Hi I am trying to install mongodb bin from aur. I downloaded the package and ran
makepkg -si
but it says dependencies cannot be installed.
error: target not found: python-cheetah3
==> ERROR: ‘pacman’ failed to install missing dependencies.
==> Missing dependencies:
→ scons
→ python-psutil
→ python-regex
→ python-cheetah3
→ python-pymongo
==> ERROR: Could not resolve all dependencies.
What might be the solution
xabbu
2
This is an AUR package. Install it from AUR manually, or use a AUR helper that helps you with this kind of problem.
Is there any way to make pacman install aur packages??
xabbu
4
Only after a package is build with makepkg.
This is the reason why there are so many AUR helpers out there. An AUR Helper takes care of this kind of problem.
Not with pacman
, but pamac
can handle the AUR.
pamac build python-cheetah3
Note: pamac
must not be used with sudo
. It is polkit
-aware and will prompt you for the password itself.
system
Closed
6
