How do I Enable Menubar in Manjaro, to access File, View Help, To change kcalc preferences from NORM mode?
bash321
Do you have global menu enabled? Because I cannot find any option to disable KCalc’s menu bar. BTW, you can access the Preferences
with Ctrl+Shift+,, KCalc Handbook
with F1, and 'What's This'
with Shift+F1.
The default shortcuts are:
Have you tried Ctrl+M?
Hi shirshendu,
No, I don’t have global menu enabled.
Thank you for the screenshot of shortcuts.
I opened the command bar using the keyboard shortcut CTRL+ALT+I, and selected science mode for the calculator, which allows me to calculate power numbers.
Kcalc is now working.
Challenge to change modes, but it does work.
bash321.
Yes i tried CTRL+M no response from the app.
@bash321 From the Command Bar
, you can open Configure Keyboard Shortcuts
and there you can assign custom shortcuts for the modes you use.
