I have often access problem with my Iphone, i have libimobiledevice and ifuse installed, but with Libimobiledevice method (acces with Nemo) a lot of time , i have acces error when i want to use Gthumb or Rapid Photo Downloader for my photos transfer and no .heic file…slow acces with Nemo, long time to display a photo…
I try the Ifuse methode, no problem, but give me only .heic file so i have to convert to jpg ???
I all retry al the step:, with Gvfs i have .jpg photo but non .heic, access is slow.
With Ifuse, i have all my .heic files and fast access, so i thing i will have to use this method and search for a good .heic ->.jpg convertor, is there any with auto conversion ?
When you download from Icloud, You can export as the file ext you want? I just copied over some photo’s from my iphone to manjaro, and didn’t have to or use any conversion. I can then convert the files as usual from Manjaro.
There is libheif for heic support but not all picture apps support it.
imagemagick can be used afterwards to convert (terminal). Or converseen (i think it’s a front end for imagemagick and it’s a batch converter)
