar vt: 7 dm: LightDM 1.30.0
Type: Laptop System: Dell product: Precision 5540 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0FMYX6 v: A00 serial: <filter> UEFI: Dell v: 1.10.0
date: 03/04/2021
ID-1: BAT0 charge: 30.2 Wh (39.7%) condition: 76.1/97.0 Wh (78.4%)
volts: 11.0 min: 11.4 model: SMP DELL GPM0365 type: Li-ion serial: <filter>
status: Discharging
RAM: total: 31 GiB used: 1.7 GiB (5.5%)
Info: 8-Core model: Intel Core i9-9880H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: D (13)
microcode: DE cache: L2: 16 MiB bogomips: 73625
Speed: 900 MHz min/max: 800/4800 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 900 8: 900 9: 901 10: 900 11: 900 12: 900 13: 900
14: 900 15: 900 16: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117GLM [Quadro T2000 Mobile / Max-Q] driver: nvidia
v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1fb8
class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:4 chip-ID: 0c45:6723 class-ID: 0e02
Display: x11 server: X.org 1.20.11 driver: loaded: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA Quadro T2000/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: 3000
bus-ID: 3b:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
IF-ID-1: br-dabcbf2d524d state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-4:2 chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 953.87 GiB used: 31.72 GiB (3.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel
model: SSDPEMKF010T8 NVMe 1024GB size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 7003 temp: 28.9 C scheme: GPT
ID-1: / raw-size: 919.47 GiB size: 903.97 GiB (98.31%)
used: 31.72 GiB (3.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-5a8341b1-c666-4441-a050-661f3f785c79 label: N/A
uuid: 6d47e3af-06dc-4c7e-8911-b128fad8df5c
used: 440 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: F21B-F106
ID-1: swap-1 type: partition size: 34.09 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-f053e508-c248-4022-a23f-a1ef2360e42f label: N/A
uuid: a451e491-90d9-45aa-b9f3-edea44fd9df6
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 919.47 GiB
fs: <superuser required> label: N/A
uuid: 5a8341b1-c666-4441-a050-661f3f785c79
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 34.1 GiB fs: <superuser required>
label: N/A uuid: f053e508-c248-4022-a23f-a1ef2360e42f
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-4:2 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Device-2: 1-7:3 info: Shenzhen Goodix Fingerprint Reader
type: Abstract (modem),CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5395 class-ID: 0a00
serial: <filter>
Device-3: 1-12:4 info: Microdia Integrated_Webcam_HD type: Video
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 43.0 C mobo: N/A gpu: nvidia temp: 53 C
Fan Speeds (RPM): cpu: 2384 fan-2: 2410
Processes: 322 Uptime: 31m wakeups: 3890 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1035 pacman: 1021 lib: 281
flatpak: 8 snap: 6 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.04
