Hello, after installing some packages at reboot GRUB only boots with MemTest. I tried to boot the system from the GRUB command line but I couldn’t find the kernel image (6.12) in /boot folder.
Then I tried with the Live USB using the recovery system: the first 2 ways have no effect. The third one installed the 5.10 kernel but I have a black screen when booting.
Now I’m using chroot but if I try to update the system with pacman
[manjaro /]# pacman -Syyu
core 139.9 KiB 260 KiB/s 00:01 [######################] 100%
extra 8.3 MiB 3.83 MiB/s 00:02 [######################] 100%
multilib 140.0 KiB 262 KiB/s 00:01 [######################] 100%
there is nothing to do
If I try to install other kernels I get this error:
[manjaro /]# mhwd-kernel -i linux614
core is up to date
extra is up to date
multilib is up to date
error: no targets specified (use -h for help)
If i check kernel status i get this:
[manjaro /]# mhwd-kernel -li
Currently running: 6.12.4-1-MANJARO (linux612)
* linux510
kommow:
mhwd-kernel -i
will not work in chroot
use pacman instead
pacman -S linux612
I wouldn’t use 614 - it’s not an LTS like 612 is
Just install any kernel
use
mkinitcpio -P
update-grub
that should have already done it
update-mirrors -f
pacman -Syu
Thank you, I didn’t know mhwd doesn’t work in chroot.
With pacman I have this error, is a mount missing?
[manjaro /]# pacman -S linux612
resolving dependencies...
Packages (1) linux612-6.12.17-1
Total Download Size: 139.22 MiB
Total Installed Size: 144.58 MiB
:: Proceed with installation? [Y/n] Y
error: could not open file: /etc/mtab: No such file or directory
error: could not determine filesystem mount points
error: failed to commit transaction (unexpected error)
How do you get to chroot?
/proc
should be mounted after that
which means
/etc/mtab
would be accessible
which it is not, as per the error message
mhwd
does work
just mhwd-kernel -i ...
doesn’t
Are you using btrfs
by any chance? manjaro-chroot
does not work with btrfs
. You’ll need to take care of mounting the necessary volumes yourself.
Assuming that the EFI system partition is on /dev/sda1
and the Manjaro root filesystem on /dev/sda2
— change this to what is applicable for your system — it would be something like this…
mount -t btrfs -o subvol=@ /dev/sda2 /mnt
mount -t btrfs -o subvol=@home /dev/sda2 /mnt/home
mount -t btrfs -o subvol=@log /dev/sda2 /mnt/var/log
mount -t btrfs -o subvol=@cache /dev/sda2 /mnt/var/cache
mount -t vfat /dev/sda1 /mnt/boot/efi
mount --bind /dev /mnt/dev
mount -t proc proc /mnt/proc
mount -t sysfs sysfs /mnt/sys
mount -t efivarfs efivarfs /mnt/sys/firmware/efi/efivars
chroot /mnt /bin/bash
Done!
I got into chroot by the Manjaro recovery tool (I attach screen)
Now I retried directly from terminal and mounted the system folder
~ lsblk ✔
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 67.7M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 1.1G 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 1.5G 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 858.9M 1 loop /run/miso/sfs/rootfs
sda 8:0 0 223.6G 0 disk
└─sda1 8:1 0 223.6G 0 part /run/media/manjaro/3601e1d3-845a-4d06-85d5-06b2b213d7b9
sdb 8:16 1 57.3G 0 disk /run/miso/bootmnt
├─sdb1 8:17 1 3.6G 0 part
└─sdb2 8:18 1 4M 0 part
~ sudo mount /dev/sda1 /mnt ✔
~ sudo mount --types proc /proc /mnt/proc ✔
~ sudo mount --rbind /sys /mnt/sys ✔
~ sudo mount --rbind /dev /mnt/dev ✔
~ sudo chroot /mnt ✔
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
linux612-6.12.17... 139.2 MiB 4.56 MiB/s 00:31 [######################] 100%
(1/1) checking keys in keyring [######################] 100%
(1/1) checking package integrity [######################] 100%
(1/1) loading package files [######################] 100%
(1/1) checking for file conflicts [######################] 100%
(1/1) checking available disk space [######################] 100%
(1/1) installing linux612 [######################] 100%
Optional dependencies for linux612
wireless-regdb: to set the correct wireless channels of your country
[installed]
linux-firmware: firmware images needed for some devices [installed]
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Install DKMS modules
==> ERROR: Missing 6.12.17-1-MANJARO kernel headers for module v4l2loopback/0.13.2.
(4/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
==> Starting build: '6.12.17-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [kms]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [plymouth]
-> Running build hook: [fsck]
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
-> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'fallback'
-> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'xhci_pci_renesas'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64-fallback.img'
(5/5) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
Found initrd fallback image: /boot/initramfs-6.12-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
ERROR: mkdir /var/lock/dmraid
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
[manjaro /]# mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -g /boot/initramfs-5.10-x86_64.img
==> Starting build: '5.10.234-2-MANJARO'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-5.10-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: '/boot/initramfs-5.10-x86_64-fallback.img'
[manjaro /]# update-grub
done
But still doesn´t boot. After the splash loading screen i got a black monitor.
No, i’m not using a btrfs filesystem. Thanks
I do not know this tool, what it does and how.
To me it looks like another obfuscation layer.
My opinion from trying to use it - not your fault.
It sure did mess with my perfectly functional system - I’m not touching the tool again.
What I do know is the command line tool manjaro-chroot
lsblk -f
gives more relevant and important output
Do not mount anything after you booted the ISO - just use
manjaro-chroot -a
from that same terminal.
See how that goes.
Do not use the system recovery tool.
If you do, I cannot help you - as I do not know it - see above.
It is available on live iso, package named manjaro-rescue authored by @Ste74
→ Stefano Capitani / manjaro-rescue · GitLab
A launcher named Restore installed system settings is provided.
I know.
I’ll have a look at it’s code to try and learn how it works.
Before writing my last post, I did try to use it - on my perfectly functioning system.
It didn’t manage to spot that I have (in /etc/fstab
a separate partition for /var/cache/pacman/pkg
and so it proceeded to download the updates without mounting that partition.
Not the end of the world, but the / file system is not the place the downloaded packages belong (in my setup).
I interrupted the tool and had to clean up the mess manually.
you have to remove this old kernel version ,
and add other
under chroot
pacman -Rs linux510
pacman -S linux66 linux66-headers linux612-headers
mkinitcpio -P
sync
exit ( end chroot )
I suggest you create an issue with the developer @Ste74 as he is very open to improving the tool
The problem with such tools - any deviation on the target system must be accounted for - and that is not an easy task.
No, it didn’t fix the problem. Always stuck on boot after loading screen
Now instead of the 510, as second kernel I have 66
* linux612
* linux66
can you reboot , press Esc to see grub appears
go in advanced section and select kernel6.6
Yeah, i had already tested both kernels boot in GRUB without success
Yes, i used the recovery tool only at the first try. Then i follow your step using the standard manjaro-chroot
and mount /dev/sda1
If yuo wanna give a look at lsblk -f
output…here the result:
lsblk -f ✔
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
squash 4.0 0 100% /run/miso/sfs/livefs
loop1
squash 4.0 0 100% /run/miso/sfs/mhwdfs
loop2
squash 4.0 0 100% /run/miso/sfs/desktopfs
loop3
squash 4.0 0 100% /run/miso/sfs/rootfs
sda
└─sda1
ext4 1.0 3601e1d3-845a-4d06-85d5-06b2b213d7b9 141.7G 30% /run/media/manjaro/3601e1d3-845a-4d06-85d5-06b2b213d7b9
sdb iso966 Jolie MANJARO_XFCE_2421 2024-12-16-11-22-45-00 0 100% /run/miso/bootmnt
├─sdb1
│ iso966 Jolie MANJARO_XFCE_2421 2024-12-16-11-22-45-00
└─sdb2
vfat FAT12 MISO_EFI 9D59-BEAA
manjaro-chroot -a
should work
install a kernel using pacman
mhwd-kernel -i
mhwd-kernel -l
lists what is available - choose one and
pacman -S linuxXYZ
OK, here’s the story:
With the help of @Nachlese I solved the main problem about missing kernel in GRUB boot
I kept the focus on the kernel not thinking that the problem instead had moved
So, digging into the boot.log
in /var/log and I found a break in the LightDM
Going in depth I also checked Xorg.0.log
and it is here that I found an error on the nVidia kernel.
I reinstalled the drivers but when I checked if the module was loaded (with modprobe
), new errors came out.
After several checks, I finally found out that nouveau driver creates the conflict with proprietary nVidia files, so I put it on blacklist and boot went smoothly. Honestly I do not know what has activated them in the past…
Thank you all for your support
in this case , that i do
double command in terminal , to get the good blacklist drivers
sudo mhwd -a pci free 0300
sudo mhwd -a pci nonfree 0300
